Question about Ovens
A 60CM STATIC OVEN MODEL NUMBER CL605W. THE COOLING FAN IS COMING ON 15 MINUTES DURING COOKING AND IS SO LOUD. ONLY WAY TO STOP IT IS TURN OFF AT WALL AND RESTART. WHY IS THIS DOING THAT
  • 1462 Answers
SOURCE: B3101 AEG oven cuts out after approx. 15 minutes - why?
this is probably the thermal cut-out causing the problem. not sure where it is located but possibly on the roof of the oven or in the rear casing near the fan. however, the cause may be lack of ventilation to the unit as a whole
Posted on Mar 26, 2007
melnavz
  • 1226 Answers
SOURCE: smeg electric oven timer controls
first is unplug the the oven from the wall outlet, to hard reset the setting. wait for almost 20 minutes then plug it again.
please tell me if there is still problem after this, melnavz
Posted on Apr 10, 2008
  • 200 Answers
SOURCE: Fan rattling in Hotpoint BS41 oven
Hi
Check this link
http://repair2000.com/oven.html
Posted on Sep 16, 2008
kachbibi1
  • 979 Answers
SOURCE: NEFF OVEN PROBLEM - SMOKE AND FUMES COMING OUT OF OVEN
Take the cover off that is surrounding the fan and you will probably find food or something there or on the fan blades. If it is not a food smell, then there is probably some wiring that is burning. I suspect that there is food behind the housing of the fan.
Posted on Feb 02, 2009
  • 56 Answers
SOURCE: i have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Posted on Jun 30, 2009
Owen fan always run, after plug owen in. How to stop it or reset it?
Your Fan thermostat has failed, now the cooling fan will run forever trying to cool the broken part... Look for the thermostat in the wiring diagram that is with the oven, meter it for continuity, and if it fails, use the model number to order a new part from a local part store- your model number represents nothing here in America or I would tell you the part #! Range Stove Oven Thermostat 318578506
Jun 25, 2016 | Electrolux EOB6630 Ultrafan Electric...
My oven fan has recently started to make a very loud rattling noise for around 30 seconds once every few minutes while the oven is turned on in fan mode.
The fan needs be cleaned and lubricated. To do this: Turn off stove/oven. Remove fan cover plate. Remove fan. Clean and lubricate the shaft bearings with 3 way oil. Install fan and cover plate.
May 16, 2016 | Smeg Ovens
Jenn-Air Maytag double wall oven makes loud buzzing noise
There is a cooling fan for upper and lower oven they run at the same time no matter which oven in use it is fed from the oven manager no way to trouble shoot without pulling oven out some models use same fan for both so you could have a blower on hand remove back panels to access fans take a lead off fan to determine which one noisey
Feb 03, 2015 | Jenn-Air Ovens
How do I replace the fan in a Fisher & Paykel 60cm oven
ill assume your referring to the cooking fan you see inside the oven and not the outer cooling fan, you will need to turn the breaker off outside to cut power to the oven then you will have to take the oven out of the wall and remove the back cover then its normally just 3 screws and the nut on the inside of the oven that holds the fan blade on (which is reverse threaded by the way) and it should come out
Sep 27, 2014 | Fisher and Paykel Ovens
My Zanussi double oven switches off during the cooking period.
If it turns off after it has been on a while, then it could be caused by overheating due to failure of the external cooling fan.
The fan is designed to prevent the oven overheating, and failure of the fan causes a safety thermostat to operate and stops the oven from working.
You need to access the fan to check that it is working.
It is usually located at the top of the oven at the rear, and entails removing the top cover and the back cover possibly depending on the model number.
What you are looking for is a cylindrical type fan about 8" to 12" long, again depending on model.
Hope this helps solve your problem.
If you requies any nore info, please e-mail.
Dec 23, 2010 | Zanussi Ovens
This oven has always had a loud fan noise when it was on or during cooling off. A couple of times lately I have turned it on and it has only had a quiet hum. I've turned it off and turned it back on a few...
Anonymous, we're sorry for the inconvenience. We would like to discuss this further with you. Please email us at Whirlpool_Reviews@Whirlpool.com at your earliest convenience with your name, address, a phone number and best time to reach you along with your model and serial number.
Oct 21, 2017 | Whirlpool GMC305PRS Stainless Steel...
COOLING FAN DOES NOT STOP AFTER HOURS
Hi I am Vortash the cooling fan must be controlled by a thermostat , it appears that it has a problem on it and is not shutting off .
They are usually normally open contact switches that are on the top or the side of the oven ,they heat up close the connection and turn the fan on . yours sounds as if it is sticking . Other ovens are controlled by a rheostat a long tubed thermostat that goes to a main control consul on the oven , it controls the fan and responds to what the stat tells it .
It may be this controller is not turning the fan off afterwards , my suggestion is that unless you are electrically trained you get the help of a service engineer to check your oven out .... regards Vortash
Jun 15, 2009 | GE Profile JT912 Electric Single Oven
Fan making loud noise
Hi
does the noise start as soon as you turn the fan oven on?
does the noise stop as you turn off?
just depending what make and model you have there is two fans
in it 1 is the fan motor inside oven at back and other
is the cooling fan which is at top of oven .you just need
to find out which one it is and just replace . then should be back to normal
regards dan
Mar 19, 2009 | Belling XOU174 Electric Single Oven
Feb 02, 2009 | Ovens
Oven Fan won't turn off. Has to be turned off at main power source in order to stop it.
my fan took 30 minutes after cooking to turn off. i think it may have to do with the fact that it is trying to cool the oven?
just wait for 30minutes - 1hr to see if it stops and open the oven door all the way to speed up the cooling
Jan 08, 2008 | Fisher and Paykel OS302SS, Stainless Steel...
Ovens Logo
32 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
