Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony kv35s66: No picture, just sound and red blinking
We've had the Sony Trinitron kv35s66 for about 5 or 6 years; manufactured in 1999. Sometimes the picture goes out leaving the screen black, but there is sound. Usually, before going out, the screen picture starts having horizontal lines, the screen picture gets shorter and shorter (the width is fine), and then sometimes it goes to black. There is no red blinking light after it has been on for awhile. Sometimes it comes on just fine. Other times when we turn the tv on, the red light flashes over and over, the screen stays black but we have sound. We always have sound. Sometime the picture will just come on. It may be right away or sometimes it's 10 minutes or longer, or the picture won't come on at all. We have unplugged it from our APC battery backup/surge protector unit and plugged directly into an wall outlet. We have reset the power many times. We can't afford a new TV right now, so we are wondering if this is a quick fix, or will we need to toss this out.
  • 6 more comments
  • Anonymous Nov 25, 2007
    tv turns on but no picture
  • carmar Dec 14, 2007
    Sony kv35s66 sound but no picture. Sometimes picture comes on for a short while then goes out. Developes static lines and then picture goes to top af screen and goes out.This TV has been used very little since it was new.
  • Anonymous Jan 03, 2008
    Sony KV-35s66-The set has always had sound, but a delay in picture when you turn it on.
    Recently, after about 40,000 hours of use, the delay has increased.
    Now, the delay is over a minute and a half long, with the standby/timer light at the bottom of the set flashing the entire time.
    Then the picture comes on, and the standby/timer light goes out, but the picture flashes on and off for about five minutes before locking on for the rest of the day. It appears to be resetting, because the channel display appears on screen each time the picture comes on.
    With this many hours on the set, and what appears to be a weak picture, I'm reluctant to put money into it. However, I guess it might be possible that whatever is causing the malfunction, might also be diminishing the clarity of the picture.
    Please Help!
  • Anonymous Aug 16, 2008
    PICTURES GOES BLACK WITH VIDEO 2 IN GREEN IN THE THE UPPER LEFT HAND CORNER.
  • kwan16 Jan 21, 2009
  • djshaw01 Feb 01, 2009
    Anyone have luck with soldering?
  • Anonymous Mar 15, 2009
    The sony Trinitron turned itself off and won't come back on. There is a red blinking light at the bottom near 'timer,standby'. We are hooked to cable and the cable is fine. Can anyone tell me how to get the tv back on?
  • Anonymous Mar 27, 2014
    picture blinks on and off. sound comes through just fine. red light in front of t.v. blinks off and on 5 times.
  • 29 Answers
The most common problem (I have fixed lots) is the Vertical amplifier has developed a loose connection. It probably just needs resoldering. As things expand it makes and looses connection you picture goes in and out. The vertical chip is a large black chip that gets hot, over time it degrades the solder until a connection is damaged. Most newer sets have a protection circuit that senses the lack of height, and shuts down the picture tube to save it. When the picture dropped to a line on older TVs and left that way too long it would burn a line into the face of the picture tube. You then had to have the picture tube replaced along with the vertical amp. it's kinda like a screensaver for your TV.
Posted on Feb 02, 2008
Blinking/standby timer
Sony Trinitron TV. Worked well last evening. Now picture won't go on. When power is turned on, standby/timer red light flashes, but picture or sound does not work.
Jul 01, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
My sony kd32fs130 red light blinks 5 times
your video circuit is not working that is why you are not getting picture
Jan 29, 2009 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Blank picture, good sound, 5 red blinks?
I have a Phillips Universal Remote Control and I'm looking for the code library
Jan 29, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony Trinitron KV 27
Please count the blinks and post that number. That is an internal diagnostic code that will indicate the problem circuit. From that I can give you probable repair parts and costs.
Thanks,
Dan
Dec 24, 2008 | Sony FD Trinitron WEGA KV-32FS100 32" TV
This should be a quick fix. Try resoldering the vertical IC. This is a small flat IC attached to a heat sink with about 11 pins. It should be marked LA7837 or something similar. That should resolve the problem.
Keep us posted.
Dan
Sep 08, 2008 | Televison & Video
Sony Trinitron blank tv/no picture
When I turn on the TV I hear the click sound and the TV powers up. Immediatly the red (standby) light begins to flash 6 times on and off. this happenes only in the morning, but after 5:00PM when youturn on the TV as if nothing is wrong.
what is the problem?
Feb 08, 2008 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Sony KV-32FS120 No picture, No sounds, 5 red blinks after turned on
your problem is in power supply section in your tv. if it is ok check for h/output section. call skilled tech to fix it it is not a major problem.
Sep 28, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
816 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
