Question about The Computers & Internet
I put my code in and it started to open but never fully opened and then 3 lines just keep passing. How do fix this problem? I'm going on vacation and my passport is in the safe. Please help.
  • Tito
    Tito May 04, 2017
    I don't have the key either. I bought the drawer at a garage sale and was never given the key.
SOURCE: error`E40
hi there e40 fault is a problem with your door interlock. get it replaced and all will be fine..
Posted on Apr 04, 2008
SOURCE: batteries are dead can't open safe
I had the same problem. We finally located where the batteries were hidden. They were below the keypad, There is a silver, plastic cover that slides to the right to expose the 4 AA batteries. Hope this helps you.
Posted on Jul 14, 2008
ekoo
SOURCE: need to reset the electronic code to open the safe.
are you the manager user of the safe?if yes,you can reset a new code by yourself.
Posted on Apr 09, 2009
SOURCE: I cannot open safe with the usual code.Safeguard electronic digit
To open a Safe International Digital Electronic Safe
User override key to open safe
Then:
a. Inside the open door you would find hidden a red button press this button, the yellow light will be on, input the user code in 30 seconds try 1,5,9 then press A or B to finish
b. If the yellow light keeps flashing with beeps the code is wrong( revere to user manual)
c. To change code repeat step a.
Test your new code before closing safe.
Posted on Apr 27, 2009
SOURCE: factory code will not open model # DA3831 safe
i am a locksmith that has worked on several of these. The safe is manufactuered with three types of lock mechanisms 1. combo dial 2. digital 3. advanced digital the advanced digital is what you have there are no green lights on it. look at the manual carefully there are 2 seperate sections on the digital key pads yours will be the second.
Posted on Dec 18, 2009
No Crank, No Start After Clearing Check Engine / Security Codes?
Do you know what these DTC'S are ?
DTC B2960
The BCM supplies a 5 volt signal and a ground circuit for the PASS-Key® system. This allows the BCM to detect PASS-Key® resistance values. Inserting the PASS-Key® (with resistor pellet) in the ignition lock cylinder completes the PASS-Key® circuit. Contacts in the ignition lock cylinder mate with the pellet contacts. The BCM compares the resistance value of the key pellet to the valid resistance programmed into the BCM. If the proper resistance value is read, the BCM allows the following functions to occur:
• The BCM sends a message through the class 2 serial data link to the PCM to enable the starter relay.
• The BCM sends a message through the serial data line to the PCM to enable fuel delivery.
If the resistance value is incorrect, a malfunction is present and a DTC will set.
Diagnostic Aids
• The following conditions may cause an intermittent malfunction:
- There is an intermittent open or short to ground on the PASS-Key® signal or ground circuit.
- There are poor connections at the BCM or the ignition switch connector.
- The ignition lock cylinder key contacts or the PASS-Key® resistor are dirty or loose.
• If the key resistor pellet is incorrect, there will be no BCM outputs to the crank relay or to the PCM. This state will last about 3 minutes. If a key is inserted, or the ignition is turned ON again before the 3 minute time frame is complete, the timer will reset to 3 minutes. Disconnecting the battery will not clear the timer sequence, but the timer will reset to 3 minutes when the battery power is restored. Even if a proper key is inserted during one of the time periods, the vehicle will not start until the total time period has elapsed.
Do you know anything about this system ? The scan tool didn't do anything , you did .
By pass the ignition lock cylinder .
measure the resistance of the pellet on your key , go to radio shack an buy resistors . Watch this video .
How to troubleshoot bypass GM VATS Passlock Passkey System
GM VATS Key Resistor Key Security Bypass
Feb 13, 2018 | Buick Cars & Trucks
Tip
Apple iPhone, iPad, iPod Forgotten Pass-code Fix
*Attention* If you have forgot your pass-code to unlock your iDevice I am sorry, But this IS the only (Official Apple) way to 'Un-Lock' it and remove pass-code to gain access without hacking it.
You are going to need a computer with the latest version of iTunes on it and unfortunately this will fully erase all data on the device .
So with the device plugged into your PC, iTunes open, if it shows up in iTunes eject it, or cancel the prompt to restore a device in recovery mode.
Hold down the Power button for 3 seconds
Without releasing the power button, also hold the Home button for 10 seconds
Without releasing the home button, release the power button and keep holding the Home button for About 20 seconds.
iTunes will detect an iPhone/iPod/iPad in recovery mode, let off button and set down device and hit RESTORE in iTunes.
If you cannot get it to work, just try again, Holding Home Button for say 9 seconds instead of 10.
on Sep 28, 2011 | Cell Phones
How do I fix my automatic transmission that keeps redlining and wont go passed 50 ?
You need to put a scanner on the truck and read the code, it may not be your transmission. It sounds like it may be in limp home mode and therefore, it won't go over 50.
Nov 25, 2015 | 1993 CHEVROLET SUBURBAN 1500 Grille...
How do you reset an iPod Touch?
if it is not locked with a pass code you can go to settings general scroll down to the bottom to reset and you select you select erase all content and settings. if it is locked with a pass code You are going to need a computer with the latest version of iTunes on it and unfortunately this will fully erase all data on the device Its called Forced Recovery.
iTunes will detect an iPod/iPhone in recovery mode, let off button and set down device and hit RESTORE in iTunes.
Sep 29, 2011 | Apple iPod touch
I have a Sony Handycam DCR-HC-48 and the tape door won't close along with a 32.11 error code.....HELP
Try these steps:
1. Open the tape cover fully until it clicks open.
2. Turn the camcorder on to "VCR Mode."
3. With the cover still open and the camera in "VCR mode," take out the battery.
4. Put the battery back in--out should pop your tape.
Keep us updated.
Jun 06, 2011 | Sony Handycam DCR-TRV140E Digital...
Changed water filter and bushed lock & water buttons, red light went off but green light and other indicator lights (crushed ice, cubes, night light) did not work. Removed new filter & put . .back...
Below are instructions to reset water filter light. Thanks, Sea Breeze
If helpful please rate.
Reset Filter (select models)
When a water filter has been installed in the
refrigerator, the yellow Order light will illuminate when
90 percent of the volume of water for which the filter is
rated has passed through the filter OR 11 months have
elapsed since the filter has been installed.
The red Replace light will illuminate when the rated
volume of water has passed through the filter OR 12
months have elapsed since the filter was installed. A
new filter should be installed immediately when the
Replace light is illuminated.
After replacing the filter, press and hold the Reset
Filter pad for three seconds. The Order and Replace
lights will go off.
Vacation Mode
The Vacation Mode feature causes the freezer
to defrost less frequently, conserving energy. The
Vacation Mode indicator light will illuminate when the
feature is activated. To deactivate, press the Vacation
Mode pad again OR open either door. The indicator
light will go off.
Temp Alarm
Apr 22, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I have a dodge dakots 2003. I have an OBDII code
Code P1281: Engine Is Cold Too Long
The running to cold to long will put your computer in a limp mode and it will run off set tables and not the best it can. It will effect performance and gas mileage
This means engine too cold for too long Mabie your thermostat is stuck open. In other cases, owners just put a 160 degree thermostat (other features).
To clear the code you can disconnect the battery for a few minutes and the light will be off when you start it up again. You could also just drive the truck.
When the PCM runs a certain OBDII monitor and it passes 3 times in a row the light will turn off, if the problem does not reoccur in 255 starts the code will be erased completely. Each monitor can be run at a different time with different driving conditions, all monitors run all by themselves with no input from the driver. In your case if you want the code to clear naturally you will have to drive the truck from a cold start and drive it until it is fully warmed up without shutting it off. You will have to do this and it has to pass 3 times in a row, and on the 4th time you start it the light should be off if it is fixed.
I hope that helped.
Jan 22, 2010 | 2003 Dodge Dakota Club Cab
Garage door openers don,t work.
If by "none of my openers will work" you mean none of your remotes and you have the wall control with 3 buttons you need to press and hold for 3 seconds the button with the lock icon.
Jul 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Forgot my pass code to my apple ipod touch 8g
i entered in my pass code and went on a vacation with out my ipod and forgot my pass code. is their somesort of universal code to enter to unlock my ipod? pllzz help me!!!!!!!!!!
Apr 18, 2009 | Apple iPod touch
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
