I have my tv hooked up to directv,the main box goes to the tv in garage so i have to change channels with the remote out there,bascally have to watch what ever is on that tv
And i changed the channel by mistake,tried reprogramming it but it won't let me
  • Tina Stitzel
    Tina Stitzel May 04, 2017
    Does the tv have to be on a certain channel? There is nothing wrong with the remote.when I went to reprogram it,it won't let me click on DirecTV under the options and after it goes thru the scanning it is all snowy black and white background
snakehead
  • 1074 Answers
SOURCE: Can't change Proline TV / Video combo to scart
visit www.partstore.com to purchase a originald remote for your set if they do not have it they can get it for you.good luck
Posted on Apr 08, 2007
ScottSwan
  • 33 Answers
SOURCE: No channels?
Try going into the setup menu and make sure the ANT input is set to cable. Then look for Auto Program or Channel Setup and let it scan and find all the channels it can receive. After it's done you should be able to go up and down through the channels.
Posted on Feb 16, 2008
  • 11 Answers
SOURCE: No remote and cannot change to video mode!
Go to radio shack and get an universal remote control that has a tv/vcr input button. the one i got is a Phillips Universal to switch channels myself.
Posted on Sep 13, 2008
SOURCE: Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Posted on Oct 17, 2008
ginko
  • 19396 Answers
SOURCE: TV stuck on one channel
Remove batteries from remote, and test again the touch buttons on TV with remote batteries out. This to exclude the possibility that remote has a stuck button.
If the problem persists , then it is probably a faulty IR board on TV (the one that gets IR signal from remote), or a faulty touch button switch.
Posted on May 16, 2009
Can i program lg magic remote to work with direct tv box
If your LG TV came with the IR blaster cable you will need to set one of the sensors in front of the sensor on your DirecTV box. Then go to your TV setting and select Video Input and Select the Input Port that your DirecTV box is hooked to. (In my case HDMI1). Then you will select that you are trying to sync your Service Provider and it will give you a list of device manufacturers. Select DirecTV limited and it will start to give you codes to try. You test these by trying the channel button up or down. If the channel changes you have found your code and you will click on "Yes" and you are ready to control. The "Guide" button will now bring up the DirecTV Guide and you no longer need the DirecTV remote.
Jun 05, 2012 | LG Televison & Video
I have a 27" sylvania
no solution here just sounds like the remote is programmed but not with the correct code or frequency hence why power won't work but volume does, if it's a universal remote try programming it again, also try looking at the manual to see if there's something like a mini breaker box, some remotes like garage doors have a panel of switches in them, sometimes a-b like a baby moniter, anyways look in the manual and see if there is one of these or something like that and maybe it just has to be redone there. good luck sorry if none of these work or can be done.
Sep 13, 2011 | Sylvania Televison & Video
I have a brand new straight from box LG TV model 32LD320. I have unpluged the HDMI from old TV ( where was working 100% OK) plugged into new TV. Mains switch on - and cannot get any chanels to report on...
HDMI sends video from a source likea bluray player or 'cable box' to tv it will not send signal so you can program channels from it
turn tv to the HDMI input you plugged device into and watch cideo from that source
you will need to connect some type of antenna to be able to program channels on tv
very few tvs need channels programmed these days since most people hook up a cable or sattelite receiver and change channels that way
hope this helps if not give me more speecific details and i can help you more
good luck
Mar 13, 2011 | LG Televison & Video
Cannot program channels into remote
IF YOU, STILL SUBSCRIBE DIRECTV, YOU MAY GO TO THE MENU, USING THEIR CLICKER AND GO TO THE PART OF MENU, WHERE YOU CAN CHOOSE TV TO OPERATE WITH DIRECTV REMOTE. YOU WON'T BE ABLE TO CHANGE ANYTHING ON TV BY USE DIRECTV REMOTE, BUT TO OPERATE IT'S CONTROL BOX. REALLY, YOU CHANGING CHANNELS ON THAT BOX, NOT TV ITSELF. IF YOU'RE NOT A SUBSCRIBER, FORGET THAT REMOTE! UNLESS YOU'RE A CUSTOMER, IT WON'T HAPPEN. JUST "GOOGLE" YOUR MAKE AND MODEL FOR A SUITABLE UNIVERSAL REMOTE, OR THE ORIGINAL.
ALSO: YOU WON'T BE ABLE TO GET ANY RECEPTION(HD OR ANY), UNLESS YOU HAVE RABBIT EARS OR ANTENNA ON A ROOF.
GOOD LUCK,
ALEX'S TV.
Apr 06, 2010 | Protron PLTV-32 Television
We have DirecTV and is is on channel 4. My
Use the tv remote to put the tv on ch 4. Use the direct tv then to select channel of the direct tv box. The box is broadcasting to the tv on ch 4. Also check that tv is on correct input . Again use the Panasonic remote to select correct input. If this does not work call direct tv for assistance.
Dec 03, 2009 | Panasonic TC-32LX60 32 in. LCD Television
Picture is coming in to big for the screen
direct tv is broadcasting some shows in a widescreen format (the boaders) zoom might bring the oicture in bigger for you
Dec 09, 2008 | Directv RC23 Remote Control
How to hook my directv to digital input to lcd tv j32l637
I don't know what flat screen tv you have,but you must be aware of the coaxial input behind the TV.It could be analog input,digital input and OUTPUT!!
Anyway,if you connect your basic directv box to your digital input,it will not serve you any purpose to get HD channels and you don't have the HD directv box.The TV will not display digital channel for you because if you use coaxial input to TV,you should be under either channel 3 or 4 and be sure either channel had been saved under memory.In order to change channels,you will need to change it from your directv box.
JUST LIKE a VCR connect to TV.TV will be under channel 3 or 4,and you will change your channels from the VCR.Don't forget to scan all the channels from the VCR!
solutiondoct
Nov 11, 2008 | Televison & Video
I have picture and sound when I watch a dvd/video but not through cable.
Try turning off the dvd/vcr and put your tv on the output channel of your DirectTv receiver. If this doesn't work it may not be hooked up correctly.
Oct 20, 2007 | Durabrand DU1301 TV
Not able to scan stations
I don't understand why you would bother to scan channel when you have directv or dishnetwork???
directv or Dishnetwork required their units in order to watch any channel,which means:
A. Depending on your TV setting,if you use RF connection from your basic directv to the tv,you would have to leave the TV on Ch.3 or Ch.4.to view the rest of the channels,you have to change it from the directv or dishnetwork box. You are NOT able to scan the rest of the channels from the TV,bottom line!!
If you have comcast or your local cable provider,once you have activated,you could use the RF signal coming out from the wall plate straight to the tv and go to TV auto programming,it will auto scan the available channels for you.
Don't waste your time on directv.
If you are thinking about recording from your BASIC directv or dishnetwork box, you would connect SAT. signal from the wall plate to the directv box,then use composite video/audio output and connect straight to your VCR/DVD player under composite video/audio input. Now you could record the viewing channel to the VHS.
Aug 19, 2007 | RCA DRC8335
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
