Ovens Logo
M
Maxine weingarden Posted on May 04, 2017
My oven will not turn off - Ovens
Tom Guadagni
Level 1:
Habit-Forming:
New Friend:
  • Contributor 33 Answers
  • Posted on May 08, 2017
Tom Guadagni
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
33
Questions
0
Helped
12906
Points
77
Probably a bad temperature sensor/thermostat if an older oven.
Moffat oven fan wont turn off. just keeps blowing cold air but eveything else is working
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Why is ignition still working after oven is lit
Oven Control Board
Relay board:
May 10, 2015 • Ovens
1helpful
How do I fix oven staying on
Oven Control Board
Relay board:
Apr 22, 2015 • Ovens
After cleaning the control panel ribbon, the oven will not shut down (top and bottom ovens. Is this the thermal oven shutdown fuse that needs to be replaced? If so, how do I remove the fuse from a W
Oven Control Board
Relay board:
Element heats up when we only put oven light on
Oven Control Board
Relay board:
Why will my whirlpool oven not cut off
Oven Control Board
Relay board:
DCS Double oven cooling fan will not turn off
Is this a convection oven? Need more info.
Whirlpool gold electric oven code pf and broiler won't turn off, oven goes into clean mode when baking
Oven Control Board
Relay board:
GE profile lower oven does not turn off...maintains low heat with the convection fan on for several hours.. When i turn oven back on and then off it stops...but the problem continues to happen periodically
Oven Control Board
Relay board:
Sep 12, 2009 • GE Ovens
Upper oven bake coil stays on.
Stove will not turn offCHECK
Oven Control Board
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately.ALSO CHECK THE BAKE AND BROIL ELEMENT.
Top Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you an Oven Expert? Answer questions, earn points and help others
