Question about Craftsman Garden
Where can I get a electrical drawing for a craftsman intek 21 hp model number 917.274033
    Champion:
    Habit-Forming:
  • 206 Answers
  • 11 Answers
SOURCE: Craftsman mower
charge the battery sometimes they come not fully charged if not push down clutch/parking brake sit on seat becouse of dead man switch and then crank it over
Posted on Sep 26, 2008
  • 109 Answers
SOURCE: Craftsman 21'' Lawn mower won't start
In order for there to be a spark at the plug, make sure the plug is grounded to the engine, it will not "fire" if it isn't.
Remove the cover with the crankrope, there should be a thin black wire going to the coil, going to a ground lug that kills the engine. Try unplugging this wire and re-check the fire...if it fires, there is a fault in this wire and should be replaced. The mower will run without it, but will not stop without "choking" out the engine
Posted on Apr 16, 2009
  • 376 Answers
SOURCE: Stratton Briggs Stratton Intek V - Twin Engine 21
The oil is contaminated with water. Change oil and filter, if it has one.
Posted on Jun 14, 2009
  • 257 Answers
SOURCE: Craftsman mower with 18.5 hp Intek Will run wide
check the lever biside the mower that connects to your carb. move it by hand while running if no change the governor has broke,, need to take engine off and replace, but if you move it and it slow down change spring
Posted on Aug 29, 2009
  • 5 Answers
SOURCE: Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1: LOOKING FOR A DEW CROSS REF OIL FILTERS TO REPL. C...
motorcraft fl-400 can buy at walmart
Posted on May 23, 2010
Briggs& Stratton 18hp OHV Intek engine will run only under a load.
Your PTO safety switch is opening intermittently. Would help if you would always add your model # such as 917.100000 that way I could look up on Sears site and tell you approx. Location of switch.
Aug 28, 2017 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Wheres oil drain on 21 hp intek briggs
you should have a square plug on the side of the block usually on the starter side of engine
Aug 25, 2012 | Briggs & Stratton Briggs Stratton Intek V...
I need a manual for a 21 hp 42" craftsman riding lawnmower model #944609210
Hi and welcome to FixYa, I am Kelly
After experimenting with numbers I have come to the conclusion that the 2 in your model number is an 8
http://www.managemylife.com/mmh/owner_manuals/search?query=944.609810
Actual manual location:
http://www.managemylife.com/mmh/lis_pdf/OWNM/99020015.pdf
Thanks for choosing FixYa, Kelly
Jun 07, 2011 | Craftsman 21 Hp 42" Lawn Tractor Riding...
I have a Craftsman 21 hp, 42" riding mower ~ 10 years old...when trying to start it, it just makes a loud metal noise like the gears are stripped. I'm going to try to remove the starter tonight...will I...
depends on the engine, briggs L-head opposed twins can be viewed by removing the sheet metal head cover near the starter, changing its starter is fun, as one of the bolts is under the flywheel, it can be changed without flywheel removal, with patience. Briggs Vanguard and Intek twins starters are easier to remove, the intek cowling has to be removed to see anything with starter in place but the starter can be removed with the cowling in place, the Vanguard has a few sheet metal covers that must be removed. If you've got a Kohler, starter removal is usually pretty straightforward, take the starter to a local repair shop for a comparison or test if you are unable to determine what's wrong. A decent shop will at least inspect it and show you what a known good starter drive looks like.
Jun 03, 2010 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Craftsman mower with 18.5 hp Intek Will run wide open only, regardless of throttle position. Linkage appears to be okay. Stuck float? What about the bowl electric solenoid valve?
Aug 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Intek engine runs poorly under load and when warm
if you have a ohv ajust valves and you might have to rebuild carb.
Jul 18, 2009 | Craftsman 21 hp 42 in. Deck Yard Tractor -...
Stratton Briggs Stratton Intek V - Twin Engine 21 hp oil had white foam in it
Jun 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
Will not crank
sorry for not answering sooner but turns out it was the starter solenoid.
Sep 06, 2008 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Garden Logo
55 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
