Question about Troy Garden
Where can I get starter parts for my Troy built snowblower
    Top Expert:
  • Troy Master
  • 49,960 Answers
From any mower shop that sells parts for the make of engine used
( honda, B&S, Tecumseh, etc ) all you will need is the engine make and serial number to identify the parts
Posted on May 04, 2017
On our Troy built we can't start it unless we use jumper cables to touch battery terminal and then the starter
check switch for corrosion make sure all post male and the female plug are clean. Check power to switch with 12 volt test light if you have power to switch check your soilinoid there is one wire that activates your selenoid to send power to starer. .i would guess bad selenoid.
Apr 05, 2017 | Troy Garden
How come my troy snowblower stalls when I move the choke switch from choke to run ?
Most likely issue is dirty carburetor. Dissasemble and clean with carb cleaner or sea foam (let parts soak in it, if possible), reassemble. Could also be head gasket, but less likely.
Feb 17, 2015 | Troy Garden
Carburetor troybuilt storm10030
Get a parts diagram of carb. from Partshouse or sears direct
Feb 08, 2015 | Garden
Snowblower always in gear and wont throw snow and cant move when engine is off
Service kit available for that mess of gears in the motor box(needle bearings inside the gear seize up), there is also a shear or sacrificial adapter mounted to the impeller input shaft Parts and Diagrams for MTD 31AS63EF729 2011 check around part # 7 and 15 top right hand corner. hope this helps. if this didnt help check out this web site
Feb 05, 2014 | Garden
The ground broke off of the electric starter of my troy-bilt storm 2480 snow blower. Is there a way to fix it other than buying the $230 dollar replacement part?
You could just connect it as usual but provide a wire with an alligator clip on one end and the other end connected to the bare ground wires in the outlet box whenever you need to start the snowblower. An alternative ground location that is often easier for homeowners to access is to connect it to a cold water copper pipe, the external, visible ground point near the electric service, water main, cable TV, telephone, etc. Some states permit iron gas lines to serve as ground too. Check with your wiring inspector or local electrician to see what is acceptable in your town. Whichever way you choose to access ground, add this wire without disconnecting any of the others.
Once you have it wired up, the procedure is pretty simple really - you would first connect the alligator clip end of the ground wire to an unpainted, solid part of the snowblower's engine, starter motor or frame. Then plug in the power cord the way you did before the ground was broke off (orient the cord / plug as if the ground were still present). Press and hold the start button as usual until it starts. Once running, remove the 120 volt power cord first - then disconnect the grounded alligator clip. The ground clip must always be first on - last off. This way, at no time is the snowblower ungrounded when it is connected to 120 volts.
Of course, some folks will say you don't have to have a ground connected. True, it will work / start without the ground wire - but you do give up a bit of safety by ignoring it. The ground is to protect people from electrical faults - its presence does NOT effect the ability of the starter to function. I wouldn't dream of spending $230 to replace the starter just because it is missing ground wire (because it is so easy to get around the problem with my simple little fix) but I would only start it w/o the grounded alligator clip wire if I had too. For maximum protection, you should be connecting the snowblower to a ground fault protected outlet when using the electric start regardless of whether or not you're using the ground wire alligator clip.
Jan 07, 2014 | Troy-Bilt Storm 2840 277cc 28-in Two-Stage...
Snowblower blowing smoke
probably oil seal or weak gasket engines build up pressure if theres a weak spot on gasket or seals it will find the spot .it can also be the pcv valve ,pollution control valve
Dec 15, 2013 | Troy Garden
Snowblower problems
www.troybilt.com/equipment/troybilt/snow-throwers
Dec 15, 2013 | Garden
Can't start snowblower with electric start.
Our pull cord broke .came out and now can not thread it back in and when we do cannot do it tight enough . Will not work . Thanking You Linda
Dec 20, 2008 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
I have a troy built snowblower that has sat for 7 years.
hi roaddoctor86; I suspect that your carb is the source of your problem in the fuel system. I always drain the fuel in my 2 cycle and even 4 cycle engines and then start them and run them dry, before I put them up for the winter/. I would suggest you drain the tank or at least take most of the gas out and then add a can of gas treatment/solvent and see if that helps. Something like Heet I think is one product.
Hope this helps good Luck Loriongh ps Please leave a rating if appropriate Thanks
Nov 20, 2008 | Karcher 2500 PSI Pressure Washer
Garden Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
