Question about Tablets & eReaders
I have a trio stealth g4 10.1 and it says not enough memory but there is plenty. it shows to interal drives one small about 300 meg one the rest of my 16 gig. but it wants to save to small partition?
3 Suggested Answers
SOURCE: My trio stealth -9 shows first screen with that on
Hi, try to connect it to your computor, and try to access....if nothing, then you will have to do a software redo.....
Posted on Jun 21, 2014
SOURCE: When I get my trio stealth-9 if shows first two
Hi, u will need to take it in for repair on the software....
When i turn it on it says trio stealth g2 and stays there and won't turn the rest of the way on.
Perhaps the HARD RESET PROCESS can help you, Merrill. I've posted my suggestion as to how it's done HERE. ( ) , so you may findt that information useful.
I've had good success with HARD RESETTING when trying to correct errors like forgotten password, or forgotten lock-patterns. However, I've had a Trio Stealth G2 that displayed the SAME problem as yours, Merrill, and it would NOT respond to ANY attempts at resetting. I tried every combination I could : pressing volume down (-) and power; volume UP (+) and power; volume UP & DOWN (+ AND -) and power. It refused to boot. But since the case and the screens were in great shape, I went on Ebay and bought a Trio with a cracked screen, swapped the motherboard from THAT tablet and it worked perfectly.
Final caution, though: ask the Ebay seller to guareantee the physical condition of the ports and other controls on the unit before you buy it. Remember you need a working motherboard.
Best of luck to you, Merrill!
Mar 13, 2015 | Trio Stealth G2 7 inch Tablet with 8GB...
Get my trio stealth to turn on?
By far the most common fault with Android tablets and in many cases there is no fix which is disgraceful...
Its called a Boot loop caused by too many apps memory consumption, os or bootblock corruption - press the reset button (its a small pin hole usually on the back of the tablet) with a pin
If that doesnt work switch on and press the power and up volume buttons
You will be in recovery mode
Select recover system then reboot
You can also load a new os from an sdcard -cyanogenmod - google it.
If that doesnt work then i am afraid you are in deep - you will have to attach to your pc with usb cable , download and run the android dev kit and use the command line to sideload or repair the tablet. You will probably find you can still browse you files but the OS is hosed - Difficult if not impossible to fix without a factory reflash/reload.
Sep 14, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Serial number for trio stealth g2
on the box also there should be a number on the back of the unit.
May 28, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
My trio stealth g2 hype 4gb tablet will not go pass the trio stealth g2 logo it just freezes up what can i do
Have you tried my old trick of pressing the on/off button and at the same time, press the volume+ button. Sounds like you have a screen freeze. hope it helps.
Apr 24, 2014 | Mach Speed Trio Stealth G2 8 inch Tablet...
Trio stealth g2 shows my internal storage space as "0", it won't let me download apps, or updates. I have reset my tablet several times (pwr down volume)... erased everything I could. I know my wifi is...
My daughters tablet did the same thing. After we had it for about 2 weeks. Called Trio tech support. Ended up having to send it to them and they sent me a new one.
Mar 17, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Jan 07, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
Trio stealth g2 just shows start up screen won't boot up
my table resets up on ever boot , you have to renter all the info every time you boot it up, Trio G2 10in
Aug 11, 2013 | Mach Speed Trio Stealth G2 Tablet -...
Tablets & eReaders Logo
50 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
