Takagi TM1 timing is off on the mixing valve. How do I time the mark on the top of the stem so the temp is not too hot or cold.
reddevil6
  • 1673 Answers
SOURCE: replacing Smart Mix knob
The knob itself will only go in one way, What I was talking about is when you put the top cover back on, the knob should be in the water only position. This way the piston (on the bottom of the knob) will go into the slot correctly.
Posted on Sep 08, 2008
  • 374 Answers
SOURCE: Shaking of the valve D500058BNT Parma Shower, not the pipes
The issue you have is known as water hammer per se. It is the result of water logged air chambers in instances such as yours. The easiest solution is to turn off the water supply to the house and drain the entire system from the lowest point available such as a hose bibb/water spigot. Turn off your electric water heater if applicable as lack of water will burn out the elements. Once this is done turn the water supply back on to the house and bleed the excess air out of each appliance by turning it on and running both hot and cold water until air dissipates. Another cause may be an inadequately secured plumbing system behind the shower itself. The piping should be secured to some cross member to prevent movement caused by water pressure. A special device is made in extreme circumstances and larger systems called a water hammer arrester which does the same job as an air chamber but uses different principles to accomplish the task. I hope this is of assistance to you and thanks for using Fix Ya. If I can be of further assistance please let me know.
Posted on Oct 21, 2008
snap101
  • 117 Answers
SOURCE: grohe shower
if you pull the handle off all the way back to the valve body there is a little black stopper around the cartridge body that you can adjust by pulling it out and sliding around the cartridge body this enables people to just turn the handle to one setting and jumpping in to their favorite temperature. in your case it doesn't allow you to have any cold water. so turn it one way see if you get what you want or try the other or some of them you can even just take the darn thing out and not even have to worry about it
Posted on Jul 29, 2009
SOURCE: My 95 Ford Escort 1.9 timing belt jumped off and I
timing marks on off. need help lining them right. did it twice but each time no power.
Posted on Sep 02, 2009
  • 67 Answers
SOURCE: I bought a Danco 3H-10H/C, Hot/Cold stem. The
One of two things has happened. I'm assuming you only get hot water when you open the valve and that this is for a single handle control shower fixture. If so either this is the wrong valve for your shower control or it is installed backwards. Sometimes the valve can be installed at either 180 degree angles. See if it can be installed any other way. If so this may solve the problem.
Posted on Jul 19, 2010
SS 5060 wont start when hot
Most likely the valve timing needs adjusting. When cold the metals are slightly smaller so the valve timing is just enough to start it. After about 10/15 mins when full engine temp has been reached and the valve stems, cams and seats have all expanded, fully and the valves no longer close fully so compression is lost , (it may then stop) it may keep running through momentum but you may notice a reduction in power. Once stopped it will not restart when hot as the valves will not be closed fully and not allow the fuel to be compressed to combustion.
Oct 05, 2015 | Garden
Tip
Single handle tub mixet hot and cold water valve
if you have a single handle tub valve and it starts to not work properly for instance if its gettin less hot water and more cold water it may be time to replace the mixet stem ,what you will need a flat head screw driver a philips head screw driver a pair of needlenose and a pair of channel locks turn off the water main to your home, remove the handle there is a clip at top remove the keeper clip then pull out the old stem take it to your home depot get a new one also get some stem grease to put around the black rubber o rings so your stem last for a long time the grease is also for the handle turns eazy put back in put clip back just remember how you took old one out so it is in the same position turn water main back on and try it out
on Mar 12, 2010 | Plumbing
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
Heats up the rapidly decreases within in minutes.
Problem new or old? How long you have unit? Sounds like not enough flow to keep burner on. Tankless need at least .6 gpm to keep hot water flowing or else the burner fires then shuts fires then shuts and you get a sandwich effect...hot cold hot cold. If you have new diverter valve in shower -vs- old two handle type try turning hot water ALL the way ON and see if hot stays hot. If it does stay hot then slowly adjust to cool and see if you maintain a good MIX for proper temp. If it goes cold again try this......LOWER control pad setting to a comfortable 105 degrees (ladies) 100 degrees(men) and turn shower valve all the way to HOT. See if your temp remains consistant now and if it does then problem solved. Tankless mindset...set temp on control pad and stop trying to MIX at shower valve. Thats how these things work. Thats why I install a control pad in each bath and one in the kitchen for adjusting ash temp during dishwasher on time. ditto for wash machine. You should never need to turn on cold water if your unit is set to proper temp at controller. Hope this helps
May 17, 2010 | Rheem Tankless Hot Water Heater...
No matter what the temp setting is at it only has very hot water
Your water temp is determined by 2 things. First the hook up to your water supply. If you are able to turn off the hot water valve that feeds the unit and then select a cold water only wash, do you get cold water?? If not then someone hooked up the hoses to 2 hot water feeds. If hot and cold feeds are installed right, the second thing is your computer which monitors the incoming temp through the boards atc control and a thermister. If you select cold, and only get a hum and the cold water valve is on, you may have to clean the screens in the valve of any sediment. If no hum, and no cold, dead solenoid on valve, but that would throw an error code usually. All fills are monitored by the board and usually begin with a hot/wrm mix and then changeover to a monitored cold temp , about 70 degrees.
May 05, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
My shower is running cold water only, the rest of house has hot water
sounds like you have a single lever shower, in this case the valve stem which mixes the hot and cold has a clogged hot side , you'll need to remove and replace the cartridge or valve stem
Sep 12, 2009 | Price Pfister RT6-E0XC/HHL-ELBC/0X6-040...
Washer Fills HOT WATER ONLY
If you checked the screens at the water inlet valve and they were not clogged, then you probably have a defective water inlet valve and will have to replace it. Hope this helped.
Jul 19, 2009 | GE WJSR2070B Top Load Washer
Kenmore top load water temp switch problems and hot water rinse
Hi, Switch the hoses around going to the mixer/inlet valve. I am sure this will take care of the problem.
If not, please let me know so I can assist you further.
Vic
Jul 01, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
