Question about Water Water Heaters
Water is leaking around the soleniod. I put some teflon tape around the thread but made no difference. model k-2000
    Top Expert:
  • Water Master
  • 48,356 Answers
Cracked plastic housing
replace the unit
Posted on May 04, 2017
Leaking drain faucet
turn off gas. turn off water. drain water heater by connecting garden hose to drain valve and place discharge end somewhere that that will safely handle the water.(sink, outside,floor drain). lift temp. relief valve to allow air into the tank so a vacuum doesn't prevent draining. carefully remove the leaking valve by using a pipe wrench. counterclockwise to loosen. there may be a little water left in the bottom of the tank, so be ready with a wet vac. buy a new valve at your local hardware store, along with a roll of teflon tape. wrap the teflon tape around the threads in a clockwise rotation. don't use more than three or four wraps. replace the valve by turning in a clockwise rotation. tighten till snug. don't overtighten! if it still leaks a bit at the threads, you can tighten a bit more.
Mar 09, 2014 | A.O. Smith BTH-199 BTH-199 100 Gallon...
Plumming brass nipple leaking water
Are you installing nipple in top of tank-type water heater?
Did you use 6 wraps teflon tape?
Is the nipple IP iron pipe tapered thread? Or is it straight thread?
Why are you replacing nipple?
Was old nipple leaking?
If previously sealed pipe connection to water heater has started leaking, then it implies the tank is rusted, and water heater needs to be replaced.
Have you checked the anode rod.
Why are you using brass instead of pex-lined di-electric nipple, available from box store?
Sep 11, 2012 | Water Heaters
On demand hot water heater leaking
is this an area w/a threaded fitting?if so ,you turn off waterheater,drain,disconnect existing fitting,clean and rewrap with new teflon tape ,and retighten down.i only say to drain,because i am not sure if it is hanging and would not want to fall on you.teflon tape and rewrenching down should fix,unless soldered.then call your plumber.also if under warr.from installer ,less than 1 yr.,call them and tell them to fix it for free.i have over 13yrs in sheetmetal install,both in hvy.industrial down to many other types of home install of furnaces,a/c units,retrofits in /new and existing homes,waterheaters,garbage disp,refrig.water lines,gas etc
May 21, 2012 | Bosch Water Heaters
Water leaking from top on water heater
If it's leaking from a hose then you can try unscrewing the hoses, put some Teflon tape on the water heater threads and tighten. If it's leaking from the rim or under the threads call a appliance repairman.
Jun 03, 2011 | General Electric GE SmartWater Household...
Slight water leak from plastic drain fitting on rheem fury 40 gal gas water heater
You can try to crack it open and get a little piece of crud out of there, I'm sure that is all it is, Just get a tray or something to catch the water, It should stop it, If it gets worse, turn the water off to the heater, then open the valve and hope the bigger piece of crud comes out. It is about all you can do, other than drain the whole thing and take the valve apart and replace the rubber in it. Check it out, Hope this helps.
Dec 12, 2010 | Rheem Water Heaters
You can buy a replacement relief valve at any hardware or home improvement store. It's real name is a T&P valve or temperature and pressure relief valve. It always has a 3/4" inlet and outlet. It is a very easy procedure to replace. You will need a bucket, teflon pipe thread tape, and a 3/4" x 6" black iron or galvanized pipe nipple. To start the valve replacement, turn off the shuttoff valve on the cold water line. Then open the handle on the relief valve and drain water into the bucket, that is, unless you have a pvc pipe coming off of it into a drain floor, then just drain it without the bucket. Be careful, the water is hot! When the water level gets below the relief valve, it will stop draining. Then remove the pvc pipe, if applicable, and thread in the 6" pipe nipple to use as a leverage tool to remove the valve from the water tank. Turn it counter clockwise to remove. Then put teflon tape on the new valve, going from left to right with the valve threads facing downward. Wrap about 3-4 layers all around the threads. Then twist the new valve into the water tank clockwise and using the pipe nipple tighten by hand until very snug and outlet is facing downward, as before. Remove the pipe nipple and install pvc pipe, if applicable. Leave valve handle open and turn on the cold water until the valve starts spitting, then close the relief valve and let it fill up the tank. If you did it correctly, you are now finished! Good luck!
Jun 14, 2010 | Water Heaters
I have a leak in my water heater coming from around one of the legs. If I shut off the water, the leak seems to change to one of the other legs. Is there some sort of new pan that I can buy or a part that...
Sorry, Sam it sounds like the water heater is defective, unless you can find a leaking connection. It sounds like you have a leak in the heater proper. The reason the leak moves is that, when you isolated the water, it cooled and a slight vacuum is pulled, and the water picked a different course (probably). Before you change the heater out, look at the threaded connections for leakage. Check the inlet and outlet lines, boiler drain valve, pressure relief, and any other threaded connections that you may have. If you find any leakers, you can repair them with wrenches and teflon tape. If no leaks are found at any of the threaded connections, the assumption is that the tank has developed a pinhole leak. They generally are at the bottom 1/3 of the tank. What you can do in the future is to either buy the kind of hetaer that is designed to stir up and remove the scale and sediment in the bottom of your heater, or to manually flush your heater from time to time.
Best regards, --W/D--
Aug 12, 2009 | Water Heaters
Installed new water heater today. No problems,
did you place Teflon tape around the outlet nipple? you might have to remove and wipe off thread then reapply Teflon tape then put a layer of gasoila pipe dope over the tape then make sure it is the female adaptor is cranked down tight
Jul 12, 2009 | Water Heaters
I have water leaking from the bottom of my waterheater PE50T9A
It is possible that the water heater has a leak at the bottom. They eventually rust out. The valve should be removed if it is leaking and you should replace it. They are cheap. Be sure to use teflon tape to seal it back up
Apr 27, 2009 | Water Heaters
Water heater leaks on top
Make sure to use pipe dope(compound) or teflon tape on the threads. If you use the tape make sure to wrap the tape in the direction of the threads. Don't over do it with the tape 5 or 6 wraps should be fine. I prefer pipe dope myself....Joe
Dec 16, 2008 | Water Heaters
Water Heaters Logo
41 people viewed this question
Top Water Heaters Experts
D. E. Hev
Are you a Water Heater Expert? Answer questions, earn points and help others
