Question about Rival VS107 Seal A Meal Vacuum Food Sealer
Heatseal 700 pro. Cant adjust the speed. Its like stuck at 6
What is the ignition timing for 2002 nissan hardbody 2000i 16v
Here are the 3 engines listed for this year. IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 2.4L SFI 4cyl
The Ignition Timing
18-22 DegreesBefore top dead center - When throttle positionsensor disconnected and using suitably programmedscan tool.When adjusting idle speed, set parking brake & chock drive wheels, curb idle speed (750-850 RPM)transmission in neutral.
IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 3.3L SFI 6cyl
The Ignition Timing
8-12 DegreesBefore top dead center - throttle position sensorharness disconnected.When adjusting idle speed, set parking brake & chock drive wheels, curb idle speed (700-800 RPM)transmission in neutral.
IGNITION TIMING
2002 Nissan/Datsun Truck Frontier Pickup 2WD 3.3L SFI SC 6cyl
The Ignition Timing
8-12 DegreesBefore top dead center - throttle position sensorharness disconnected.When adjusting idle speed, set parking brake & chockdrive wheels, curb idle speed (700-800 RPM)transmission in neutral.
Jun 05, 2015 | Nissan Hardbody Cars & Trucks
Does the GBC Ultima 65 have an adjustable pot to increase heat of rollers? If so, where is it located?
Ordinarily, laminators have speed controls to allow the laminated substrate to get hotter.
Feb 12, 2015 | Gbc HeatSeal Ultima 65 Roll Laminator
I have a 1985 Yamaha Virago 699cc.. It starts up and idles but dies when I give throttle?
Hi, Timothy and the usual suspects are:
1. Idle speed improperly adjusted.
2. Air fuel mixture screws not properly adjusted.
3. Inlet system air leak.
4. Leaking accelerator pump.
5. Loose low-speed jet.
6. Plugged low-speed jet.
7. Contaminated or plugged low-speed circuit.
8. Enrichner valve/choke not seated or leaking.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://viragotech.com/newtech/Only%20starts%20idles%20on%20choke%20dies%20when%20you%20give%20it%20gas%20(SOLVED).htm
Bike idles perfect but dies when given the slightest amount of throttle 93...
Yamaha XJ700N Service Manual
OEM parts for Yamaha
http://mybikemanuals.com/yamaha/yamaha-xj-owners-manuals
Apr 04, 2012 | 1985 Yamaha XJ 700 X Maxim
1985 maxim x 700 has trouble starting sometimes and wants to idle at 4000 rpm or stalls when adjusted, just rebuilt the carburetor still won't idle correctly
Hi, Dlmninja and the usual suspects are:
bike idling high
82 1100i surging bit 4000 rpm
Jul 21, 2011 | 1985 Yamaha XJ 700 X Maxim
Hi, I have a 1999 Chico/Citi Golf. The revs stay above 1000 and do not want to drop, I do not even have to pull the choke out. How do I get my revs to drop back to 1000? It use to Idle just below 1000,...
Check that the choke accelerated idle cam is not stuck. Check that the throttle cable has not dislodged and the outer casing is riding on the bracket. Check that the throttle linkages are free and the throttle returns to the idle adjustment stop. If all these are correct, adjust the idle adjustment to obtain the correct idle speed. 700 - 800 rpm is about the right speed.
May 15, 2011 | Volkswagen Golf Cars & Trucks
Why does my 1985 Yamaha Maxim XJ 700 stall / die in the rain. I can be riding along at 50mph in the wet rain / drizzel then it just dies
Hi, Achlubna and the usual suspects are:
1. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
2. Failed alternator/generator and or voltage regulator.
3. Loose or corroded battery terminals and or cables especially the "NEGATIVE" cable, look for loose, corroded, or broken connectors inside the cable harness at "BOTH" ends.
4. Failed main circuit breaker or ignition switch, check for loose connections and continuity.
5. Failed system and or ignition relay, check for continuity.
6. Failed ignition coil, ignition/electronic module.
7. Failed CKP, CPS, CMP, MAP, TPS, or BAS sensor, corroded, loose or broken wire connector pins/sockets.
8. Throttle cables and or idle speed improperly adjusted hot idle speed should be 950 RPM to 1000 RPM.
9. Air/fuel mixture screw improperly adjusted.
10. Accelerator pump damaged or not working.
11. Water or dirt in the fuel system, carburetor or filter.
12. Restricted, blocked or kinked fuel line.
13. Fuel tank empty.
14. The gas cap is not venting properly or fuel tank venting system blocked.
15. A failed fuel pump, pressure regulator and or fuel injectors.
16. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
17. Needle and seat stuck closed in the float bowl.
For more information about your issue and valuable "FREE" downloads that you need please click on the links below. Good luck and have a nice day.
Electrical Battery Issues 1985 xj700
http://www.kawasakimotorcycle.org/forum/mechanics-corner/144934-maxim-shuts-down-once-rains.html
Maximum Maxim Resource for 1985 86 Yamaha 700 750 Maxim Models XJ700X and...
Oct 25, 2010 | 1985 Yamaha XJ 700 X Maxim
Can boost mobile sim work in a pro 700
PRO 700 DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Mar 14, 2010 | Sanyo PRO-700 Cellular Phone
SPRINT SANYO PRO 700
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
Apr 09, 2009 | Sanyo PRO-700 Cellular Phone
2003 Toyota Celica GTs 6-speed transmission problem
Grinding going into third gear only may indicate a worn syncronizer ring. There are no adjustments on the shift cables, so I doubt highly that changing the cables will help you, since you are talking about 3rd gear only. Please note: This issue may be still under warranty, if your vehicle has less than 60,000 miles and is not 5 years old. Replacement of 6-speed internal parts is best left to a pro.
Sep 13, 2008 | 2003 Toyota Celica
Rival VS107 Seal A Meal Vacuum Food Sealer Logo
Top Rival Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Ed Mac
Henry  Thomas
Henry Thomas
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
