Am unable to power on my ES-S950 washing machine?How do I on it?
What does ES code in my aftron washing machine mean?
I do not find the particular code in a general search for Aftron codes. It may be an E5 code rather than an ES. But I do not have direct access to the codes.
Although knowing the model number might assist in locating a user manual with the codes, you might try the customer care number 1 800 238766.
Dec 26, 2017 | Washing Machines
Sharp washing machine,ES-AG950 hangs during the spin cysle.
Sounds like its tripping the drum vibration sensor or a temp limit sensor on your motor.
Apr 09, 2013 | Washing Machines
My Sony Steady Shot DSC-S950 won't flash. I have pressed the flash setting several times as suggested in blogs to no avail.
Sep 15, 2011 | Sony Cybershot DSC-S950 Digital Camera
DSC-S950 camera problem help!!!!
There is definitely some sand or dust stuck in the lens well between the body and the lens housing. Use your vacuum cleaner to pullout the dust particles from there. It is this stuckup dust that is making the noise. Also while pulling out the dust keep powering on and off the camera.
Nov 05, 2009 | Sony Cybershot DSC-S950 Digital Camera
Unable to change the time settings
In Sony DSC-S950, press Menu button, go to Setup menu, Clock settings and adjust time and date, press OK, press Menu button to exit.
Thanks.
Sep 19, 2009 | Sony Cybershot DSC-S950 Digital Camera
My Sharp ES-A50S washing machine won't spin dry. the alarm warning that the lid is open always sounds off even though I closed it already. what should I do????
ok your problem is due to some problem with lid sometimes a heavy wait on lid of dry drum makes it settings wrong alignment is not correct plz call the mechanic there it will fix
Sep 14, 2009 | Washing Machines
I have a nn s950 ba microwave. It has stopped
Just a possible solution. Our microwave suddenly seemed deader than a door nail.
Our microwave was on a rolling cart. Without realizing it we had pushed the cart too close to the wall. The cart had pressed the on the wire connection with the plug and temporarily broken the power connection. As soon as pressure was removed from the connection, the microwave came back to life.
May 17, 2009 | Panasonic Microwave Ovens
Washing Machines Logo
Top Washing Machines Experts
