Question about The Office Equipment & Supplies
I try to enter the service mode but can't able to. I want to execute the Code error of SC863-06 Aficio MP4000.
Ickoajnc
  • 183 Answers
SOURCE: Does anyone know how to
you can do it by pressing the energy saver key it is next to the number " 3 "on the control panel or you can put a certain time when the machine will go to sleep.
1. press the [user tools] key it's on the right side under the copy key.
2. press [system settings] on the touch screen.
3. press [timer settings] on the touch screen.
the time can be set from 1-240 min.
it means after how much min. do the copier to go to sleep mode
Posted on Jul 12, 2009
  • 68 Answers
SOURCE: How to enter ''service mode'' on Aficio SP C221SF Color MFP
this is priveledged information and kept away from non service personnel to protect both you and the device from unqualified access and possible damage.
if you have an issue that requires entering service mode please call for a ricoh tech this ensures that you are protecting the investment you have made in purchasing a ricoh device.
Posted on Sep 16, 2009
Ickoajnc
  • 183 Answers
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Posted on Jan 22, 2010
canontech
  • 1219 Answers
SOURCE: need to execute APVC Correction in Service Mode
You must press *28* for service mode, but no APVC correction is no needed.
And if just want to do it any way be sure to put A3 paper in second drawer, because drum adjustment.
Posted on Mar 03, 2010
  • 11 Answers
SOURCE: I need enter in factory service mode to enter
press the clear mode key and use the key padto enter '107'hold downe clear\stop key for 3 sec enter the service mode and press on the touch panel sp mode and you can work what ever you like
Posted on May 23, 2010
RICOH AFICIO SP 4210N SERVICE MODE SC 545 Power Off On How Solve it this error?
SC545 fusing lamp remains on. reset fuser error in service mode. If it still reoccurs. Possible bad thermistor or power supply board. To go to service mode press up and down botton for about 5 sec and then press enter. In service mode engine fuser reset SP5810 execute
Sep 30, 2017 | Ricoh Office Equipment & Supplies
HOW DO YOU GO TO SERVICE MODE ON A RICOH AFICIO 3224.I JUST FILLED THE OIL BUT STILL GETTING SAME ERROR SC570.DOES THE OTHER PIPE ON THE OIL TANK CONNECT ANYWHERE BECAUSE IT IS JUST HANGING THERE.
Hello Peter,
Once the device has been neglected for oil long enough you will get this error code. Usually people don't wait until the code occurs. You WILL INDEED need to go into service mode. To do this,you will need to follow a fluid 3 step process. First locate the "CLEAR MODES" key located obove the 9 key pad. It is yellow. Now locate the red STOP button located below the 9 key pad.Ok, to enter service mode you will need to press "Clear /Modes"and release,then press the numbers "1,0,7" in a 3 step sequence and release, then press the red STOP button and HOLD it down till the device beeps. The screen will change and say service mode. Press "COPIER". The screen will change again. Using the keypad press 5,8,1,0 and then press the pound sign {#}. You will be prompted/asked to EXECUTE. Press EXECUTE. Now unplug the device while in service mode after the execution of the 5810. Wait a sec, plug her up, and you are done. Have a good day and let fixya know I helped. :-) SPINAL
Jul 23, 2011 | Ricoh Aficio 1232C Color Copier
Jan 21, 2010 | Office Equipment & Supplies
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
Ricoh aficio 2232c sc542 error
SC542 means that the thermistor hasn't detected right temperature in given time.
Often you only have to reset service code.
Try this reset:
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
from http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/ here is another service procedure:
  • Press Mode(The Yellow Button)
  • Enter 107
  • Press STOP Button for 3 second (RED Button)
  • Copy Sp
  • 5810#
  • Execute
  • Power Off
  • Power On
Nov 19, 2009 | Ricoh Aficio 2015 Copier
I need the fuser reset code for the Ricoh Aficio 350
Try to reset with 5801 it means:
enter service mode with 107 and find 5801 and execute then switch on and off the copier.
Please try if it works.
Oct 15, 2009 | Ricoh Aficio 350e Printer
Aficio sp4100n sc541 error
Press total clear press 1 0 7 and press for more off 3 second the clear stop key to enter to service program mode.
Then enter SP 5-810 (SC code reset),
select execute, select close. Exit
SP mode, turn the main power
switch off then on.
Aug 05, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Service code SC 548 on a Ricoh Aficio SPC 811dn printer, what is it and how to correct?
I have sc 548 error code also. I was following your instruction, but i couldn't enter to service mode. How do i prepare it? Please write this instruction to me step by step.
Apr 23, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Error Aficio 550
reset the problem first if don't work then replace laser unit
1, press "clear mode" on up-right of panal.
2, enter 107
3,press and hold "clear/stop" for 3-5 second
4, turn power off and on
Dec 12, 2008 | Ricoh Aficio 450 Copier
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
