Question about Coffee Makers & Espresso Machines
Why is k cup dripping all around instead of coming out of the single opening?
3 Suggested Answers
BarrettDenCo
  • 1772 Answers
SOURCE: I got a single cup
Sorry to read about your problem, I hope this helps you out.
no its not...if you just got it..call the company..if you have had it over a year try this
The brewer should be de-scaled at least every 3-6 months. Scale is harmless, but if left unattended, it can hinder optimal brewer performance. De-scaling your brewer regularly helps maintain the heating element, removable water reservoir and other parts of the brewer that come in contact with water. Better water quality and water heating means a better cup of coffee, tea, hot cocoa or iced beverage. We recommend de-scaling your brewer at least every 6 months (every 3 months if your water has a high mineral content). The de-scaling process involves using 48 ounces of undiluted white vinegar.
Take 48 oz of white vinegar. place in tank. pretend you are making coffee (Do No Use K Cup). let the water fill you mug. then empty that mug. Do it again until tank is empty. then let sit for 4 hours.
Then fill with fresh water to the top. let that tank of water run thru. towards the end taste the water.
If you taste vinegar..use more clean water, until the taste is ok.
I tried to help you. Please help me and Vote/Rate this response. Thanks and good luck
Posted on Dec 22, 2010
vicfixx
  • 54 Answers
SOURCE: my cuisinart keurig drips water while it brews
Broken hose or inlet on the inside
Posted on Mar 10, 2013
The water in my Nespresso does not come through the from where the pod is, but fill the drip tray! what is wrong?
I had a coffee machine that was letting out the water instead of making the coffee it turned out the hose that leads the water was disconnected from the source if you can get to the hose you may find the problem good luck
Jan 03, 2015 | Nespresso Coffee Makers & Espresso...
WHY HAS MY CAFE STOPPED WORKING? IT DOESNT DRIP COFFEE INTO CUP.
Sounds like your machine is congested. Consider cleaning out the nozzle or the filter.
Sep 22, 2014 | Bunn Commercial Bunn My Cafe Pourover...
Keurig drips too slow
The exit needle is located on the inside bottom of the K-Cup Holder. If coffee grounds or cocoa mix gets clogged in the exit needle, it can be cleaned using a paper clip or similar tool. Remove the funnel from the K-Cup Holder, insert the paper clip into the tube and move it around to loosen the clog and remove any debris. Please note, you cannot poke all the way through the needle as the opening of the needle is located on the side and not the top.After cleaning, align the K-Cup Holder tabs with the opening placing the two front tabs on the bottom and the single tab on top and snap it into place by pushing down on the top rim.
Aug 28, 2013 | Keurig K-Cup Keurig OfficePRO Single-Cup...
Cusinart coffee pot single serve with kuerig cups switch won't turn on
The problem is often that the machine develops a leak in the hose that is right over the transformer...the water drips onto the transformer and kills that... then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig One Cup Coffee Brewer will not turn on
heatman101
Sep 01, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
My Saeco Vienna at times seems to extract a cup of coffee extremely slowly (drips out). The next cup will come out at a normal rate. I've tried the grind at various settings, but the problem remains. Any...
HI You might need new burrs. When the burrs get dull, they will crush the beans instead of grinding them into small grounds. You start to get powder instead of grinds. They will slow the extraction, but then the next time they will produce the correct shot.
Feb 19, 2010 | Saeco Vienna De Luxe Espresso Machine
Kenmore refrigerator model 363.9711781 water appears daily
This water comes from a plugged up defrost drain tube. Do you see like a cup at the back of your refrigerator connecting using a plastic tube in a hole at the back of your refrigerator ? This cup collects dripping water from your freezer during a defrost cycle - you will notice a hole above it on the ceiling - what drips into this cup and drains out back the hole in your refrigerator wall and into a long drain tube extending down into the drip pan at the bottom of your refrigerator, usually sits ontop of the compressor or in newer systems next to the condenser fan and evaporates. If this drain tube is plugged up with debris water will backflow back into your fridge and drip against the wall and under your cripsers.
During a defrost cycle (when you hear the sizzling sounds and all motors are off, open the door and you should notice water dripping.
If you can manually remove the cup yourself you can pass a piece of pipe cleaner or long cable and dislodge whatever is blocking it or if you can't do that you will need to have it serviced, sometimes there is a seal around base of the plastic tube it's best you don't touch or break it. Makes ure the cup is firmly connected and inserted into the hole, you can try raising the fridge a bit, the front part so it is slightly inclined to back. If all fails, have it serviced, it is a very simply problem easy to repair and common too.
Aug 24, 2009 | Kenmore Refrigerators
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Ross Keen
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
