Solution of error code 0007 - Televison & Video
4 Suggested Answers
hquiteculo
  • 19 Answers
SOURCE: error code
do you need to clean the error in service mode tham do you have to restarted the machine,if it not soluve please send to me email and I we are going to see it ok.
Posted on Jul 28, 2009
SOURCE: sony up-dr 100 error 0007
This may well be a failure of the cutter switch sensor to reset. This worked for me.
Turn Off the Printer.
Remove both side panels and the plastic panel on the INSIDE of the DOOR on the right hand side. Then close the door and remove the plastic panel UNDER the door. This is held in place by two screws.
You will see a white gear on the bottom right hand side of the door. It is on the underside of the door. Turn this gear untill you can see the cutter move smoothly across the bottm of the door and return to the right side of the door. Listen for a click. This is the switch resetting. Close the door and power up the printer if you still get an error code 0008 or 0007 repeat the resetting process by turning the gear. BE SURE TO TURN OFF THE PRINTER!!
Posted on Aug 11, 2009
  • 1382 Answers
SOURCE: error code Oxc 18a 0007 appears and can not print
The "Ox18" series errors can be removed by resetting the printer. Unplug the USB cable from the printer, remove the ink cartridges. When the "Insert ink cartridges" message appears unplug the power cord from the printer. Wait 1 minute (at least), then reconnect the power cord and turn on the printer if it didn't come on by itself. Reinsert the ink, close the unit and print a calibration page if prompted to do so. Finally reconnect the USB cable to the printer. If this doesn't work, the unit needs service (or replacement if the service call will cost more than a new printer).
Thank you!!
Posted on May 19, 2010
Code
I have exactly the same problem with my aprilia rs125 09 error 5 0007, do you solve this problem can you help me ???
May 24, 2013 | 2007 Aprilia RS 125
E000602 0007
I'm going to guess??? Do you have a Canon copier? If you do, the error code deals with the hard drive. You can try to do a F disk, it will only work for time enough to get to your car or out the door... You will need to replace the hard drive.... Good Luck
Apr 28, 2013 | Office Equipment & Supplies
E 0007
If turning the machines power on and off does not get rid of the error code than the only thing that will get rid of the error is changing the fixing unit.
Nov 27, 2011 | Canon iR 2016i Black and White Copier
I have an error code- E00060-0007
Error code 60 means the changing roller is not being detected position it properly. check if it is not in a pool of toner if so clean the toner properly with dry clothe.
Error 007 means the fixing fume is not being detected because it is damage and needs to be replaced.
Jul 14, 2011 | Canon Image Runner 3320I Copier
Error Code: E071 0007
I got an error code on my canon clc 1100:
E071 0007
Aug 19, 2010 | Canon CLC 1110 Copier
Error code Oxc 18a 0007 appears and can not print
Thank you!!
May 19, 2010 | HP Photosmart 3210 Printer
Error code
Jul 28, 2009 | Canon imageRUNNER C3200 Copier
CLC 1110 E71?0007, E071?0002, E072 error codes.
On my CLC 1150 copier machine, I have an error code E071 – 0002.
Sir plz send soluation this error
Dec 12, 2008 | Canon CLC 1110 Copier
Sony up-dr 100 error 0007
Dec 11, 2007 | Sony UP DR100 Thermal Photo Printer
Televison & Video Logo
Top Televison & Video Experts
