I am having trouble with the AV site on my 32M2160 TV, when the site is selected it comes up with a white arrow box across the AV emblem is there anyway I can fix it
techman
  • 3130 Answers
SOURCE: White Lines in picture
your problem is common for sanyo and fisher tv's the B+ feed capacitor is defective and maybe the waveshaper in the cuircuit right next to the IC. Your probably gonna need a service manual to find these caps as if you get one from sams photo facts post the vertical here and I will show you the capacitors to change. Done it a hundred times but I dont remeber the #s. Old age I guess. Good Luck
Posted on Apr 24, 2006
SOURCE: Unable to locat and select the AV channel on new LCD HD TV
Hi, try switching your tv to channel 3 or 4 and see if that works- there should be a switch on the back of your DVD player beside the Coaxial Cable outputs-it will allow you to use Channel 3 or 4 as the default to play dvd's. I hope that helps-if more detail or wiring diagram is needed-please leave make and model numbers and i'll try to help.
Cheers and have a Happy Holiday Season!
Posted on Dec 23, 2007
  • 275 Answers
SOURCE: jvc av-32wf36--have sound no picture
A bright Horizontal Line indicates failure of teh Vertical deflection Circuits.
Get a competent Technician to have a look.
Posted on Dec 01, 2008
rocky2005
  • 70 Answers
SOURCE: THE SCREEN IS BLACK WITH
Yes it can be. First try to power off your phone and hold the end and call button at the same time for about 15-20 sec, press Alt-W at the same time, to do a factory restore (this will delete all your data). Then restart your phone. If that does not work try posting your question here to see if anyone else has had your problem : http://forum.xda-developers.com/forumdisplay.php?f=507
Posted on Sep 02, 2010
SOURCE: i have a 26' led LG TV , and i am using a new set top box . when i am joining the tv from set top box and going in AV mode , its showing input blocked, i can not use set top box services. please h
Please provide a model number for this TV, I would have thought being an LED tv that you wouldn't be needing a set-top box as it would be digital already.
Posted on Apr 07, 2012
Where can I get a Hisense TV manual 32M2160 to download
What manual? User manual of service manual? If you wish to get some details; visit the site linked here. Pull up older posts.
http://electronicshelponline.blogspot.com/ Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Dec 01, 2017 | Hisense Televison & Video
Konka kk-199 tv
Yellow is for video; Red and White are intended for Sterno Audio. If your TV has only an yellow RCA socket, connect that Yellow socket with the pin at one end of Yellow wire, and connect the other end pin of that Yellow wire with the direct TV equipment.
Switch On both the devices [TV & DTV box], and select the TV input to AV, and see whether there is Video comes by TV. If yes, look for any AUDIO In socket at the back of the TV, Connect the other wire similarly as you did with yellow wire. For audio, only one wire connected will be enough.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jul 28, 2014 | Konka Televison & Video
I am trying to Connect my TV no: ALT2260M to Geepas DVD but not connected how can i start functioning?
Check its connecting wire [AV cord] first for any internal breakage to its conductor strands. Try with a new AV cable. After connecting the cable with TV and DVD player, switch the input to TV to AV. Power On the DVD player. If all connections are OK, you should see the brand emblem display of the DVD on TV screen. If not, make sure that there is some fault, either with TV or DVD player. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box and press "Enter".
Jul 04, 2014 | Televison & Video
How do I connect my Coburn home theater to my Sony 52 inch projection TV I tried but get no sound
if the coburn has a scart interface u willl need a scart cable that terminates to rca the simple av vcr cable jack then ;ug the scart end to the theater and the rca to the tv front jack inputs n u ae ok alternatively get a hdmi cable that terminates to rca and connect the hdmi end to the theater and the rca to the dvi/ dvd/compoment input remember sony use icons not words for there accessories for audio input the icon is an in-arrow to a square box and output an out-arrow from a square box select tv. dvd or component av before u start
Jul 19, 2013 | Televison & Video
I just bought a new dynex 32 inch DX-32L152A11 tv. I tired to hook it up to my dish system and the picture is black and white and no sound.
Hello Debbie,
This is due to incorrect connections between the dish box and the TV. You may find that if you select another input (AV1) on the TV, you will have sound from the dish system, but no picture.
I suspect you are using an RCA type AV cable with red, white and yellow jacks on both ends. You've most likely connected the yellow jack to a socket labelled Y, Pb or Pr on the back of the TV and then selected the COMPONENT input on the TV.
If you are using a cable with red, white and yellow jacks, please make sure they are connected to the sockets on the back of the TV shown below. I've ringed the socket for the white jack in green for better visibility.
Once you've done this, select the AV1 input on the TV by pressing the INPUT button on the dynex remote, then use the arrow keys to highlight AV1 and press ENTER to select.
If this does not solve your problem, please let me know which type of cable you are using and the model number of your dish box. If you don't know the technical term for the type of cable you are using, please describe it as best you can, i.e. how many plugs/jacks are on each end of the cable and whether they are color-coded.
Hope this helps. If you need further assistance, please reply to me by clicking on "Add a Comment" below your question.
Regards,
BElectric
Apr 16, 2011 | Dynex 32 in. LCD Flat-Panel HDTV
I have a blank, black screen, irrespective of the input (cable, dvd, wii). The menus, however, come up fine and the audio is working fine.
Your screen is showing a black picture because the closed caption function has been activated. When the closed caption mode is on the screen will display an 80% black picture.
To turn off the closed caption and regain a full screen please follow these steps;
1) Press the Menu button
2) Use the up and down arrows to navigate to Closed Caption
3) Use the right or left arrows to select it.
4) Use the right or left arrows to select OFF
5) Use the up or down arrows to select Finish
6) Use the right or left arrows to save the settings and exit.
You should have your full screen back now minus the annoying black box.
If this solution has helped please do take a moment to rate it.
Thanks for using FixYa
Dec 25, 2009 | JVC AV-32D305 32" TV
I have no idea how to get channels to tune in.
In order to get a picture of what is going on you must understand what is happening. The cable box converts all channels to channel three or four depending on what it was intitially set on. That means that you have only one channel coming into the tv. So you cannot program the set. You just have to put the TV on Channel 3 or 4 and leave that alone. Do not try to program the TV. Then change the channels on the cable box. The hitch is that there are several ways to hook a cable box to your set. One is with the RF connector, which is the screw on one, into either Antenna A or B. and the other is through the AV cables which are yellow, red and white. Yellow for video, red for right audio and white for left audio. If your box is hooked to the AV input then you must use the INPUT button on the tv to select the proper AV input. On that set there are several.
Sep 19, 2008 | Mitsubishi VS-50604 50" Rear Projection...
I have an Onn 15'' LCD TV Model No OLCD1504 and am trying to connect a DVD player that only has an AV out.I have tried connecting it with a Scart to Av lead in all combinations i.e. via freeview box,direct...
Some dvd players do not have the switching line fro your tv to automatically select scart input but you will be able to select via the tv remote if there are no buttons marked av it can be an oblong with an arrow pointing inwards or you may have to select via the source menu on the tv if you have your original handbook it will give a helpline number for Asda.SUPER8.
Jul 31, 2008 | Televison & Video
No Audio
1. Make sure you have connected the cables from audio OUT on the Directv box to the audio IN on TV input 3 and have selected the correct source on the TV.
2. Many sat boxes have an audio volume control. Select the satellite box on the Directv remote and turn up the box's volume.
Hope this helps.:)
Apr 01, 2008 | JVC AV-56WP30 56" Rear Projection...
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
