Fuse blew when I hooked up speakers.opened up my durrabrand ht-400 and seen it caught fire a little bit.can this be fixed,and if so,how. Need help
  • 4,201 Answers
From your photo it looks like the power transistor is blown up
Fuse blew when I hooked up speakers.opened up my d - 5_4_2017_7_22_32_am-fqpri0tghtom2qr1ml2b2auw-4-0.jpg You may need to follow the circuit tracks and see if there are any other components blown up Maybe the resistors or capacitors
You need to ask yourself why did the speakers blow this up maybe there is a short circuit in the speakers ?
Posted on May 04, 2017
My car is shaking when I put it in reverse and a little bit when in drive. Prior to this I changed out my plugs and wires and the car was acting up by backfiring and shaking violently.
I am thinking that with the back firing ans all ,you put the ht leads on in the wrong firing order and had 2 wires crossed
when replacing the new with the old you fixed the cross wires but reintroduced a bad plug or a bad ht lead.
Jun 24, 2015 | Cars & Trucks
I can only hear phone calls if it is on speaker phone. I have tried blowing into the device and that was no help. This just started happening a couple of days ago out of no where. Apple iphone 3G. Hope...
I had seen this problem, you will have to change the earpiece speaker, and another thing is that you will not get that alone, it is a set that contains the loudspeaker, mike and earpiece speaker
Oct 23, 2013 | Apple iPhone 3G
I need a fuses for my durabrand home theater system and model is ht-3916. i went to radio shack and purchase a fuse 1.6 amp volt fuses and it still don't work can you please help me thank you
Do you mean it blew them again or that it didn't work and the fuse is still intact?
If it blew it again the problem is not the fuses. Instead what you have is a semi-conductor device that has developed a short and that is blowing the fuse. Check any devices in the power supply section, look for signs of damage or heat and also any devices on the heat-sink.
If the fuse did not go and it still doesn't work check the power supply only or the on-off switch.
May 24, 2011 | Durabrand HT-3915 System
Sa-ak17 displays f 61
First, stop feeding it fuses until you determine the cause. Every time you blow a fuse you're stressing something in line with it.
We'd need some specific details about the sub and how it is being driven to even begin to answer the question.
My guess is you did something with the sub that is NOT recommended by the manufacturer. Shelf systems are generally not designed to be mix-n-match with other speaker components.
The F61 means "Check and correct the speaker cord connections. If this does not fix the problem, there is a power supply problem. Consult the dealer".
A blown fuse IS a power supply problem. You might look for a hands-on tech to give it a sniff and a look for whatever got cooked.
Apr 17, 2010 | Panasonic SC-AK17 Shelf System
Where can i find the Durabrand ht-400 manual
You will find the manual here>
http://www.funai-corp.com/support/default.aspx
Please vote if this helps you
Jul 01, 2009 | Durabrand 5.1 Surround Sound Computer...
I blew my fuses on my ht-400 digital home theater system
Radioshack has a good selection of fuses, an all you do is take the one out of the system take it with you an they will help you find the fuse ur looking for, an you would be good to go
Oct 22, 2008 | Audio Players & Recorders
Problem w/ surround sound for Onkyo HT-R430
you are in stereo mode which only uses the two front speakers, hit the surround sound button remote or hit the mode button and cycle through until you get to the Dolby II setting
Dec 31, 2007 | Onkyo HT-S680 System
Surround sound
adding more speakers in parallel reduces the impedance, causing the amp to work harder. if you reduce the impedance to much and turn the volume up its a bit like making a short across the output, and has probably damaged the output stage. if you are really lucky it may be fused and simple replacement will fix the issue. if not it could be a costly repair. always observe the minimum impedance rating on your amp and match the speakers to it, never less than it
Sep 02, 2007 | Samsung HT-Z310T Theater System
 Grubhead
Grubhead
