Question about Home
Why does water come out the tub spout and the shower head at the same time
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 10 Answers
Because the valve between the spout and shower pipe is defective - you need a plumber. Or locate the valve, move it from full on to full off a number of times to loosen the corrosion and perhaps it will seal at the shower position. Generally the shower valve is a pull-up knob on top of the tub spout or a lever that turn, mounted near the hot / cold water controls.
Posted on May 04, 2017
Shower head leaks
Yes, the "switch" (to redirect the water to the shower head) is not closing/sealing completely (when you are using the tub spout.) Depending on the spout (model), you may have to replace the part where the "switch" is located, e.g. the spout.
Mar 03, 2014 | Plumbing
Why does the water not flow from shower valve when turned on?
Do you have water coming out of the tub spout and not the shower head? If so how does the water get directed to the shower head,is it by pulling up the diverter on the tub spout?If water is still coming out of the tub spout then the diverter is bad and the tub spout needs to be replaced.
May 09, 2012 | Danze & Single Handle Tub And Shower...
Kohler rite temp with diverter. When the tub is turned on water leaks out the shower head. Changed the diverter didn't fix problem.
You could have a restriction in the tub spout or just too much pressure. Diverter only restricts flow to tub spout so any restrictions to the tub spout will cause water to go up to shower head.
May 13, 2011 | Kohler K-T396-4-BRZ Devonshire Single...
We have installed a moen 82490 one handle tub & shower unit. When we turn on the water you could shower and bath at the same time. If you pull the plug for just a shower the water to the spout stops...
If you pull the silver knob on the tub spout up, the diverter located located inside will redirect water up to the shower head and when lowered it will return the water to the tub spout. It sounds as thought the diverter is not working properly. Hope this helps..
Mar 08, 2011 | Moen & One Handle Tub & Shower Faucet
When lever on tub spout is pulled up for shower use some hot water still comes out of the tub spout...reducing water pressure and temperature of water coming out of the shower head... Tub spout does NOT...
2 things can be happing here depending on the age of the tub spout. If the spout is more than 5 years old, you may need to replace it. if not that old then you may have a screen filter blockage in the shower head itself. remove the shower head from the shower neck and see if there is anything in the filter. while you have the head removed, try the tub spout again and see if problem continues. this should guide you in the next step to either replace the tub spout or just clean the shower head screen filter. Hope this helps.
Dec 29, 2010 | Cifial 295.604.625.SO Polished Chrome...
When i'm filling the tub with water, the water back feeds up to the shower head and sprays out. I changed the spout and also moved the shower knob to make sure it wasn't stuck in the up position for the...
You will have water coming out of the shower head when you have really good water pressure. There might be more water volume coming out through the valve then what the tub spout can handle and in turn sends the water up to your shower head. When you fill your tub try turning the water only half way on not at full pressure, does this keep the water from coming out of the shower head? Most likely your valve has a 3/4" supply line while your shower head and tub have only a 1/2" supply line. Sounds like you have more volume to the valve than what the tub spout can handle. You might consider one of two things: 1) you can put a water regulator on the main supply line going into the house to lower your pressure, or 2) change out the supply line to the tub spout, increasing it from 1/2" to 3/4". Let me know whats going on.
Dec 03, 2010 | Delta Home
We have Delta brand tub/shower fixtures, the one handle kind. The problem is that water comes out of both the tub faucet and the shower head, even though the shower is not turned on. This happens every...
You need to replace the tub diverter/spout. There are two kinds, I hope you have the kind with
an allen head set screw on the bottom side of the spout near the shower wall. These are super
easy to replace ! Loosen the set screw, twist the spout a little and it should slide off. When installing
the new spout, smear some vaseline on the copper pipe sticking out, this will help seal the new O rings in the spout.
The other kind of spout has pipe threads in it. They can be a little more tricky. I got called to a
house one time. The plastic female threads on the spout cracked when the plumber installed it.
The water ran down the inside of the wall and did damage down stairs. The leak could not be seen
until the sheet rock down stairs fell down from being soaked. You need to put some pipe dope on the threads, then tighten the spout on by hand, so as not to scratch it with a pump pliers.
I hope this helps !
Nov 03, 2010 | Delta & Single Handle Shower Faucet
I turn on the spout for my tub and i turn the dial for my shower head to come on and it does, no problem, the shower head shoots water at full force, great water pressure, but there is still water coming...
I would look into the spout being the issue. The spout is a bypass when the shower is on and yours seems to be letting water get through. I would replace the spout..
Apr 27, 2010 | Price Pfister 01-311 Shower Head, Tub...
Delta T13090 faucet shower head working at the same time.
The only possible explaination is that the water is finding it easier to go up than down. Water is lazy, just like me. ;)
Use an allen key to remove the tub spout. It's underneath and awkward. Once the allen key is loose, the spout just slides off. Try running the water. This may solve your problem and all you'll need is a new tub spout. If not.....
Turn the water off to the house.
Use an allen key to remove the handle.
Use a phillips to remove the trim plate (2 screws). Cut the silicone around the trim if it's there (which, in a proper installation it shouldn't be, but...)
Unscrew the nut (usually chrome) holding the cartridge into the brass body of the valve. The cartridge pulls straight out. Check for restriction in the ports of the cartridge itself. Check for restriction in the line going down to the tub spout. If you can't find anything, replace the cartridge.
Reassemble & Enjoy!
Aug 05, 2009 | Delta & Single Handle Shower Faucet
Price Pfister Shower--No water to shower
Does the tub spout water flow stop when the shower knob is pulled?
Was the systems pipping flushed before the shower head was installed?
It may be clogged, remove the shower head and then attempt to operate. If it is clogged you will see debris trapped in the screen at its connection point. The shower head can be disassembled - cleaned - reassembled
Is the shower head an adjustable type, that may be in the off position?
Good luck
Mar 26, 2009 | Price Pfister Hanover 950-102S Soap &...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
