Question about Westinghouse Microwave Ovens
Westinghouse oven Model: POH688W*07 is overheating and burning quickly Not sure of the age of this oven as it was here when we purchased the home in 2011.
2 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: I would like to know
This site will allow you to date your appliances, I tried it with your numbers you included and I am not able to retrieve any information on your stove. I keep getting prompted for correct numbers, so I will include it on this post and you can check for yourself and make sure the model and serial numbers are correct. I think your model number is incorrect or your appliance was made before 1970. I get nothing when I type in your model number. If you need more assistance please let me know. and thanks for using Fix Ya
www.appliance411.com/service/date-code.php
Posted on Dec 31, 2010
Model #
Make and model will usually be on a label plate on the back of the unit.
With the age of the unit and unlikely availability of spares you may be better to look for a new unit. Cheers, Dan
May 08, 2012 | Microwave Ovens
How many watts are on the wst3501 microwave oven?
Westinghouse WST3501 Microwave Oven 0.7 model or 700 watt
Good luck (remember to rate this answer).
Apr 08, 2011 | Westinghouse WST3501 Microwave Oven
On stove bulbs what is the wattage I need to replace the two bulb's. Everytime I purchase bulbs they don't last long. LG microwave, model # lmvm2055st Thanks, Dave
There should be a sticker in the back that quotes this. 40 Watt is the highest you may go but....buy the 130volt brands as this is a higher rating for 120volt and it will not burn out as quick. Make sure it is an appliance bulb. Most hardware stores like ACE have them. Big Walmarts do too but check the package.
Jan 03, 2011 | LG LMVM2055 Convection/Microwave Oven
Surface Light Bulb burned out where can I purchase new one. Model ge #JVM230BL001 Spacemaker
most hardware stores/home centers carry them,you will need to unplug the unit and you should be able to access the lamp and unscrew it from inside the cooking chamber near the top of the cavity,you may need to remove a screw holding the cover first
Jun 25, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Microwave won't heat
Sorry my Clarification Request came out as a single blob of a paragraph.
That's not how I typed it. I never write that way!
So I've pasted it here, but as a solution.
Magnetrons generally should last about 2000 hours, but several factors can shorten that.
If it's not OVER ten years old (from the purchase date or the date on the tag inside the unit) then the magnetron is still under warranty.
From the owner's manual:
"For the second through the tenth year from the date of original purchase
"The magnetron tube, if the magnetron tube fails due to a defect in materials or workmanship. During this nine-year limited warranty, you will be responsible for any labor or in-home service costs.
"For the above limited warranty: To avoid any trip charges, you must take the microwave oven to a
General Electric Customer Care® servicer and pick it up following service. In-home service is also
available, but you must pay for the service technician’s travel costs to your home."
GE Customer Service is here, and you can verify the warranty status and find your nearest authorized servicer.
If you're sure the magnetron's bad, it's still under warranty, and you or a friend are handy, they will send you the magnetron to do it yourself. Call them at 888-239-6832.
Be persistent. You may have to speak with a supervisor.
It does sound like the magnetron overheated and the magnetron's thermostat opened until it cooled down.
An overheating magnetron can be due to:
  • operating oven without cover(s) in place
  • wrong magnetron installed in oven
  • an old or otherwise failing magnetron
  • cracked magnetron magnet
  • improper power line voltage (should be 110-125VAC)
  • foods low in moisture (popcorn & bacon, e.g. - add 1/2 cup of water in rear oven)
  • failed or inoperable cooling fan or hood vent exhaust fan
  • deteriorating foam weatherstripping seals in air ducts or on outside cover
  • blocked air vents (dust, animal nest debris, insufficient free air space behind & around oven, etc.)
  • clogged or greasy charcoal filter or grease filter
  • blocked duct in hood vent exhaust
Since yours is a counter top model, there are less of those factors to worry about.
When you hit Start to microwave, do the inside light, cooling fan, and turntable all come on?
Any unusual noises? Is it louder or quieter than usual?
We have a sound clip of what a microwave should sound like when the cooling fan and high voltage section are operating here.
You can find helpful exploded view diagrams and order parts if needed by entering your full model number from the tag on the oven here.
Let us know what you find out or decide.
Jul 05, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
40 watt night light bulbs constantly burn out short out.
Is they are left on all the time, this can reduce their life, and they are more susceptible to vibration.
Have you checked at home center or home improvement centers like Lowe's, Builder's Square or Home Depot?
You can order quality parts such as lamps by entering your full model number or part number WB36X10003 here.
Always be sure the microwave is unplugged or the breaker is off when installing or removing bulbs, and be sure the bulbs and and your hands are clean when installing them.
Feb 13, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker Model # jvm1650wh05 GONE CRAZY
I have a GE Spacemaker microwave oven and it is not heating the products. The light works, turntable turns but wont heat anything?
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Only the #4 does hasn't worked for some time. This is my 2nd Model R-310J; R209J, R308J. Original purchased from a Home Depot12-4-07 and due to that one being faulty, we exchanged it for same model
Since you posted your contact info, I have sent you direct e-mail on this.
It sounds like it's repairable with our $39.95 service, but you'll have to decide if it's economical for this model.
Dec 08, 2007 | Sharp R-308J Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Westinghouse Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
SHARCNET-USA
SHARCNET-USA
Are you a Westinghouse Microwave Oven Expert? Answer questions, earn points and help others
