Question about Plumbing
I am making a plumbing repair to copper pipe. There is a small trickle of water that I cannot stop flowing. What is a good way to block the water to make a good joint?
  • 2,374 Answers
Jamb a piece of white bread(wadded into a tight ball)into the pipe. Work fast. Bread will stop flow for a bit, but will breakdown quickly under pressure and dissolve with no blockage.
Posted on May 07, 2017
    Top Expert:
  • 51,218 Answers
Replace the copper section
fit new plastic ferrule to pipe inside the the fitting nuts
make sure that the pipe is round and not dented or scratched
tighten the nut more
put the pipe further into the fitting
Posted on May 04, 2017
HOW DO I UNFREEZE MY WATER HEATER I HAVE KEPT THE DOOR OPEN AND A SMALL HEATER IN FRONT OF IT BUT IT MAKES NOISE BUT NO WATER FLOW YET
it is probably not the water heater that is frozen but pipes in the area. Close the door leave the electric heater on and open a valve to let water trickle when it starts to flow.feel the pipe on the hot side of the heater if it is warm it is not the heater. try to stop any drafts and you can use a hairdryer to try to warm pipes that you think might be frozen. a torch will also work if you know how to use one and avoid any flammable areas.
Jan 17, 2015 | Water Water Heaters
Tip
The Leak - How to Repair the Leaking Water Pipe
Normal 0 MicrosoftInternetExplorer4 st1\:*{behavior:url(#ieooui) } /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Water is dripping constantly from the rag that you have wrapped around the pin hole in the water pipe. Let's see how easy it is to fix that dripping and give you peace of mind. With some of the fantastic improvements in plumbing fittings in the last few years, plumbing repair has been made very simple. Many leaks are caused by just a couple of things. The pin hole in the copper pipe that is caused by pitting inside the pipe. Usually this is caused by poor water quality. The inside of the pipe flakes off to cause a hole inside the pipe that eventually gets through to the outside. These often are given away by the green spot that usually is seen on the outside of the copper pipe first. This is caused by mineral left by the water evaporating off of the surface of the pipe. So in all reality there is a leak before there is a leak. The other main problem is the joining of two dissimilar types of pipes. Copper and PVC or Copper and Pex are two examples. The expansion rate of the two different types of materials is very different. This causes friction and constant movement where the two meet. This movement eventually will cause enough of a gap to allow the water to leak out.
Until recently there where many redneck fixes out there most involving garden hoses, inner tubes, hose clamps, epoxy, and many other creative fixes. I have seen way too many to describe all of them. Now there is a great way to fix those leaks with a simple push fitting. The new design of the push fitting allows for the pipe to be cut at the hole and then a coupling just pushed onto the pipe to fix the leak. The hardest part of the whole process is to get the pipe cut neatly. The same fitting can also be used to replace those pesky plastic to copper unions that always seem to give trouble. Joining different types of piping is no longer a problem.
By doing a quick search for push fitting you can find a number of different suppliers of this type of fitting. I have used a number of different ones and they all seem to work well. My preference is the brass types as they seem to be much more rugged in construction. The price of those fittings also reflects that. The most common that I have seen and used are the Sharkbite Brand. These are very good, are sold in many plumbing supply houses, and in Home Depot Stores. Other companies include Watts, Probite, Tectite, and Speedfit. I'm sure that I have left some out. These are some that I am familiar with and have used.
Bottom line is that it is now very easy for even a desk jockey to fix his own pipes. Go by the closet home improvement store on your way home. Pick up some of these fittings and impress the wife with talents that she did not know you had. You may even get brave and do that small plumbing project that she has been begging for. Now you can use these fittings to cut into that water line to run that new outside faucet or hookup that water filter yourself. With the push type fitting plumbing has been made easy enough for anyone to be able to do it.
on Dec 03, 2009 | Plumbing
35 hp mercury
Pices of impeller could be stuck in block,put hand on top of block and feel if it is running hot,blow compressed air into tell tale and see if that helps
May 12, 2014 | Boating
Changes in amount of water flow from shower head
when he soldered the connections on these pipes.. he may have partially blocked the flow with solder inside..if its restricted up to 50% then its a hell of a pressure loss..hot water is always lower in pressure anyway..also take the shower head and dunk in a clr solution it may have calcium deposits inside the small plastic orafices in it..
Jan 12, 2014 | Water Heaters
REPLACEMENT OF GAS WATER HEATER LEAKING FROM TOP INTAKE FLEXPIPE
A leaking from a pipe (but from a soldered or threaded connection point) should be replaced - not repaired. Chances are good that the wall thickness of the pipe has been reduced all along the pipe's length. This means that even if you "seal" the existing leaks, new ones will probably pop up fairly soon.
If you insist on attempting a seal, you may have luck with JB Weld's WaterWeld. JB Weld products are available from most hardware stores, home centers, etc. WaterWeld is designed for plumbing repairs like yours. This should stop the leak at this location - but beware of new leaks, later.
I hope this helps & good luck!
Nov 14, 2012 | Water Heaters
Water from bathtub faucet is orange when first turns on. The plumber says it is not rust. The pipes are all copper. It becomes clear after about 30 seconds but by the next morning the water is cloudy...
You didn't mention the source of the water. Is this a well or connected to a water system? If is a well you might need to install a filter on the line coming into the house. Does the orange water stain or have any odor? It is possible that there is a loose connection somewhere allowing sediment to leach into the line when there is no active flow.
Oct 28, 2012 | Hansgrohe Plumbing
I replaced a moen 1222 valve stem becasue i had just a trickle of water. I go the new stem in ok, but still no water. I have the hot water heater diconnected on the water inlet, but the out let is still...
With posi-temp cartridges, if one supply of water, hot or cold, is interrupted, the cartridge automatically restricts the flow of the other water source. This is to prevent you from getting scalded if the pressure on the cold side drops because of a toilet being flushed or any other uses of cold water. The cartridge will only allow cold water to flow through if there is hot water to balance it out. If you restore hot water to the faucet, it will operate properly.
Aug 04, 2017 | Moen 2919 Chateau Two Handle Tub and...
We live in a house built in early 60's. Re; Plumbing to kitchen sink and dishwasher. On vary rare occasion the sink faucet will have decent water pressure. We have changed the water faucet with a Moen. As...
if this is the only place in the home where water pressure is a problem then the lines may very well be the issue. if you have low pressure throughout the home then there may be a problem with the main water supply in the home. if the lines are galvanized pipe then they may be restricted due to rust or other deposits forming on the inside of the pipe. unless you are good at plumbing then i would suggest having a professional come out and assess the condition of the lines.
Feb 25, 2011 | Microwave Ovens
I have a pin hole in my copper pipe
first of all shut off the water to the area and see if the flow has ceased, if you still have a trickle of water you will not be able to solder the pipe. Any water flow will make the repair impossible. If you can get the water to slow to a trickle you will need to cut the pipe in half and solder a sleeve in its place at the cut. once the pipe is cut you can take a peice of bread, yes bread, and pack the incoming water side and this will stop the flow long enough for repairs to be made. The bread will break down to minute particles after the soldering is done and shouldn't hurt the system at all. If it is impossible to cut the piping at the area there is a pipe patch that you can purchase at most local hardware stores the wont require the water to be shut off however, this is a temporary repair and may start leaking again in the future. Good Luck on your repairs Hope I have helped you some
Dave
Jan 08, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
Removing a built in Asea Skandia cylinda 1200
Its normal to have the water supply from under sink to dishwasher 3/8 soft copper. If there is a water stop under sink for dishwasher go ahead and shut it off. If not you will have to shut water off at main. Now you can unscrew supply at dishwasher, it's close to the front on left side. Its a 3/8 compression nut, you can use a small cresent wrench.
Sep 30, 2009 | Dishwashers
Plumbing Logo
554 people viewed this question
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
