Question about The Health & Beauty
Wristech blood presure monitor. I don't know how to set the time or date.
SOURCE: Setting Date & Time
With the power off press "Digit". Month is blinking press "Set" for correct month. Next press of "Digit" will give you Day, Hour, and then Minutes.
Posted on May 10, 2009
SOURCE: How do I change the time & date on Lumiscope
My husband found the manual elsewhere on the web at http://www.manualsonline.com/
Posted on Oct 10, 2009
SOURCE: I NEED THE MANUAL OR INSTRUCTIONS FOR THE CVS BLOOD PRESSURE
Press Set Time/.Date button and hold down for several seconds. When you let go number - year - will start flashing. Use MEMORY button slowly to correct year. Push Set Time/Date button to set year. Next number will be month - same process. Then date - same process. Then time beginning at midnight using 12 hour clock - same process.
Posted on Mar 15, 2010
SOURCE: How do you set the time and date on a Welby Wrist
I was able to do this by 1st pushing and holding the M button and then pushing and holding the on button and holding both for 3-4 sec. Once released you will see the month flashing. change by pushing the M key to desired month then toggle to day etc with the on button
Posted on Oct 07, 2010
thetaz001
SOURCE: i got a wristech jb5538,i
i got a wristech jb5538,i don;t have a manuel,can;t find 1 online.i need to know how to switch between kpa and mmhg.
the solution is when the unit is off, press and hold the left (<) button
until you see a kpa or mmhg in the display.
release then press and hold the same (<) button to choose between
kpa and mmhg .
press the start stop button to start measuring.
I also requested a manual from
info@jobar.com they sent me one.
Posted on Feb 16, 2012
Tip
Truly/Accuread DB61M Blood Pressure Monitor - how to set date and time
I found how to set the date and time on my Truly DB61M blood pressure monitor by trial and error. I suspect other Truly BP monitors do it a similar way. These monitors also seem to go under the name Accuread. It's a pity they don't make manuals readily available online.
Here's how you do it:
1. Put the monitor into the date/time setting mode by holding down the MEMO and AVG buttons together for several seconds, then release.
2. The YEAR will be displayed flashing at the top right of the display. Press the PAGE button to move through the years to the one you want.
3. Press the AVG key to move to the next field, which is the month, flashing on the left. As with the year, used the PAGE button to move through the months to the one you want.
4. Following the same procedure, set the day of the month, the hours and minutes. The monitor knows how many days are in each month, so you can't set eg 31 February.
5. To finish, press the START button (the one on the right with the red marking).
There seem to be some other settings as well as the date/time that come up if you keep pressing the AVG button, but I don't know what they are.
on Feb 13, 2014 | Truly Health & Beauty
Wristech blood presure monitor not working
My advice here is simple. Do You have the original receipt? If so then take it back, or call the Manufacturer with this problem Roy. For every model has a limit on how long it works. Did You check the batteries, and were they new and fully charged when You put them into the blood pressure monitor. Always check the Batteries first. Plus always keep the receipt so that you can get a refund within the time allowed for that. The information paperwork that comes with the monitor also will have information on how to get this monitor fixed or repaired. Look for it, and the 1-800-# with it to get your questions answered by the makers. This is what I and other have to do. Good Luck.
May 05, 2017 | Health & Beauty
I got a wristech jb5538,i don;t have a manuel,can;t find 1 online.i need to know how to switch between kpa and mmhg
kpa and mmhg .
Aug 10, 2011 | Asseenontvguys Wristech Blood Pressure...
I purchase a Wristech blood pressure band but I do not understand the reading such 132 sys/88 DIA & 90 PUL /min could you tell me what that mean?
I bought a wristech blood pression monitor its not working IT takes my blood pression very low. 74/64. I know my blood pression isnn't that low, is there something wrong with this monitor. Deb
Dec 18, 2010 | RTO WrisTech Blood Pressure & Pulse...
My wristech bp moniter will only pump up to 08 and then it displays the error message, what's wrong with it?
You need to make sure that the bp is RIGHT over the pulse point, that is the only way for them to read. they are great little items, but I prefer the arm cuff, have used them for 15 years on all my patients, the reading seems to me to be more steady and accurate. but, I know you already have to wrist, so please check the locations that you are placing it on your wrist. Please write back should you need more info, would love to make sure you are on schedule..... Guy
Sep 08, 2010 | Asseenontvguys Wristech Blood Pressure...
How do I reset my monitor clear the deck wipe it clean as if it was new? wristech model ZSBP-002
Press both the memory and on/off buttons at the same time. Hold for a couple seconds and monitor will reset.
Dec 08, 2009 | RTO WrisTech Blood Pressure & Pulse...
Health & Beauty Logo
24 people viewed this question
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
