Question about The Computers & Internet
Trio stealth g4 storage problem
Says not enough memory but there is plenty. it shows to interal drives one small about 300 meg one the rest of my 16 gig. but it wants to save to small partition?
babb
  • 104 Answers
SOURCE: 160 gig external storage
Plug In your external drive! if you have any data back it up!(you said it was new so i assume there little to none) Go to start->run type diskmgmt.msc In the bottom pane look for your external drive! If there is a partition, right click and delete! Now the drive should appear full black on disk management! If not delets any other partitionin the drive. (Make sure you are deleting the external drive partition(s)) Now you can create drives by right clicking on the drive and click create partition! It should bring up a wizard which gives you the option to format, set partition sizes and everything!! If you don't wanna go through all that check out a third party software called Partition Magic: http://www.partitionmagic.com/home_homeoffice/products/overview.jsp?pcid=sp&pvid=pm80 hope this was helpful, regards, babb
Posted on May 07, 2007
DarkNeogen
  • 109 Answers
SOURCE: Guitar Hero III on PS2 Saving Failed
Could be. Maybe the game doesn't recognize the 16 MB. You can try an original 8 MB Sony one. They're not that expensive anymore. But first try the other Memory Card slot.
Let me know if it worked. Please rate.
Greetings,
DarkNeogen.
Posted on Jan 25, 2008
skotkolr
  • 558 Answers
SOURCE: luckeywalker@yahoo.com My Roland VS 880
that would depend on where you are located in the USA doesn't fix ya have people who do repair work in another section.?
Posted on May 28, 2008
vincent721
  • 240 Answers
SOURCE: Cannot reformat computer; no partition
the H drive is the manufacturer restore drive..where the factory setting, Driver and OS are installed ..since you deleted the drive and wanted to install new vista.
since you are using the OEM disk...boot your computer from CD...select custom install...if u are in stage that asking which drive are you going to install windows...click the more drive options in lower right...then create partition ...format..then install
Posted on Mar 16, 2009
buffalonyman
  • 1865 Answers
SOURCE: i just purchased a 320 gig hard drive and when i
Use the WD data life guard disc to partition the drive. Put the disc in, reboot the computer, and run data life guard. A screen comes up and asks if your system can recognize a partition greater than 137 gb. If your system can read larger than 137, then use the option to format one large partition.
Some OS cannot read larger than 137gb. Also some Bios have the same problem.
Posted on May 01, 2009
How do I download apps onto this device?
The default on most tablets is to install apps to internal storage so the SD card does no good by itself. You can go into Settings>Applications and change the location for each app to the SD card. Likewise anything else you put on a tablet, particularly photos and videos get stored in internal storage. If you have taken a lot of photos and videos they can fill up your storage quickly. You can change this in the Camera app by tapping the settings icon and changing the storage option to SD card. You will still need to actually move existing photos and videos to the SD card manually or copy them to external storage and delete them. I would also change the image and video resolution in Camera settings to 640x480. This is plenty good enough for pictures you just want to look at on the device or share online.
Jan 04, 2016 | Trio Stealth G2 7 inch Tablet with 8GB...
How do I reset my trio stelth G4 7.85
Have you tried using the reset button on the tablet? Manual can be found here: http://www.manualslib.com/manual/749979/Trio-Stealth-G4.html
Feb 05, 2015 | Tablets & eReaders
Why am i getting insufficient storage error when downloading if i have 10.3 gb free?
Go to your settings. Then to your apps. When you click on the app, you will have the option move to your sd card. Do it. Do the same with your photos, videos and music files. That is what your Sd Card is for. Once this is done you will have plenty of space on your internal memory to download what you want.
Sep 03, 2014 | Mach Speed TRIO Stealth G2 10.1" 16 GB...
Trio stealth g2 shows my internal storage space as "0", it won't let me download apps, or updates. I have reset my tablet several times (pwr down volume)... erased everything I could. I know my wifi is...
My daughters tablet did the same thing. After we had it for about 2 weeks. Called Trio tech support. Ended up having to send it to them and they sent me a new one.
Mar 17, 2014 | Mach Speed Trio Stealth G2 Tablet -...
How to restart a trio stealth G2
all that shows is trio stealth G2 when turned on it freezes I tried the reset button
Jan 07, 2014 | Trio Stealth G2 7 inch Tablet with 8GB...
What number do u do if ur trio stealth pro is not working
More then likely you powered the unit on before it had enough of a charge to operate, Chargers for these types of tablets are way to little power for these things, will hold the charge when you use it but will not charge the unit when you use it, needs to go into standby to charge. Hold the power button and see if you can get a reboot screen or a turn unit off screen. Turn the unit off fully let it charge up alll the way then powere the unit back on. Should reset it. If not look for a small hole in the unit that says reset. push this and see what happens.
Nov 28, 2013 | Mach Speed Trio Stealth Pro Trio Stealth...
Computers & Internet Logo
46 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
