Question about GE Refrigerators
My GE side by side indoor water dispenser is running very slow, no leaks and just replaced the inlet valve, it made no difference
    Master:
  • GE Master
  • 460 Answers
Have you changed the water filter?
Posted on May 04, 2017
The water from the door of my GE Profile fridge doesnt work consistently. Sometimes it does and sometimes is does not provide water. It has started dripping inside the freezer leaving icicles.What to do???
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use.
You have two points where you can check the dispenser water. At the rear where the water supply comes in is the water inlet valve. If you disconnect the dispenser water line and then see if the water comes out when you try the dispenser. You should hear the valve work when you try the dispenser. If you don’t hear it there is a dispenser actuator switch problem. If you do hear it but water doesn’t work here there is a valve or water supply problem. If it's normal, disconnect it at the bottom of the freezer door and try again.If it's normal here it may be frozen in the door. If this is the case open the door till it thaws. A blanket over the opening will prevent thawing of all the food.
Dec 01, 2009 | GE Profile PSW26P Stainless Steel Side by...
I have a side by side GE refrigerator and the water dispenser is leaking quite a bit. It looks like is leaks where the water is dispensed.
Oct 31, 2009 | GE Profile PSW26P Stainless Steel Side by...
Water spencer don`t stop
Your water inlet valve on the back where the water supply comes in is probably leaking. disconnect the water line coming out of it and see if you have a slow drip. Try the dispenser to see if it's just drips after use. Replace the valve.
Oct 25, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The water dispenser unit has a tube coming into the back of the fridge. Anytime you dispense water, it will also leak from this tube in the back. Also, about once a day or so, it will sound like water is...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube. You can thaw the fill tube and replace the water inlet valve.
Sep 27, 2009 | Jenn-Air JFC2087HRS Side by Side...
Water leak from ice dispenser line
hi..
For the ice maker problem, Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.If it does, the problem is the ice maker and not the valve and line...
thank u
rate me!!
Jul 26, 2009 | GE Refrigerators
GE side by side; model # TFX25JRYD Serial #
So the dispenser is getting water. Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
If the valves clicks but water doesn't get to ice maker the fill tube can be stopped up with ice.The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
Jul 12, 2009 | GE GSS25JEM Side by Side Refrigerator
Water dispenser leaking at the door all the time.
Jul 09, 2009 | GE GSS25JFM Side by Side Refrigerator
Water is dripping from dispenser
Jul 02, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ed25rfxfw01 whirlpool fridge water dispenser ...I have a slow drip from the dispenser hose. I assume I need a new water inlet valve. How do I access the inlet valve for replacing?
It should be on the right hand side in the back take off the compressor cover on the back should be 8 or so 1/4 screws nutdriver type and then two more hold on the water valve. If you have a RO system hooked up to refrig you may need to change the filters on the ro or just change the filter on the refrig. those two will also cause the water to drip thru the valve allowing it to drip on the front
May 30, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
The indoor water dispenser valve leaks
Clean/rebuild or replace the valve that controls the water to the indoor dispensor.
Dec 29, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
