Question about Crosley Audio Players & Recorders
I just bought a used crosley turntable model cr6019a and the power light won't turn on, when i turn the knob it doesn't click, is there any way i can fix this ? or would the company be able to help ?
  • Crosley Master
  • 5,056 Answers
It sounds like the power switch might have broken.
Crosley might help you find a service centre, but since you didn't purchase it direct from them, that's all they will tell you.
Posted on May 06, 2017
5 Suggested Answers
CompuGuy44
  • 432 Answers
SOURCE: Suitcase Turntable stopped turning
It you hear the motor spin and nothing is moving, the belt could be broken.
Posted on Jul 07, 2007
canwoodjc
  • 3301 Answers
SOURCE: we just got a crosley
remove the rubber plate at the top of the record player,, under that is a metal plate, in that plate is a large "sight hole" look in that as you turn the plate around,, look for the belt that has fallen off the motor shaft and the plate itself,, if you can't locate it, there is a spring clip at the base of the post that holds the metal plate on, remove that , you will see the motor shaft, and the ridge on the underside of the metal plate that the belt has to be on, they sometimes fall off in shipping,
Posted on Sep 07, 2011
dennis_w47427
  • 232 Answers
SOURCE: I got my crosley record player yesterday and I
Hi A Soni...word of advice...if this a new unit DO NOT attempt
to fix the problem yourself...you may void any warranty attached
to the product. Call Customer Support 1 866 Crosley.
Regards,
Dennis
Posted on Oct 05, 2014
  • 884 Answers
SOURCE: Crosley CR6019A turntable skips
Hi
Being a portable model, it is very easy not to have the turntable level. It is very important that it is level as a tilt can lead to the head "skipping", amongst other things.
You can get a full User Guide here
http://0bee184f253cf7f48610-d2b1caba160808a264f409f8f32a9b54.r0.cf3.rackcdn.com/Crosley%20CR6019A%20%20Executive%20Turntable.pdf
Another possible problem is that the balance has become upset by being moved around. The correct balance is achieved b the positioning of a weight on the tone arm on the opposite end to the needle. This can usually be moved short distances to balance the tone arm so that the needle is held in the record groove, by the minimum necessary weight on the needle.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Posted on Dec 26, 2014
Hi
Cheers
Dec 26, 2014 | Audio Players & Recorders
I got my crosley record player yesterday and I tried turning it on today and the knob doesn't click like it's supposed to. Consequently the power light doesn't turn red and the turntable doesn't spin....
Regards,
Dennis
Oct 05, 2014 | Audio Players & Recorders
Want to connect and play Crosley Executive CR6019A
You have to get a program for your computer to use with Crosley. Unfortunately, there is none.
Jun 10, 2014 | Crosley Audio Players & Recorders
Crosley turntable
The Crosley CR6019A Executive USB Portable Turntable is sold in the USA, so I would say it is a 120 volt machine, however, it does have a small AC adapter, from 120 volts to whatever the voltage the machine uses.
Apr 27, 2014 | Audio Players & Recorders
Crosely won't play usb
If it's a turntable with a usb connector, those connections are usually outputs only. USB on a turntable is used to output the audio to a computer to rip albums to digital audio.
Jun 17, 2013 | Crosley Audio Players & Recorders
Power is on, turntable won't turn
Hi, sounds like the belt was not refitted when the motor was replaced.
To replace drive belt on a Crosley turntable.
1. Remove the cir-clip holding the platter in place from the base of the centre spindle.
2. Lift the platter off. You may need to use a flat blade or some similar tool to get under the platter in order to lift it up.
3. NA.
4. Place the belt around the platter pulley making sure it is sitting flat without any twists.
5. Flip platter over the right way up
6. You will see 3 rubber grommets in the platter surface. Remove 1. Through the hole insert a belt hook, crochet hook, kebab skewer, knitting needle type tool and slip it
between the platter pulley and belt in readiness to fit over the motor pulley.
Nov 15, 2011 | Crosley CR249TA Turntable
Purchased product last month. It worked for a few days and then the volume would not function properly---stays at low volume even if knob turned all the way up.
You should return to the place you bought it. You are entitled to a replacement or your money back. Any problems contact Crosley.
Jan 12, 2011 | Crosley 0187SST Turntable
Crosley Record Player Stopped Spinning...
I had this same problem with my Crosley 704 and it bamboozled me to no end.
After digging around I dug up the manual online (I bought mine used so I didn't have one to consult). It turns out the record stops when it gets to the end, and to get it spinning again you have to lift up the tone arm and move it right (past the holding latch) until it clicks, and voila, it starts spinning again, ready for a new record.
You'd think that they coulda made it more obvious :(
Jan 12, 2010 | Crosley Audio Players & Recorders
I always get static when adjusting the volume of my Crosley CR73, and sometimes the volume doesn't change smoothly and sometimes, I think, one channel stops working completely.
sounds like you have a dust build up on your volume switch? buy some electrical contact spray ( aerosol type ) remove the switch/knob........just pull it towards you, remove the knob and spray a bit......not too much and refit the knob and twiddle it about with the power off and then try it? repeat if necessary? good luck.
Sep 27, 2009 | Crosley Conductor CR73 Turntable
52 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
