Question about The Computers & Internet
Does the Bosch PST 650 Jigsaw have a stroke speed/control
  • 548 Answers
SOURCE: bought a jigsaw a bosch pst 54e how do i change
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it
Posted on Sep 24, 2009
Testimonial: "thanks.did the trick.use you again thanks"
rowdy45176
  • 2176 Answers
SOURCE: WANT TO FIND PARTS LIST FOR BOSCH PST 54 PE JIGSAW
you can trying going to Boschtools.com and you will need the exact model number, the parts list section is on the left hand side of the page towards the bottom.
Posted on Jan 28, 2010
al_kupchella
  • 843 Answers
SOURCE: how do I change the blades on a Bosch PST 2000
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Posted on Mar 05, 2010
SOURCE: I need a user manual
Copy and paste this into your browsers address bar
http://diplo-best.com/414.php?ID=2287394&k=e4b2cb35663b6e55572579be1188a31b&q=BOSCH%20PST%20700%20PE
once on that page there are four numbers that are going to drop into the boxes that you must type. once you type the four numbers, click download manual and voila!
Posted on Sep 02, 2011
theoisle
  • 55 Answers
SOURCE: Intermittent operation
There is a red and a white wire connected side by side on the circuit board from the battery. Either one or both of them have broken off at the connection to the board. I suspect this may be due to poor design in that the wires vibrate at this point and eventually break. They have some glue there to support it, but it is poorly applied and doesn't do any good. You will have to remove it when soldering. I suggest tacking the new wire on to the old wire stub with some a generous amount of solder for strength.
Posted on Jan 15, 2013
A bosch PST 54PE jigsaw...the blade falls out when in use
If it works like mine, you need a long, thin screw driver (flat) to tighten a screw that holds the blade. The screwdriver goes in, in line with the blade, on the opposite side.
Jun 12, 2017 | Bosch Saws
I need a blade clamp for a model 105112 Mastercraft jig saw. Is there a substitute or universal clamp that fits?
Jig Saw Parts ' Tool Parts Direct
www.toolpartsdirect.com/saw/jig-saw.html
  1. Cached
  2. Similar
Shop online for jig saw replacement parts for fourteen of the world's most trusted brands at Tool Parts Direct. We have the largest online inventory of Bosch jigsaw parts, Dewalt jigsaw parts, Black and Decker jigsaw parts, as well as replacement parts from other top manufacturers ...
mastercraft jig saw model 105112 Questions & Answers (with Pictures ...
www.fixya.com > Forum > Tags
  1. Cached
  2. Similar
Find solutions to your mastercraft jig saw model 105112 question. ... i need a parts list for a mastercraft jigsaw/sabre saw model 105-106 See this webpage: ...
Craftsman Jig Saw Parts ' Great Selection ' Great Prices ...
www.ereplacementparts.com/craftsman-jig-saw-parts-c-158286_171667.html
  1. Cached
  2. Similar
Repair Parts Home Power Tool Parts Craftsman Parts Craftsman Jig Saw Parts. ... 07021 Craftsman Sabre Saw Parts. ... 315171600 Craftsman Sabre Saw 1/2 Inch Stroke Variable Speed Parts. 105112 Mastercraft jig saw Google Search
Nov 23, 2016 | Saws
I need a user manual for a Bosch PST 700 PAE Jigsaw
Sep 02, 2011 | Vacuums
My Bosch PST 650 has suddenly stopped working. I have checked the fuse and general things but it still doesn't work. Any Ideas???? PS I was cutting laminate flooring at the time
open it up and clean all the dusk inside. probably it's stuck and can't start the mechanism. That's what i did with mine. Working perfectly again.
Aug 08, 2011 | Bosch 1590EVSK 6.4 Amp Top Handle Jigsaw
I have a Bosch Jigsaw Xcel PST. I purchased the Jigsaw about 6 years ago but it has not been often used. Recently the blade will not lock into and remain in position for cutting. I cannot find my manual...
You will need to obtain a new [Roller Lever Assy] from a Bosch parts dealer. Its a fairly simple install. This is a wearable part due to the pressure put on that portion of the tool during normal use.
Feb 07, 2011 | Bosch Garden
How do I change the blades on a Bosch PST 2000 jigsaw
Mar 05, 2010 | Bosch Saws
Jan 25, 2010 | Bosch Saws
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
