Question about Ovens
Our Westinghouse oven Model: POH688*07 is overheating and burning quickly anything I try to bake.
SOURCE: Oven bakes unevenly and burns food
Jenn Aire oven is about 5 to 7 % cooler than electronic temperature setting. How may this be re-calibrated?
Posted on Oct 14, 2008
EllaWatson25
  • 725 Answers
SOURCE: FRIGIDAIRE STOVE MODEL FEF316BSC I WAS BAKING
Don't worry! Your element probably blew out. It's no big deal. It happens. Call us for parts. 9728590929. It's really a simple repair, probably one of the easiest to do. Hope this helps!
Posted on Aug 24, 2009
SOURCE: Westinghouse Freestyle 668 oven not doing anything , just blinkin
Yes I can help.Hold down the buttoms on the far left at the same and then set the time using the + and - buttons.Cheers
Posted on Jan 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: From "bake" mode, oven door locked, both heating elements on.
The F3 E2 error code indicates that the electronic oven control board in the range senses an over-temperature condition in the oven.
This can be caused by a failed temperature sensor probe, a wiring problem between the sensor and the control board, or a failed electronic oven control board.
If the oven is apparently not overheating when this error code appears, then your likely failure is the temperature sensor probe.
If the oven is overheating, then you likely have a failed electronic oven control board due to a stuck relay not cycling the oven heating element off properly.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question$%^
Posted on Oct 01, 2010
oldTech2332
  • 2341 Answers
SOURCE: trying to find a bake
I have found the part # for it it's 5300207851 however searching all my parts supply houses that i normally use they say it's no longer available. Perhaps it may take some searching on your part but having the part number will possibly help you find it. Their is some places that restore vintage appliance and info on them could be found by a google search for vintage appliances and perhaps they may have one they need to knock a ton of dust off of and ship to you.
Good luck,
Gene
Posted on Aug 12, 2011
When baking when oven gets to temperature, and you open the door to put food in The grill comes on and burns everything. I use the middle of the oven, but it still happens. Any suggestions.
Not sure how your oven works, but older ones had a "pre-heat" setting that you would use to get the oven to temp. This ran both the upper (broiler/grill) and lower elements at the same time to raise the heat quickly to temp. Once the oven is pre-heated, you would switch the selector to "bake" and that would only allow the lower element to work after that. If you failed to remove it from "pre-heat", it would use both and burn the food. Just saying.
Sep 02, 2016 | Ovens
How to switch on oven westinghouse kimberly 509
If the oven does not work on bake or broil settings then there has to be a problem with the circuit, either on the control board or the thermostat. If only the bake element does not work then the element itself most likely needs to be replaced. There are ways to isolate further but takes some basic electrical knowledge and tools. Note that I am not recommending that you do the following linked procedure - merely pointing out an information source. https://www.youtube.com/watch?v=uZNyEqXCNOA
Mar 08, 2016 | Westinghouse Kimberley 509 Ceramic Oven
There's no heat from my Westinghouse Oven(pol662s). The grill, fan & light all operate correctly, just the oven. I'm guessing it's either a thermostat or element problem. If it's a...
One quick test would be to turn on the bake and shake the element a little. Sometimes the connection burns loose and by shaking the element you may breefly make connection and there would be a little heat. If that does not work you would have to take the element out and check continuity. (Turn the power off!) Next you need to trace the wiring. If you have an old mechanical thermostat you could have a burnt terminal. I forgot, first make sure you have 240 Volt going to the oven. Fans, clocks, lights will work on 120 V. but elements need 240 V.
May 10, 2011 | Ovens
I need the bottom heating element in an old westinghouse wall oven. the model # is OG25HXO
I am not certain what geographic region you are in but... Bake elements are often generic between brands. The key is to match up voltage, wattage, size, bends and terminals. Here are 2 pages of westing house elements:
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Range+%2f+Stove+%2f+Oven&Brand=Westinghouse&PartType=Element+or+Burner&Electrical=Yes
I tried searching using OG25HXO with little success even on westinghouse sites US and AU.
Thanks for choosing FixYa,
Kelly
Nov 18, 2010 | Ovens
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Wont heat past 200 degres
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
May 27, 2009 | Ovens
Dec 21, 2008 | Whirlpool RBS275PD Electric Single Oven
White Westinghouse built in oven not heating up.
go to RepairClinic.com
you'll need make & model #
Nov 15, 2008 | Ovens
Foil baked onto oven base.
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. Oven operation is not affected. The only option you have is to replace the panel or the entire oven liner...
Jun 07, 2008 | Ovens
Ovens Logo
42 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
