Question about Garden
I need real life application of lever,wheel and axle, inclined plane,screw and pulley
2 Suggested Answers
  • 95 Answers
SOURCE: My dad is replacing the rear wheel barrings on his 2005 Ford Explorer , does he need a axle pulley to do the job.? Some sites say yes some say no? He has it almost off but , not all the way ? Can We u
it's been my experience that a socket and ratchet only works it it comes off smoothly, not often. a puller is the best way to go especially if it is hard to remove,usually.
Posted on Nov 16, 2011
Husqvarna Model YTH24K48, won't move forward or reverse.
I will try to give you all information needed to fix the tractor. The first question is have you removed the rear wheels. The rear wheels have a square axle key that drive them. I have provided you with an image below showing the placement of the axle key.
If the axle key is in position, the next check to make is if the drive belt is still on. With the tractor on a level surfaced and the engine off look under the tractor at the drive belt. The belt should be free of slack and go around all of the pulleys.
If the belt is fine put the tractor in neutral and try to push it. If you can push the mower, you know the brake is not the problem. If you can not push the tractor the problem is likely a stuck brake. You will need to mover the break lever on the transaxle to see if it is sticking. If it is stuck you should be able to free it up by spraying a little WD-40 on the brake lever. Then work it back and forth.
Your tractor has a hydrostatic transaxle, I recommend you try to purge the air out of the system. The purging instructions can be found in your owner's manual and I have posed them below.
Next check the brake lever on the transaxle. If it has been sitting for a long period of time it might be stuck on. The lever is located on the right side of the tractor inside of the frame. I recommend working the lever back and forth to make sure it is moving freely.
When you are looking under the tractor, have someone move the shifter. When the shifter is moved, you should see the shifter on the transaxle move. If the shifter is properly attached, have someone start the tractor and let out on the brake. Now carefully look under the tractor at the Trans axle drive pulley. The drive pulley should be spinning. If the pulley is spinning, the problem is most likely a defective transaxle.
Oct 20, 2016 | Husqvarna Garden
I have a 20" inch girls kent trouble bike. How do I take the rear wheel off?
remove the coaster brake lever bolt. This is small bolt that holds the coaster brake lever to the left side chain stay. There will probably be a strap wrapped around the chain stay with bolt going through the strap and the lever. This usually requires a 10mm wrench (sometimes it is 8mm) for the nut and a Phillips or flat head screw driver (some times it's another 10mm bolt head).
The axle nuts are usually 15mm nuts. Loosen these (they usually don't need to be removed all the way) and push the wheel forward to put some slack in the chain. Lift the chain off the rear cog and you will be able to pull the wheel out of the drop outs.
To install, slide the wheel into the dropouts, put the chain back on the cog, pull back on the wheel and tighten the nuts finger tight. Reinstall the bolt through the coaster brake lever and then tighten the axle nuts, pull back on the wheel while tightening the nuts so the chain is tight. Then tighten up the coaster brake lever bolt. (if you tighten the axle nuts first, you won't be able to move the coaster brake lever into place to get the bolt in)
Aug 18, 2014 | Cycling
Hi Brenda,
This machine makes use of two levers on the handle. The right controls the drive and the left controls the auger. When both are released, the drive wheels and the auger should stop. The impeller (the part inside that pushes snow up and out of the chute) will run as long as the motor is running and not controlled by the levers.
You said the auger continues to spin even when the lever is released. Both levers are connected by a flexible, thin, steel cable that extends down to a "wheel" or pulley assembly that is held in place by two hex nut bolts to the rear (operator position) corners of the machine. The steel cable should be ON the wheel - not hanging in free air and not wedged between the pulley and pulley support. Loosening the bolts and adjusting the pulley UPWARD should reduce tension / provide SLACK required to disengage the auger when the lever is released (adjust for a *small* amount of slack only). Positioning the pulley DOWNWARD increases tension that reduces the amount travel the lever needs to ENGAGE the auger. The pulley assembly position needs to be adjusted so that when the lever is released, the auger shuts off, and when squeezed, the auger turns on. These same adjustment procedures can be used for the DRIVE lever control, too.
If you are unable to adjust the cable so that there is a little slack, then there is a problem with the cable at the other end - inside the machine. It will require someone who is mechanically inclined - or snow blower serviceman to adjust / repair this for you if you lack the tools and understanding to do the work yourself. It is not likely to be an expensive repair, however. You should ask for an estimate or be given the opportunity to authorize repairs before they are started.
I hope this helps and good luck!
Mar 23, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Adjust drive belt
You didn't say what MODEL YEAR (yes, it makes a difference!), but here's a generic how-to.
Get rear wheel off ground.
Loosen jam nuts on axle adjusters (if they have one, varies by year).
Turn adjusters equal number of turns until belt tension is correct (belt deflexes 1" with 10 lbs pressure in center of top run).
Tighten jam nuts (if applicable).
Turn rear wheel in normal direction of rotation.
Check to ensure belt is running centered in rear pulley.
If not, tighten the axle adjuster on the side that the belt is pulling towards (if belt is to right side of pulley, tighten right adjuster to move right side of axle aft).
Oct 09, 2013 | Harley Davidson XL 1200 C Sportster Custom...
The screw to used to move the frog to adjust the throat is missing. Can I get a replacement? Is there another part of the adjustment assembly missing?
Auctions and search engines.
Some plane Mfgs. had custom threads made. Modern bolts and screws from the hardware store may not work. Take the plane to a genuine hardware store where someone will help.
There are typically 2 slotted machine screws that secure a frog to the plane.
The plane will work fine without the slotted frog adjustment screw near the brass thumb wheel.
Really old metal planes had no frog adjustment screws.
The new frog adjustment feature did boost sales though.
If the threaded bolt for the brass thumb wheel is missing it will need to be replaced so the cutter can be easily adjusted.
Jan 20, 2011 | Fulton Tools & Hardware - Others
How do I set car to be on 4x4?
I believe that Mitsubishi has one of the best and easiest 4X4 selector systems on the Pajero/ Montero. Just below the gear shifter lever is the 4X4 mode selector. A lever like the gear shifter that works in a up, down movement. On your dash board you will notice a sort of axle, chassis diagram in green light. In normal 2WD or 2H mode the lever is set all the way back and on the dash only the rear wheels a lite up in green light on the axle, chassis diagram. This is for normal driving on the highway and smooth roads of dry dirt roads. Pushing the lever up wards while moving at crawling speed will engage the light 4X4 mode which is 4H for when the driving gets a little slippery. All 4 wheels on the axle/ chassis diagram will be lite green. Shifting the lever from the 4H position to the left and upwards will engage the 4HLc mode for 4X4 on sand and deep snow. This will also engage the central diff lock which will show on the axle/ chassis diagram on the dash board with the center box also lite up. Further up from the 4HLc mode and while pushing down on the 4X4 lever push it to the top most position, but only do this when at a stand still with your foot on the brake pedal. This will engage the 4LLc mode with 4X4 and central diff lock on for when driving gets sweaty on thick mud up and incline. To disengage this mode stop, foot on break put it in P and then pull down the lever to one of the lower settings.
Jan 13, 2011 | 1997 Mitsubishi Montero
Troy-built 21" mower - self propel problem. From my research it seems like a manufacturer problem that was availiable thru a claim but I am the 2nd owner so I must fix myself. Its a model 834. I have...
do you have the complete model number from the data tag on the mower frame? there are two typical systems for these machines, both require the belt to be tight and not slipping at the crank shaft, and the pulley on the trans-axle to not be slipping on its shaft, the older style trans axle uses a belt tensioner system to tighten the belt and turn the pulley, i.e. if the pulley turns then the axle should too. this can be checked by hand with the axle and belt removed. the second system is a clutch style axle that has a constantly tight belt and uses a small cable controlled lever on the transmission housing to engage a drive clutch inside the transaxle, if moving the lever forward doesn't cause the axle to turn as the pulley and shaft are turning the clutch mechanism is usually toast. with both of these systems one should also note whether the axle is turning inside the wheels when they are on the ground, the over running clutch sprags inside the drive gears could be stuck causing the wheels to turn without resistance applied, but stall when in contact with the ground.
while inspecting the trans axle note any wobble or free play in the axles or input shaft, this will indicate a worn case or bearing, resulting in a slipping gear in the trans axle.
Jul 01, 2010 | Troy Bilt 5.5hp Self Propelled Mower
How do I replace axels on a Hyundai Sonata 03
these are relatively easy to replace. you will need to remove wheels, axle nut in the centre, look underneath and remove the 3 lower ball joint fasteners, outer tie rods, and for someone who has not done these before, remove the struts bolts, but be sure to mark the spindle so it can go back exactly or you will screw with the alignment(camber), move the spindle out of the way not allowing to hang by the brake line. take a small prybar and place between the transmission and axle joint and it should "pop" right out. it would be best if you had a friend who was mechanically inclined to assist. be sure to use jack stands and be safe. on the install make sure that axle nut gets tightened properly or it can cause some real damage.
Nov 08, 2009 | 2001 Hyundai Sonata
Dryer making a crazy noise
Hello, shhllc,
The problem is with one of three pulleys. There are two "drum rollers" on which the dryer drum rests, and then there is a third pulley which keeps tension on the belt that connects the motor to the drum. Either of these can get squeaky when the grease dries out, or when they wear from prolonged use.To open this dryer, remove the front panel (either 4 screws inside the hinge mounts on both sides, or 2 screws along the bottom of the front panel) and check with a flashlight to find these three pulleys. With the dryer unplugged, jiggle each one... if it is loose from its axle, it needs replacing, otherwise, just lube all three pulleys by removing the retainer clip and wheel, greasing the steel axle with silicone (never use oil!), then replace the wheel and clip. You should enjoy blissful silence from there.
May 06, 2008 | Maytag Neptune MDE5500AY Electric Dryer
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
