Question about Gem Sound GemSound PA-585 2-Channel Amplifier
It was working fine and just quit it acted like it had blown a fuse but all of them that I have found look okay. Is there a reset switch on this model anywhere? When it kicked off the first time it stayed off for about for about 5 seconds and then came back on before it finally kicked off and stayed off, as if the power wasn't even plugged in. I seen nor smelled any smoke from burning, so I do not believe that it is burnt up, but I am stuck any suggestions?
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,810 Answers
Is this like charades
what the beep are we talking about here is it a toaster a car or may be a phone
the question makes no sence with out knowing the item that has the problem
Posted on Jul 25, 2009
Need to find a solution on some electrical issues on my Swift
Check for blown fusible link. Don't know about these? Run google search.
Jun 12, 2014 | 2006 Suzuki Swift
Running lights and dash lights not working on 1998 Pontiac Bonneville
I've found that this problem, assuming the fuses are okay, to quite often be a bad headlight switch or loose wiring to the switch...
Nov 14, 2013 | Computers & Internet
Wiring diagram
Bad headlight switch.
Nov 03, 2013 | 1994 GMC Yukon
4wd just quit
check the 4wd switch on the transfercase and wiring sounds like its shorting out. Fuses only blow when theres a short
Feb 09, 2010 | 1991 Chevrolet K1500
I have a 2003 Dodge Stratus and the power outlet quit working. Have checked the fuses they seem fine. Any suggestions?
If this is the cig lighter plug then check for power at the fuse, with key on accessories, using a test light or multimeter. Sometimes a fuse will appear okay but has blown in a hard to see area. If you have power there, then check earth contact at the plug or connection of positive wire onto rear of plug.
Aug 03, 2009 | 2003 Dodge Stratus
Blower fan not working
it is probably the resistors are blown or your switch is faulty. The blower motor can be found behind your glovebox. Remove the lower cover and you should see it. If there is power to the motor when your switch is on, it is probably resistors are shot. If they are okay, then the blower motor itself is shot. If there isn't power to the motor, then it's the switch that's faulty.
Jul 25, 2009 | 1998 Oldsmobile Aurora
Brake light fuse keeps blowing Noticed our brake ligths were not working...checked the fuses under the dash and they were fine...checked under the hood and found one blown...replaced it and the brake...
Take a look at the wiring to the brake lights. It is quite possible that over the years one of the wires has rubbed against another enough to short out, causing the blown fuses.
Jul 17, 2009 | 1998 Mazda Protege
2005 town & country electric door locks quit working
the door locks are controlled by the body computer and one of the switches may be bad. When you pull the fuse you are clearing the computer codes and the locks work fine until that switch acts up. once the computer sets a code for a shorted or stuck switch all switch inputs are ignored until you pull the fuse and reset everything. Could also be a bad wire to the switch or a bad computer.
Jan 16, 2009 | 2005 Chrysler Town & Country
Gem Sound GemSound PA-585 2-Channel Amplifier Logo
128 people viewed this question
Top Gem Sound Audio Players & Recorders Experts
 Grubhead
Grubhead
brian williams
Are you a Gem Sound Audio Player and Recorder Expert? Answer questions, earn points and help others
