Question about The Clothing Accessories
Pokilinos men's shoe with exterior stiching: the exposed stitching one the front of the toe wears through and the whole shoe comes apart. Where can you fix? And is there a better stitching?
    Habit-Forming:
    New Friend:
  • 13 Answers
Local shoe repair store!
Posted on May 29, 2017
tripletauto
  • 1450 Answers
SOURCE: Driver side toe-in
this would be your camber setting not the toe in. you can adjust the camber by removing shims from upper control arm but this will also affect other angles. best to just have it aligned
Posted on Oct 22, 2008
  • 155 Answers
SOURCE: wear on the inside of front tires
yes there is toe adjustment but no easy caster adjustment. if a front end alignment mechanic said there wasn't ,,, I'd take it elsewhere. I just had my front end aligned on my 99 ram and they did adjust the toe.
Posted on Mar 27, 2010
  • 2309 Answers
SOURCE: I have unusual tyre wear pattern on my Land Rover
blotchy wear is a sign of worn shocks
Posted on Aug 20, 2010
  • 137 Answers
SOURCE: Front end alinement plus toe
Once a wear pattern is set in the tires, it will continue to wear even if the aignment is within spec.
Another contributor could be if you are taking hard turns and rolling the tire over a bit and causing excessive wear on the outside edges. Low pressure makes this even worse. Could that be the cause?
Posted on Oct 03, 2010
  • 1141 Answers
SOURCE: Mens vs. women's shoes.Does anyone know if there
Men shoes are normally in a D width, and women shoes are in a B width. Men narrow shoes are B, women narrow are A.
Posted on Oct 27, 2010
How are shoe sizes calculated?
Every Brand has a different way to design their shoes, you just keep in mind that your foot size is 28cm and relate it according to their size chart.
Jul 21, 2017 | The Clothing Accessories
Trying to find Reebok NPC Insigignia plus men's shoes for men
You will have to find some old stock, as Reebok for some reason stopped making their ORIGINAL classic shoe. Most of the old stock is unusually small sizes, like a 7 1/2, and I've seen some size 13 and 14, but nothing in between for at least 3 years. A similar shoe is available (NPC II), but it is obviously lower quality -- thinner sole, printed rather than stitched heel cap, etc. It has "Reebok" in place of the insignia on the side of the shoe.
Feb 21, 2014 | Reebok NPC Insignia Plus Shoes for Men
I want to ask how can I stitch my shoes together again and clean it
Most shoes are not stiched where yours are coming apart, they are just glued. I would try some super glue or heavy duty epoxy glue. things like normal white glue wood glue or things like that wont work because the area will be constantly flexing. As for a good cleaner just use a good dish soap that says it works on grease/oil, and scrub them in the sink and let them soak for awhile before you rinse them off.
Mar 04, 2013 | Clothing Accessories
I want to repair my caterpillar shoes
Go to a shoe repair shop and they can help you
Feb 04, 2013 | Caterpillar 2nd Shift 6" Toe Boot for Men
I have a pair of Georgia Boots 11" Giant Safety
Do you have a a pair of shoes that you bought not too long ago and the sole is coming apart? If you rather not risk buying another pair of the same shoes only to have them come apart, then this is the article for you.
Difficulty: Easy
Instructions Things You'll Need:
  • superglue
  • shoes to fix
1. 1
Get a tube of super glue--any brand name should do. Just the regular type should do, no need for any extra strength formulas or special types. Make sure the tube has been properly opened at this time--the seal on the tube has had a hole punched in it, in other words.
2.
Get the shoe(s) that need its/their sole(s) fixed. Where the sole is coming apart on the shoe, squirt in a good amount of super glue, but not too much that it will gush out. (If it does, try to wipe off the excess).
3.
Hold the sole and shoe together for the recommended drying time or until they seal. Try not to get any glue on your fingers at this time, as it can stick flesh to other objects.
4.
The sole should be fixed at this time. Sometimes it has to be done over if the drying time hasn't been followed or the glue might have some problem with it. Repeat this procedure for other shoes to be fixed
apply the same proedure for your broken part insted of repacing it
Dec 28, 2010 | Georgia Boot 11" Giant Safety Toe...
Any thoughts on Allen Edmonds Men's Copley Plain Toe Oxford shoe?
Finally gave in and bought my first pair of real shoes. The material and workmanship is excellent and they are comfortable. They look sharp and I've gotten compliments for it. I wear them all day Sundays and other times when a suit is appropriate so I get good use of them. They're very easy to take care of. Just a warm damp cloth will clean them up. No need to ever shine them at all.
Oct 27, 2010 | Adidas Clothing Accessories
How to Buy The Right Shoes for men?
Men's shoes come in a variety of styles and colors. If you're interested in Oxfords and Derbies specifically for formal and informal dress occasions, go here: Mens Shoes How To Wear Oxfords
Oct 27, 2010 | Clothing Accessories
Mens vs. women's shoes.Does anyone know if there are significant differences, other than color, between the men's and women's models of the same shoe?
Are there any general fitting tips I should know of?
Feet tend to expand over the course of a day so it's better to try on shoes in the late afternoon and evening. A tight fitting shoe in the morning can become uncomfortable as the day wears on. Especially if your job or daily activity involves alot of walking or standing.You should also make sure your big toe has around half an inch or a thumb width of space. Otherwise your toes will rub against the material and this will create discomfort and blisters. Just make sure you can extend your toes and wiggle them when trying your shoes on.Also Make sure your wearing your usual pair of socks and not thick hiking socks.
Clothing Accessories Logo
748 people viewed this question
Top The Clothing Accessories Experts
ray gallant
deton8 von Splosion
Are you a The Clothing Accessory Expert? Answer questions, earn points and help others
