Question about The Health & Beauty
I have a M51 pronto on the charger when plugged into a power source I see a solid red and also a blinking green light what does this mean
2 Suggested Answers
  • 78 Answers
SOURCE: m51 charger has solid red light and a blinking green light
Battery is shorted or may have cristlized replace battery. This will solve your problems.
Posted on Sep 16, 2012
Invacare Pronto M51 lights on controller blink 2 green 1 red
It means the battery voltage has dropped below the operating range of the chair electronics. Either need new batteries or maybe a charger and new batteries. There is always a chance of loose battery harness connections.
Jan 12, 2018 | Invacare Health & Beauty
Charger seems to have both red and green lites flashing at the same time no sequence and both batteries connected read 4.0 VDC, are these chargers repariable or throw aways
Your manual is here. The section on charging states, that green blinking means your battery is fully charged but blinking red means that your charger is faulty. I would say repairable.
1. Plug the female connector of the AC power cord (supplied) to the AC receptacle on the charger and plug in the male connector on the AC power cord into the wall outlet.
2. The On/Off LED indicator is blinking RED, this is abnormal. Unplug AC power cord from the on-board battery charger and wall outlet. Charger may need to be replaced. Contact an Invacare dealer or qualified technician.
3. When the On/Off LED indicator light is Off, charger is Off.
4. When the Charge LED indicator light is YELLOW, the batteries are charging.
5. When the Charge LED indicator light is solid GREEN, the batteries are fully charged (as their condition will allow).
6. When charging is complete, unplug the male connector of the AC power cord from the wall outlet and then unplug the female connector of the AC power cord from the AC receptacle on the charger.
http://www.invacare.com/doc_files/1125085.pdf
Mar 24, 2016 | Invacare Pronto M51 Power Wheelchair
My pronto m51 when i charge it the lights do not come on until i push shut off again
If you are referring to the three lights as the three colors red, yellow and green. Then you would normally get that. The circuit is telling you that something is attached to the chair, has faulty component or a motor unlocked. and you can't move.The rapid blinking would tell me that you have a controller fault or a motor fault and a rapid scroll left to right would be an inhibit. I would need to know which one it is doing to know for sure what what to look for. If it is just three lights then I would definitely look at the joystick and/or controller being faulty.
Feb 13, 2015 | Invacare Pronto M51 Power Wheelchair
I am getting a flashing green light when I try to charge my batteries on the Pronto M51 what does this mean
why did you change the batteries, did you verify that it wasn't the charger in the first place, sometime the charger will appear to charge but actually isn't. put a meter on one battery then plug in charger if voltage goes up charger is good if not look for loose connections and or bad charger.
Sep 25, 2012 | Invacare Pronto M51 Power Wheelchair
M51 charger has solid red light and a blinking green light
Sep 16, 2012 | Invacare Supply Group Invacare Pronto M51...
What is the proper way to charge the Pronto M51
Eduardo After using your chair and the battery level lights are down with yellow or red lights showing just plug the chair into the wall socket and let er rip. Now really after using your chair during the day and you are ready for bed just plug in the charger and let it charge over night. In the morning unplug the charger and you should be set for the day. If you don't use the chair everyday always put it up with a full charge and about once a week plug it in and let it charge overnight. Never leave the chair plugged in all the time and never leave it for more that 24 hours. The charger has two lights on it one red and one yellow or green that are hard to see because they are under the rear cover. When the chair is fully charged the yellow light turns green and you can unplug the charger and you should have a full charge. Hope this helps you
Sep 08, 2010 | Invacare Pronto M51 Power Wheelchair
Someone gave me a pronto m51 sure step motorized wheelchair but no manual was given..my question is: Is it safe to charge the battery overnight? Is there any danger of overcharging? If anyone knows for...
Jo, nope you are safe. Most of the chargers are designed to cut off and go into trickle charge once they sense that the batteries are fully charged. The problem with overcharging comes after 18 hours or so. You should never leave the charger plugged into the chair for more than 24 hours. On the M51 the charger is built into the chair so just plug it in when you go to bed and unplug it when you get up and you'll be ok. You can check for full charge by looking at the charger there should be a red light and a green light when fully charged. Hope this helps
Sep 08, 2010 | Invacare Supply Group Invacare Pronto M51...
How do i know when my invacare pronto m5 is fully charged?
With an M51, a full charge will be indicated by all three joystick indicator lights lit- red yellow green. The green far right LED is the full charge light. Also the charger has indicator lights that go from red/yellow to full green at full charge. Hope this helps
Jul 11, 2010 | Invacare Pronto M51 Power Wheelchair
When charging the batteries, are there 2 lights that go on...1 red and 1 yellow?
on my m51 the lights on the charger are red and green the green is flashing what is this telling me.also should i have the controller on when i plu in the charger my chair i 6 years old battery replaced 2 years ago
Jun 18, 2010 | Invacare Pronto M51 Power Wheelchair
Health & Beauty Logo
Top The Health & Beauty Experts
Motshidisimary
Motshidisimary
Level 1 Expert
Stacy Harrison
Stacy Harrison
Level 1 Expert
Dave Jacobs
Dave Jacobs
Level 1 Expert
Are you a The Health and Beauty Expert? Answer questions, earn points and help others
