Solution of canonir 2870 shutdown error code 0007
hquiteculo
  • 19 Answers
SOURCE: error code
do you need to clean the error in service mode tham do you have to restarted the machine,if it not soluve please send to me email and I we are going to see it ok.
Posted on Jul 28, 2009
SOURCE: sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Posted on Aug 11, 2009
  • 1382 Answers
SOURCE: error code Oxc 18a 0007 appears and can not print
The "Ox18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Posted on May 19, 2010
canontech
  • 1219 Answers
SOURCE: error code 19
You have waste toner full!
Remove the drum, on top of drum there is cork, remove cork and vacume all the waste toner out.
Posted on Jun 02, 2010
  • 51 Answers
SOURCE: sir my canonIR 2870 copier has
Try turning OFF the Auto-Orientation.
Addition Functions > Copy Settings > Auto-orientation > On/Off.
Posted on Sep 20, 2010
WHEN MAKING A FIRST COPY OF ANY DOCUMENT THE FOLLOWING ERROR APPEARS e000024-0001
Canon imageRUNNER 2870 Copier Error code e000024 ...
www.fixya.com > ... > Canon > Canon imageRUNNER 2870 Copier
... error code e000024-0001 E000024-001 is a problem with the developing assembly it's usually either a faulty toner sensor sometimes just toner stuck to it just ...
Sep 09, 2015 | Canon ImageRunner 3570 | IR3570 |
2870 canon copier machine showing error code E000024-0001
service manuals free at http://www.eserviceinfo.com may help you out .
Jul 03, 2015 | Canon IR 2870 Digital Copier RECONDITIONED
remove your doveloper unit and check sensor, it is luse or re fix again ,........
Sep 24, 2013 | Canon Ink Cartridge GPR15 for iR 2270, iR...
May canon ir 2870 eror code below E000732-0010
sir ihave ir 2870 mashine . the machine giving E000225 -001 error code
Oct 25, 2012 | Canon imageRUNNER 2870 Copier
Error Code: E071 0007
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
29 people viewed this question
jasbo
jasbo
