I need to do soild and liquid to put it in slime
I need with it
How do you make slime with 3 or less ingredients
hi Megan.
not sure if this is off any help to you.
Add the baking soda: Add the baking soda to the glue mixture and stir until smooth. Add the contact lens solution: Pour in 2 tablespoons of the contact lens solution and stir slowly. The mixture should begin to harden, becoming stringy. Mix until a ball forms: Continue mixing slowly until a ball of slime forms.
or try this link.
https://www.thekitchn.com/how-to-make-3-ingredient-slime-without-borax-245904
How do you make slime with flour and water?
  1. Step 1: Getting Things Together. You will need: A cup of cold water A big spoon Lots of flour Food colouring of any color.
  2. Step 2: Putting Things In. Once you've put the flour in pour about 1/4 of the water in then stir. ...
  3. Step 3: Entering the Food Colouring. ...
  4. Step 4: Going Stiff. ...
  5. Step 5: Nearly the End.
or this link.
How do you make slime with 3 or less ingredients Google Search
Dec 07, 2017 | Kitchen Appliances - Others
I have an Electrolux dx303 and it seems there is no water coming through. What could it be?
if you just defrost your ref then your tubing might be clogged by buildup of slime. if you can insert a small tubing to it then your problem is solved else you can buy a liquid chemical (like liquid sosa in the philippines) that is used to unclogged all pipes. i dont know if vinegar can solve the problem but its worth a try
Sep 03, 2015 | Electrolux Refrigerators
Is it true about mold in keurig coffee makers
Any place that heat and liquid can get trapped, mold can occur. This is why descaling is important for traditional coffee makers and even for tea pots. Basically, keep your stuff clean.
Biofilm Slime Bacteria inside the inner tubes of the Keurig Coffee maker
Sep 30, 2014 | Keurig B70 Coffee Maker
I use Slime in my bike tires and am following dealers recommondation that I pump up tire to 40 lbs pressure every 2 weeks.I am encountering problems inflating tires.It seems that the Slime will not allow...
I am pretty sure on the slime I use that it says I had to ride the bike immediatley after I put it in for about 5 miles, this was to throw the slime to the outer edge, also have you tried with the valve at the top of the wheel when pumping?
Please let me know if this doesnt help, if it does however can you rate my answer.
May 29, 2011 | Slime Tire Sealant
I have a crack in the drum
i would call up the manufacture and see what the warranty on the tub is. If its not covered, i would try to put some really good apoxy adhiesive on the crack. apoxy is some great stuff when it come to fixing leaks. i would buy the apoxy that is "putty like" It s in a tube i think. The type you have to moosh together with your hand to one soild color. Dont get the liquid kind. Its to messy...hopfuly this helps
Jul 31, 2009 | Maytag Neptune MAH5500B Front Load Washer
My new EZ-33 cloggs easily with small amount of waste to flush.
you have to take the whole toilet out. you need to check the opening of the down pipe. most likely the wax ring is blocking the soilds. shunt off the water drain out the toilet, unbolt the floor bolts and left it up. clean out the down pipe and replace a new wax ring.
Jun 04, 2009 | Jacuzzi Bath Perfecta EZ33 959 White round...
Slime buildup in my washing machine
The slime is almost certainly the enzymes in the washing powder that are there to digest the dirt getting left behind.
3 things you can try:
  1. As a one off to help clear out the slime, throw a couple of DISHWASHER tablets into the machine and run it through the hottest cycle it has. This may help get rid of the problem, but it will of course come back.
  2. Reduce the amount of washing powder you are using and keep cutting back until you get to the point where the clothes arent getting clean (This has the advantage of cutting the cost of your powder purchases too!). This should allow the machine to more effectively purge the drum when it rinses.
  3. Finally, change your powder, if for no other reason than a test, go try a pack of NON-BIO washing powder and see if that helps. If it does, either stick with it or experiment with other powders until you find one that helps and you like.
A combination of 2 and 3 above should eventually get you where you need to be.
Mar 01, 2009 | Bosch Washing Machines
Neptune t.l. washer has a horrible odor that we have not been able to fix, either with bleach & vinegar solution nor with Electrasol lemon scent dishwashing powder, as has been suggested to us. This...
if you use liquid detergent for a long period this will cause a nasty smell and it leaves a horrid slime in pipework etc. if so, put on a boil wash and change to powder.
also, make sure there is a water barrier between the washer drain pipe and your house drains
Jul 11, 2008 | Maytag Washing Machines
My Kenmore Elite He3 sounds like it has water in the tub after washing AND smells of MOLD?
there is always some water left inside the machine and that is probably what you are hearing are you using liquid detergent? if so this is almost certainly the cause of the smell. liquid detergent leaves a nasty slime inside thge machine and smells like drains. put on a boil wash with no clothes and revert to using powder detergent
Apr 02, 2007 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
