Question about Westinghouse Televison & Video
Dead Westinghouse DWM55F1Y1 TV?
DWM55F1Y1 LED 55" 120Hz 1080p TV Powers on. Screen lights up (Backlight?). No picture, not even westinghouse logo. I unplugged/replugged @ surge protector. Audio is back. I was able to change sources without seeing, and then switch back to the source with audio. I see no picture with a flashlight. Any ideas what this could be or if it's reasonable to fix? Thanks in advance!
  • 10 Answers
SOURCE: westinghouse LTV30w2 has blank screen and audio
What you have is a darfon V144 board (junk). it's a simple fix if you know how to use some basic tools and a soldering iron. Get an led (i used digikey's PN: L10041-ND) and solder it from pin 10 to pin 16 on the OZ960 chip on the inverter board. If you need the chip layout type "OZ960 pdf" in google. Hope this helps.
Posted on Dec 31, 2009
budmrtn
  • 11361 Answers
SOURCE: I have a Westinghouse W3223 TV which has decided
This going to be tough one to figure out, but at least the back light inverter board and power supply are working, unhook it at least 1/2 hour?
You may have bad main logic board problem. Try reading my guide here and see how much the main baord may cost you.
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jun 25, 2010
Testimonial: "Thanks very much! That seems to have worked."
AJIN G
  • 6694 Answers
SOURCE: how do I fix backlight problem on Westinghouse dw 32h1g1 led tv
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
http://electro-medical.blogspot.com/
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Apr 05, 2016
gopakumarg43
  • 74634 Answers
SOURCE: Samsung 50 smart LED tv has no backlight but has audio and sound.
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Nov 13, 2016
  • 12962 Answers
SOURCE: Hisense HD500F-B57/SO led tv no back light. Audio is fine and picture is visible with flashlight. Thanks in advance
Check out your inverter board which supplies power to the backlights.
Posted on Nov 22, 2016
How do I reset my tv or set it up
Westinghouse 40 Lcd Manual - Heroku
gfdc.herokuapp.com/Westinghouse-40-Lcd-Manual.doc
Westinghouse 40 Lcd Manual - gfdc.herokuapp.com ... led 1080p hdtv - westinghouse 40 class 39 5 diag led 1080p hdtv black model dwm40f1y1 c ... lcd hdtv - buy westinghouse uw40t3pw 40 1080p 120hz lcd hdtv led lcd tvs amazon ... 1080p hdtv dvd combo user s manual vk 40f580d tv dvd combo pdf manual download, ...
Sep 17, 2016 | Westinghouse 40" Class LED 1080p HDTV...
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
What else could be wrong with lcd tv that has no video or audio, TCON board has already been replaced?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 06, 2015 | Westinghouse 55 in. LCD HDTV
Westinghouse dwm55f1y1 no video
Check and replace the backlight inverter. Contact any service technician. Gopakumar Gopalan Google
Mar 09, 2014 | Westinghouse 55" Class 1080p 120Hz LED...
Westinghouse dwm55f1y1 will not play through receiver
You need to connect a pair of audio cables from the audio out/monitor out ports on the tv to the same input as the cable is connected to.
Jan 05, 2014 | Westinghouse 55" Class 1080p 120Hz LED...
Screen go back to black after the westinghouse logo displays.
Westinghouse? A model number might help me help you---does sound remain or never make it on?
Mar 14, 2012 | Televison & Video
Televison & Video Logo
54 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
