Question about The Audio Players & Recorders
Out of no where the audio coming from my speakers arent putting out enough volume and there is a fuzz noise coming from them, whats wrong with my system? everything used to work fine.
    Master:
  • The Master
  • 534 Answers
Likely a blown capacitor or 2.
Posted on May 04, 2017
Car speakers fuzz
Do not use factory speakers with a aftermarket radio the ohm rating will not match and you will never get any kind of good volume out of them.
New aftermarket stereo's are set for 4 ohm load. consult ohms law when purchasing new speakers. ALWAYS run new speaker wire to your speakers. If problem still persists then you have to install a choke (noise suppressor) on the positive side wire of you stereo or relocate it to another source of power.
Resistor spark plugs never hurt as well.
Oct 24, 2012 | Toyota Cars & Trucks
I have a sony home theater system. my cable box volume is all the way up but still with watching TV the volume is so low, eventhough the volume on the sony system is set to "MAX". also i get a...
First, TURN THE VOLUME DOWN. We don't test with max volume any more than we start our cars with the accelerator floored.
How is the audio from your TV getting to the HTS? Name names and be specific.
Your TV audio output may be dependent on its volume control. Many TV's have a FIXED setting in their setup so you can lower or turn their speakers off while letting REAL electronics and speakers handle the sound duty.
OR, you could (and should) bypass the TV entirely as an audio source and go to the cable box's audio output.
Feb 05, 2011 | Audio Players & Recorders
Car headunit fuzz in speakers.
my first thing to check would be the ground to the stereo. if your ground wire is loose, you will get that odd sound at most volumes. if that doesnt solve it, then you can go to a car audio store and buy an inexpensive noise filter that you splice into the power wires for your stereo, and that usually eliminates the radio noise.
Aug 04, 2009 | Car Audio & Video
Sound fades out on both earphones
The chance of both speakers going bad at same time is remote. Your ipod is at fault and has something wrong with its output circuits. Check to make sure that there is no muting circuit inadvertently turned on.
Jun 13, 2017 | Sennheiser CX 500 Consumer Headphones
Jl audio 500/1 amp low ohm light at high volume
I would try running the subs in parallel. Pos to Pos Dual Voice, Neg to Neg Dual Voice. Then Run + to + stereo - to - stereo on both channels.
So you have + and - running to one channel and + and - running to the other channel.
Also your LPF filter could be set too high.
Feb 07, 2009 | Jl Audio 500/1 Car Audio Amplifier
Humming Noise
There might be something wrong on the volume dial, or the speaker connection.
SOLUTION: Check the speaker cables on the back.
Mar 28, 2008 | Philips FWC577 CD Shelf System
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
26 people viewed this question
Top The Audio Players & Recorders Experts
bihug
bihug
Level 1 Expert
D. E. Hev
AliennoisE
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
