Question about Kenmore Kitchen Ranges
We have installed new granite countertops and now our Kenmore Elite slide in gas range is too high even after lowered as low as possible. Any suggestions for us?
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 48 Answers
Raise your bench top to standard height or get used to it.
Posted on May 06, 2017
  • 1462 Answers
SOURCE: granite installation didn't get flush with slide-in range
suspect your contractor didn't allow for the tiled floor. the range legs are usually adjustable up and down. have you checked this?
Posted on Sep 04, 2008
SOURCE: mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Posted on Feb 03, 2009
  • 4 Answers
SOURCE: Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Posted on Feb 17, 2009
aasc
  • 1606 Answers
SOURCE: Installing cooktop into granite countertop
Put a bead of clear sylicone caulking around the cutout , then set the cooktop in place .
Posted on Aug 08, 2009
  • 39 Answers
SOURCE: new granite countertops big circle spots on.
They suggested a dryer because they thought the stone had absorbed a liquid and was causing the stone to darken. This is common on unsealed granite. If you put a sealer on the counter tops however, whatever it is you see there will remain under the seal. I would ask the installer to come out and take a look at it. If they are unwilling, the Home Depot has a cleaning kit sold in the kitchen counters area of the store made by a company you can call and they will ask questions about the problem and provide advice on how to fix it. They are extremely helpful with free suggestions as well as stuff you may be able to purchase to fix the problems. In any case, granite is sensitive stuff and while it is physically durable it seems to be extremely sensitive to stain and etching and learning about proper care, cleaning, and dos and dont's will save a lot of heart ache and time for you down the road. (For instance oil absorbing into the stone is a several day ordeal to fix). Good luck with getting the results you want. If you did find a specific solution please share it here.
Posted on May 06, 2010
Which one has more heat resistant: Granite or Silestone? Explain?
Planning to refurbish your kitchen, Now-a-days, a wide range of choices for kitchen countertops are available in the market, which make you to choose the perfect one. In case if you are looking to select granite or Silestone for your kitchen worktops. Then, as per my knowledge both are popular choices, but he Granite is a very durable natural stone with a high aesthetic value. It is heat and scratch resistant but also porous and therefore possible to stain; it needs periodic maintenance. Where as the quartz used in countertops and flooring is a man-made combination of resins and crushed quartz. The resulting surface is non-porous, meaning it is more stain resistant than granite and requires less maintenance overall. For further detail explore at: Black White Granite Kitchen Worktops in Surrey Essex MKW Surfaces
Feb 29, 2016 | Green Bean Cleaning Products Commercial...
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
I have a new viking stove slide in electric top range that was installed in our kitchen with existing granite counter tops. But there seems to be a small gap between the stove and the counter. My previous...
If you are talking about a gap caused by the height of the stove, You can lower the height of the stove by adjusting the threaded leg posts on the bottom of the stove. A more difficult fix would be in raise the height of the countertop and cabinets by shimming the bottom of the cabinets.
If your gap is not a height issue, then you can experiment with some type of trim around the stove itself. Local granite dealers has an assortment of trims for issues like this.
I was able to find a number of trims for a back gap on my granite countertops and backsplash from my local European Marble and Granite.
Mar 15, 2013 | Cooktops
We purchased a slide in range, Frigidaire fggs3045kf. We want to put a granite countertop and use tile on the floor. When we raise the heighth of the range to make room for the tile, the ridge of the...
Hello Mkoffice, this a very common problem when floors are installed in front of cabinets and not underthe cabinets. it also causes a problem for the dishwasher. it will become trapped or cant be installed.If you dont want to removed cabinets to install the tile. you will need to raise the cabinet height. my shop has run into this before. We add 1 inch tall strips of wood across the entire front edge of the cabinets. the same is done to the back wall and any area where two cabinets sides meet. we dont use full sheet of ply wood because the granite installers will need access into the top of the cabinets to level the counters. The wood type should match the cabinet.( at least in the front) it will have to be stained or painted.
Hope this helps
Joe Connolly
Aug 16, 2011 | Frigidaire FGGS3045KF Stainless Steel Gas...
I just bought a 7904427 electric kenmore cooktop, which isnt installed flashed to the countertop, there is 2 mm gap between countertop and cooktop, cooktop sits on the 8 brackets instead of the flat...
From my experience, most cooktop manufacturers give cutout dimensions that almost always need modifications to get the screws or nuts on the stove to fit the cutout. Have your granite fabricator come enlarge the opening by grinding specifically where there is interference. They should be able to tent off your granite and use a vacuum to minimize dust.
Feel free to contact me with any questions. Brandon Wiese - Brandon@StoneRepairman.com - http://.www.StoneRepairman.com
Jan 09, 2011 | Kenmore 30 in. 42701 / 42702 / 42709...
Need to reinstall Kenmore Downdraft Blower
If I can get the model # I can help you more with the removal and reinstall.
May 28, 2010 | Kenmore 59940 Kitchen Hood
Is there suppose to be a gap of 1/8" - 1/4" between the lip of the range and a granite countertop?
Ranges have a built in safety factor when the cooktops were designed so that the perimeter of the stove stays warm at best when using. The granite is very thermally stable and will not have an issue here. But the oven area needs a little air space from your cabinet/wood surface.
Jul 26, 2009 | Electrolux 30" Self-Cleaning Slide-In...
Unable to install the electrolux slide in electric range
  • Electrolux may have supplied generic installation instructions, failing to account for design differences
  • Electrolux failed to validate the installation instructions against the actual hardware
Jun 23, 2017 | Electrolux EW30ES65GS 30" Slide-in...
Mounting brackets for granite countertop
Dec 19, 2008 | Dishwashers
Granite installation didn't get flush with slide-in range
Sep 04, 2008 | Cooktops
Kitchen Ranges Logo
48 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
