Question about Power Computers & Internet
I have a rm 2862 no lights at all not even door light i check fuses they seemed good it dont workon gas or eletic
It seems to have power to the bord
jsrock516
  • 5911 Answers
SOURCE: Kenmore Elite Dishwasher Problem
The dishwasher should have a thermal fuse mounted to the control board behind the operator console4.gif. It is a small silver colored device4.gif attached to a white plactic bracket. In some model dishwashers the wrong gage wiring was used causing the wires to heat up and trip the thermal fuse. There was no apparent risk of fire or anything like that, but the thermal fuses didn't tolerate the heat differential too well. A fix for the problem was to purchase a thermal fuse replacement kit (found at most appliance repair stores) that had thicker wires. The part number for the thermal fuse kit is 959376 and the price is $16.85. You can find it at repairclinic.com. Order on line and have the part shipped directly to you. Now...to access the control board perform the following:
1. Turn off the main breaker to the dishwasher. This is important. Even though the dishwasher is not running, the control board still has live voltages present.
2. Open dishwasher door and remove the top screws that hold the console in place. You shouldn't have to remove the lower screws unless you plan on removing the entire door panel.
3. The control panel should pull off from the front enough to where you can access the control board. There is a thermal fuse mounted on the board with two wire leads going to it. The fuse is silver in color and mounted to a plastic bracket which is mounted to the control board.
4. Cut the wires on the old fuse and splice the new fuse kit to it. Leave plenty of wire to accommodate. There will be instructions included with your replacement kit. Ensure you follow the direction thoroughly and tighten the wire lug screws securely.
NOTE: Do not attempt to reuse the existing wires by simply unplugging the old fuse and replacing it with the new one (been there). The fuse will eventually blow again. Follow the instructions provided and you can't go wrong.
If you have any further quesitons, or if you run into trouble during your repairs, let me know. Good luck to you.
PS If you do not wish to order on line, take the part number I provided you to any major appliance repair shop4.gif and they SHOULD have the part available. This is a known problem and a common fail item.
Posted on Dec 15, 2007
SOURCE: Front light, tail light and
for the dashboard... have you checked the intensity control? It happened to a friend of mine.
Posted on Aug 02, 2008
SOURCE: Dometic RM2652 or RM2852 not working.
There is a factory recall on these refrigerators. Call Dometic 1800-544-4881 and give them your serial number and model number. Going through the same thing right now. On my Fleetwood Gearbox. Hope that helps. Robert
Posted on Sep 30, 2008
  • 834 Answers
SOURCE: brake lights dont work
Check the brake light switch, it is down on the brake pedal lever, you can dis-connect the wire connector at the brake light switch and check for broken wires at the connector, and then jumper the connector with a paper clip, if the brake lights come on then replace your brake light switch.
There might be more than one switch attached to the brake light pedal lever, the brake light switch usually only has two wires going to it when there are two switches.
If there is no problem with the brake light switch then you can suspect the turn-signal switch to be at fault, as all of the running lights, turn-signals, brake lights, and hazard lights are all ran through the turn-signal switch. You can also try stepping on the brake pedal and wiggle around the turn-signal switch and see if the brake lights flicker or come on.
Posted on Apr 26, 2010
johnjohn2
  • 5763 Answers
SOURCE: brake lights don't work
This sounds like a bad brake light switch, this switch is located on the bracket that holds brake pedal,you can test for power at switch,also if you remove connector and jump terminals with a wire and see if lights lite, if lights light then switch is bad,
Posted on May 27, 2010
Clean Lint Filter Light Keeps Dryer from starting
Evidently the fuse blew for some reason.
Keep the dryer unplugged from power for one hour or so. If it still does start, you will have to take apart the dryer, check the fuse, check the thermal fuse, and test the wirings inside.
If you need to call arepairman use the number listed on the owner manual.
Oct 06, 2008 | Frigidaire FGQ1442ES Gas Dryer
Breakers seem fine, dryer won,t start and light is not lit. ?
There is probably a fuse on the main line somewhere that may have blown. Mostly not resettable but you have to replace. Try following the main wire from where it comes in up to the circuit board and you should see it. Also just to make sure the breaker is good check with a volt meter and make sure you have power coming into the dryer(on an electric two wires would have to be live on gas only one)
Feb 17, 2012 | Dryers
My parking lights,or panel lights dont turn on and my fuse box is # so i dont know what fuse to change i am stranded cant drive
All the marker lights and the dash board and the door switches and even the tag light and the light in the ash tray all light because of this one fuse. Under the steering collum the cover removes with a penny or a quarter and even your bear fingers a quarter unturn. Your problem another fuse correctly installed won't find the short and the new fuse will blow to. If yu use other fuses in the box to replace the lighting fuse the item that does'nt work might cause even more problems. The owners manual for that car is the only good key cause thier wired diffeernly for the different countries that their sold in. I mke a loop of wire and touch the place the fuse goes with the lights turned on if it draws a big spark just strickit and have someone watch to see what lights try to light the ones that don't seem to light remove them and try again, till you unplug or remove the shorted item. Once the problem doesn't draw a spark you can put in a fuse and drive away with some of the lights not working and fix them later. Trailor connectors are good sources of shorts that kill the lights so I check them first.
May 09, 2011 | 2000 Ford Expedition
Car lights and power doors work. when key turned nothing happens not a sound
Please check on your main fuse and look out for any blown fuse. Since your lights and door electrics are working the battery connection and power seems right. If you dont get any indication on your dash then the fuse, the line to the swtich or the harness could be defective. you will need to have a continutity testing of the wires from these points. do it carefully and possible with a voltage check as you must be careful with a continuity tester you might damge the device if there is voltage on line, if not you will have to disconnect and test. I hope this advice helps you out. Good day
Jul 06, 2010 | 2005 Buick Terraza
Brake light dont work. 2006 chevy truck, 4.8L 2wd
Some of these had two fuses for brake lights. One for the top/center stop lamp and another for the rear left and right brake lights. Usually one said "stop" and the other said "brake" and one was in the underhood panel while the other was in the dash fuse panel. It's not uncommon to blow a brake light fuse [LR and RR] if you tow a trailer but some of these had seperate fuses for the trailer lights also. If you have a test light check both sides of the two fuses for power [ignition key on] while stepping on the brakes. It should at lest narrow your search a bit.
Jun 08, 2010 | 2006 Chevrolet Silverado 1500 2WD
I have a Dometic Rm 2862 2-way about five years old.
Ammonia smell means cooling unit is done. Just double check on dometic site in case of any recalls that may apply. (dometicusa.com)
May 24, 2010 | Dometic RM2852 Refrigerator
2005 dometric rm 2852 wont cool
I suggest the main control board is faulty because of the spike. The voltage would have damaged some of the control circuit - even though the fuses did not blow. Sounds like a memory fault on a control chip.
Aug 05, 2009 | Dometic RM2852 Refrigerator
Need Fuse box diagrahm
I don't have the fuse box cover and need to replace the fuses that are missing.
Jun 04, 2008 | 2001 Ford Expedition
Computers & Internet Logo
Top Power Computers & Internet Experts
waruna
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Power Computer and Internet Expert? Answer questions, earn points and help others
