Question about The Office Equipment & Supplies
How do I get my printer to use the BK ink cartridge and not the PBK cartridge?
The PBK is empty and I just want it to use the the full BK cartridge
  • The Master
  • 10,028 Answers
Try setting the printer to print in B/W or gray scale in the printer setup on your computer.
Posted on May 04, 2017
jackboy
  • 2985 Answers
SOURCE: Printer will not print.
http://www.fixya.com/support/p169991-brother_mfc_420cn_all_in_one_inkjet See if any of these solutions help
Posted on May 17, 2007
  • 286 Answers
SOURCE: Screen reads "Near empty Cyan" but I just replaced the Cyan ink cartridge, its full.
If the firmware update doesn't work, you can reset this error.
Unplug unit. Remove offending cartridge. Plug unit back in, wait until all startup noises have stopped. Open lid and reinstall cartridge. This will solve the fault as long as the sensor is working.
Also, please be aware, you should not have to change a cartridge if it says "Near Empty", only if it says "Ink Empty Magenta".
Also, please make sure none of your other cartridges are empty. I have seen this over and over. Two cartridges empty at the same time, and the person replaces one of them but thinks they actually replaced the other one.
Turn the power off and pull all the cartridges out. Look a the side of the cartridge, you should see a window with a little plastic tab sticking out. This tab should be blocked by a black float inside the cartridge. If you cannot see the float, and the tab is clear with no ink in it and no float tab blocking it, it means the cartridge is empty even if you still see some ink in the bottom.
To be sure plug the machine in without any cartridges. When all the noises have stopped, open the lid and install the cartridges. If you're still getting an error saying either a cartridge is not installed or is empty, then one of your cartridges is empty. Redo the previous paragraph.
Posted on Dec 30, 2007
old marine
  • 2036 Answers
SOURCE: Black ink
The PGBK cartridge is a pigment black ink, while the others use a dye for coloration. The pigment black is used when printing text and other documents. The dye ink is used when printing photos and other colored documents. The dye black is used in conjunction with the color (dye) inks to provide tinting and color gradation, and therefore is not used nearly as much as the pigment black unless you use your printer only for printing photos.
If you're printing text and documents, you will need to buy another pigment black (PGBK) cartridge.
Posted on Oct 14, 2008
dnewcombe1
  • 1564 Answers
SOURCE: Printer thinks cartridges empty
Unplug your printer from the computer and then the power supply. Remove the inks from the printer. Plug the printer back into the computer first then connect the power supply. Install the inks "very slowly" one by one and then check the levels, they should now read full. Thank you, Dana
Posted on Nov 06, 2009
Testimonial: "You have just saved me sooo much time and money!Thank you."
  • 146 Answers
SOURCE: Printer does not print using black ink
Check your settings i=under the Services Toolbox. Also go into printer preferences and see if you can force it to print in black only.
Posted on Apr 26, 2010
No Cartridges. Open Scanner cover, then reinstall ink cartridge. All Cartridges are full
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty.
To make sure about the real issue unplug the mach from the power outlet then plug it back in after 10 seconds.
If the display show: "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace. If the display shows "ink empty Y" it means that yellow needs to be replace.
Even if it looks like the cartridge is full, it really needs to be replace so that the machine will work again.
Hope this helps. Rate if it works. Thanks
May 05, 2011 | Brother MFC 210C All-In-One InkJet Printer
I just changed my yellow ink and printer is still saying no cartilage need to replace
No Cartridge will show on the display if the machine cannot recognize one of the cartridge or one of the ink is empty. Try to unplug the mach from the power outlet then plug it back in after 10 seconds. If the display show "ink empty C" it means the cyan/blue needs to be replace. "ink empty M" it means the magenta/pink needs to be replace. "ink empty BK" it means that the black needs to replace.
May 03, 2011 | Brother MFC 240C All-In-One InkJet Printer
False error empty cartridge
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Jun 01, 2009 | HP Photosmart C6280 Printer
Only black cartridge empty, but 3 full color crtrige say empty
Remove the color cartridges. On one end you can see the opaque
ink tank inside the main cart. housing. Cut a piece of black electrical
tape to fit around the three sides visible of the ink tank. Make sure the tape fits inside the housing and adheres to the tank itself. This makes the printer think your ink is always full but you can always tell when you need to refill/replace the ink(right?). Good Luck!
Dec 27, 2008 | Brother MFC-440CN InkJet Printer
Black ink
Oct 13, 2008 | Canon MP610 Photo All-In-One Printer
DCP 117C Brother ink jet printer: Although ink cartridge is filled, is showing black nearly empty error message. No black is getting through on test printing after head cleaning procedure.
two diffrent errors:
1. near empty. I guess your cart is at full level.: Take cart out. unplug dcp from power. leave scanner open. replug to power. machine will come up and demanding cart. insert cart. close cover. answer display if its changed!
2. press menu then start bk-copy then four times arrow up. machine will be in maintenance mode. press by help of arrow-up and set: 7 (set) 6 (set) 3 (set) start bk-copy. machine will do a power purge cleaning. when finished press 9 (set) 9 to leave maintenance mode. run a test print and set date/time again!
Apr 06, 2008 | Brother MFC-5840CN All-In-One InkJet...
Instructions on refilling cartridge for brother LC41CL cartridge
Do mix the ink with some glycerol to prevent clogging!
2ml glycerol (85%-glycerin alc. from drugstore) with 10ml of ink for C/Y/M and shake well (mix) before use. Mix 1,5 ml glycerol with 20ml BK ink.
Simply drill a hole into the brandname (O of brother) on top of the cart. Refill with 12ml for C/Y/M and about 21ml for bk.
You can leave the hole open.
Next time when cart is empty simply open scanner and refill without taking the cart out! ;-)
DO MIX THE INK WITH GLYCEROL!!!
Apr 03, 2008 | Brother MFC-5440CN All-In-One InkJet...
Can't print when there's only black ink
Mostly it connot print w/out color ink if when printer message empty / sometimes the printer no message while ink was empty still black can print. it depends to the chip .
Jan 11, 2008 | Xerox DocuPrint M750 InkJet Printer
Prints header and footer but nothing in between
Make sure that the carts are FULL, placed well and are secured!
press menu then start bk copy then fourtimes arrow-up-button.
machine will be in maintenance mode. press 7 then 6 then 4 then start bk copy. machine will initialize the carts and refresh ink in tubes and the ph. leave the maintenance mode when finished by pressing 9 then 9.
Run a quality test print.
If you still cant see any bk this might be because of generic ink which had clogged the bk channel. this cant be fixed anymore!
Jan 03, 2008 | Brother MFC 420CN All-In-One InkJet...
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
