Question about The Office Equipment & Supplies
I have a problem with my Aficio MP4000, I replace the toner and here comes this error code SC863-06. Please can you explain and help me execute the error.
3 Suggested Answers
  • 46 Answers
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Posted on Aug 28, 2009
  • 183 Answers
SOURCE: Error Code ''SC441'' on Ricoh MP4000 Copier
The machine have problem with the transfer roller or the motor which drives the transfer is overloaded,
see do the right door is closed good if this not help it will need to be checked by a technician
Posted on Jan 22, 2010
Error sc542
SC542 is a fuser related error code, this will need to be reset.
Probable causes are:
• Defective thermistor
• Incorrect power supply input at the main power socket
• Defective fusing lamp
Corrective actions :
1. Check the voltage of the wall outlet.
2. Replace the fusing unit
3. Replace the fusing lamp.
Resetting the code:
Execute "Fuser SC Reset" with Some (printer models) or "Engine Maintenance Menu" (MF model) to recover the machine after completing the recovery procedure. Otherwise, the machine continues to issue this SC code and cannot be operated.
Sep 02, 2014 | Ricoh Aficio Sp C320dn Laser Printer -...
Error code sc542 on ricoh spc222sf?????????????????
Press the red CLEAR/STOP key till you hear the little beep. Press 1 0 7 Press the green COLOR START key. The display changes into MAINTENANCE MODE Use arrow keys to go to ENGINE MAINTENANCE and hit Ok Use the arrow keys and select FUSER SC RESET and hit Ok Hit OK again at the Execute prompt.
Once it is done executing the reset, power the unit off and on.
If the error comes back again, it is likely a real hardware problem and you may need to replace some components.
Sep 30, 2010 | Ricoh Aficio SP C222SF All-In-One Laser...
Jan 21, 2010 | Office Equipment & Supplies
Error code SC 548 on Ricoh Aficio 1022 copier. Need to reset m/c
sc 548- service call - fusing unit not set properly
the fusing unit connector may be loose.
u can reset the error by entering the service mode (careful -do not change anything )
to enter the service mode press [all clear](yellow button) ,[1],[0],[7],[clear](orange button)and keep the button pressed for about 5 sec.
go in copier options , then mode 5, then option 810
and execute(or 1 & ok)
(careful -do not change anything else)
Jan 15, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I have a ricoh aficio 2035 that reads error sc 546 problem
It is fuser code, to reset enter the sevice mode by pressing All clear 1,0,7 & Keeping Stop button pressing, Press the copy Mode, then OFF & ON the m/c, the code will cleared.
Aug 17, 2009 | Ricoh Aficio 450 Copier
Error 592....
Hello sir; The error code you display, means the toner motor defect, just replace it, will take care your problem.
May 27, 2009 | Ricoh Aficio 1085 Laser Printer
How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Jan 06, 2009 | Ricoh Aficio 450 Copier
27 people viewed this question
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
