Why do I not get my e-mail when I click on check tds e-mail
HOW DO i GET SERVICE TO YAHOO MESSENGERi CANN NOT FIND tHE YAHOO MESSENGER i HAVE SERVICE TO TDS E-MAIL ADDRESS HUNKYBUNKY@TDS.NET i WANT SERVICE TO YAHOO MESSENGER
Open the internet, type in "download yahoo messenger" in your search box. Click on a link to download the software. Open the website and follow the instructions.
Oct 09, 2011 | Yahoo Messenger
Procedure to open .tds winzip file version 3.0
You cannot open .tds files with winzip. Check this information: http://filext.com/file-extension/TDS It might be helpful. Good luck.
Jun 18, 2011 | Computers & Internet
What settings should I use for incoming/outgoing server to set up my tds email on my motoblur phone?
ISP Name
TDS Telecom
Country
USA
POP3 Server
(Incoming Mail Server)
popmail.tds.net
SMTP Server
(Outgoing Mail Server)
smtp.tds.net
Dec 21, 2010 | Computers & Internet
How to apply tds in tally
Please follow the below link for your problem.
http://www.tallyinfo.com/resources/help_files/
after open this website find statutory and taxation and double click on this option see step by step all details about tds.
thanking you
davevipul197
Dec 14, 2010 | Tally T2250 Matrix Printer
Stops will not spin had censor replace still will not spin.
Is the wash tub banging around in Spin Cycle with a wash load then failing with a dC or UC unballance error code?
If so the TDS is working as designed. Try a Spin Only cycle with no clothes in the wash basket. If it completes then the issue is most likely a clutch malfunction of your FAV6800A or FAV9800A machine. See this post Clutch Fix
Did you replace the TDS sensor or did a repair person? If it was a repair person did they try a Wet Load Spin Cycle after the TDS replacement?
If a repair person was called and the TDS replaced what troubleshooting steps did they take to warrant changing out the TDS? I would ask if the range of montion check of the TDS was checked for properation signaling action to the Control Board in Service Mode.
Oct 13, 2010 | Maytag Neptune FAV6800AW Top Load Washer
How do you know if you need to replace the RO membrane filter in the culligan good water machine
A TDS (total dissolved solids)meter is needed to test the Reverse Osmosis water and compare it to the feed water to determine how much TDS is being removed. Reverse osmosis membranes are designed to remove 80-95% of the TDS in your water supply.
For example: If your water has 500ppm of TDS the minimum TDS removal should be 400ppm leaving 100ppm. If the TDS from the Reverse Osmosis System drops to these levels it is time to change the Membrane.
Typically an RO system will consistently remove 90+% of TDS for many years. The normal lifespan for a membrane can be anywhere from 3-10 years. It all depends on the TDS of your water and your water usage. The higher the TDS the more frequently the membrane needs replacing. The other filters should be replaced every 6 months to keep the quality up and protect the membrane.
A TDS of 1000ppm compared to 100ppm is much more difficult remove to acceptable levels. I like to compare 1000TDS to taking muddy water, forcing it through a filter and getting drinking water. Where 100TDS may be more like a clear glass of water. Consequently a reverse osmosis system on high TDS will be less efficient, less gallons produced and filters will need to be changed more frequently to keep the quality and quantity up.
RJ
Oct 04, 2010 | Culligan Under Sink Water Filter
Why can i not receive emails from my brother email address jcppair@tds.net
Go to yahoo mail->options->mail options->spam->blocked email addresses->and if your brother's email address is there,remove it->save changes. Gudluk!
Feb 18, 2010 | Yahoo Mail
KONICA 1015 COPIER - P.27 ERROR MESSAGE - - WHAT DOES IT MEAN?
2. Toner was added prior to adding developer and performing the TDS adjustment. Developer must be added FIRST at new machine set-up so that toner does not fall on the uncovered TDS sensor.
Run 47 mode, output code 51 until the code does not reoccur (may take 5 to 10 attempts) OR open the developer unit and clean the excess toner from the area of the TDS sensor. Then tilt the developer unit to allow fresh developer into this area.
3. Poor connection at CN95. The toner density sensor (TDS) is abnormal (0.2 V DC or lower). Reconnect CN95 (located under the front of the developer unit).
4. TDS failure. If version 16.0 is installed, P27 is displayed when the TDS is disconnected or fails. Check for proper connection prior to replacing the TDS.
Jul 10, 2009 | Konica Minolta Office Equipment & Supplies
Ican receive emails but when trying to send emails I get the error response.
open your email click tools up top then accounts the click on your account and click properties make sure were it says outgoing it says smtp + whatever it says on incoming without the pop
e.g. incoming - pop.tds.net
outgoing - smtp.tds.net
if this doesnt work go to your service provider site it should say on there something about fixing your email settings or connection
Feb 07, 2008 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
