I have campingaz catalytic mobile heater,it lights ok but there is a slight smell of gas and it does not get very hot as though it not burning all the gas this happens on all settings.any help ?.
  • 1314 Answers
SOURCE: kitchenaid
advise
Posted on Feb 13, 2008
zeusfaber
  • 247 Answers
SOURCE: A slight burning smell from the fuser region ...
Although a faulty thermistor could be to blame for the fuser running above target temperature, the usual explanation for a slight burning smell is a bit of paper debris stuck inside the fuser, slowly scorching away to nothing.
A.
Posted on Mar 31, 2008
SOURCE: rinnai convector 516TR
Hi This is happening to us and I called Rinnai... they suggested that if anyone either in our apartment or an ajoining one has painted walls or varnished a floor that the convection heater picks up the smell and the only way to get rid of it is to burn it off by running the heater for several hours in a well ventalated room...
I am going to try it tomorrow.
will let you know
Posted on Aug 19, 2008
  • 34 Answers
SOURCE: My catalytic converter gets red hot after 5 min of driving
yes this could be the fault but you would have a light on the dash in the shape of an engine this is the eml light>engine managment light)this is the computer he is talking about unfortunatley yes it could be costlyit has a lot of miles on it hope this helps you
Posted on Apr 01, 2009
co7196
  • 3433 Answers
SOURCE: gas smell during startup of GE hot water heater
yes, provided there is no excessive build up. The gas and air mix must be right before the mixture will ignit. a household stove will do this each time it's turned on. That's why yhe igniter sparkk hits about three times before it lights. proper venting will confine any fumes to the cimbustion chamber to be carried out the exhaust. If the odor is strong then have the appliance checked for safety sake.
Posted on May 06, 2009
Obd light on, idle rough, smell, no throttle
The obd light with tell specifically what it is, is it gas or rotten egg - the latter means catalytic converter, gas smell probably flooded or not firing on one or more cylinders, need more details. Also, if the light is flashing it's warning of catalytic damage - raw fuel hitting the cat, smell could be heat from cat trying to burn off raw fuel,it will glow red hot.
Dec 15, 2013 | Chevrolet Aveo Cars & Trucks
Hotpoint condenser dryer overheating. Heard a loud bang fom dryer then smell of burning. Checked to see if power cable was melting but was ok. The back of the machine was red hot though thanks for any...
1st check see if drum turning if not could be belt.Next heater circuit, check replace thermostats, Make sure filter clean and exhaust ok before above......
Mar 22, 2010 | Dryers
HEATER BURNING OK, UNTIL IT SHUTS OFF AND PILOT GOES OUT
gas valve bad or its getting too hot and shutting the gas off. must have air movement
Dec 24, 2009 | Heating & Cooling
1999 Ford Windstar
Hi, Sounds like the catalytic converter is shot. It needs to go to the shop to have it checked. Best of luck to you!
Feb 09, 2009 | 1999 Ford Windstar
Cozy 351A 35000 btu
You might have a slight odor of gas when the burner first ignites. Some gas does escape before it completely ignites. It shouldn't smell after 2 years of use. If you can see the pilot flame burning from the top of the heater, the heater pilot assembly is pushed over too far. The pilot fumes could be escaping in the room and cause a smell.
Dec 27, 2008 | Cozy Enclosed Front Console Heater 70,000...
Smell of gas while burning
Incomplete combustion could be a major health and safety issue. Seek qualified help and do not use until then.
May 01, 2017 | Empire ECS BF-30 Infra-Red Wall Mounted...
Rinnai convector 516TR
will let you know
Jul 13, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
