Question about John Deere Garden
It's a ride on mower.i have to jack up the tractor and clean out under the mower before I can mow again.very por disign on the mower.
It's the John Deere x300 tractor with 42 mower.
    New Friend:
We have one and find the same issue. The way round this is to lay the mower on its left side, looking from the back. There is no need to jack it up. Doing this gives full access to the blades and drive belt. Make sure though you lay it on its left side.
Posted on May 16, 2017
  • John Deere Master
  • 7,515 Answers
Here's the link and I'm sure you will get the solution of your problem.
JOHN DEERE X300 SERVICE REPAIR MANUAL
GOOD MORNING, I HAVE A D140 JOHN DEERE LAWN MOW,IT RUN WELL WHEN NOT MOWING BUT WHEN ENGAGED IT SLOW DOWN AS THOUGH IT HAS TO CATCH IT'S BREATH LESS THAN THREE YEARS OLD
Make sure there isn't anything binding the deck belt or blades. Check the spindles for free movenent. If all that is good then it might be the linkage that is supposed to adjust the throttle when the engine is under load or it might be a carb issue...especially if you run ethanol gas in it.
Aug 27, 2016 | John Deere D140 22HP V-Twin Foot Pedal...
John deere L108.drives for about 2 minutes mowing and stops.leave for about 15 mins and will go again.puffs of smoke when put under load
John:
The puffs of smoke when you put the machine under a load make me think that your carburetor is loading up and needs to be adjusted. Adjust the fuel/air adjustment screws on the carb until it runs properly.
Jan 20, 2013 | John Deere Garden
I have a John Deere LA105 Riding Mower and when I mow it leaves a strip of grass in the middle. Left and right sides are cutting fine. I have taken the blades off and shaarpened them and have leveled...
jack the tractor (using a tractor jack) or remove the deck, measure the blade tips against each other where they meet in the center of the deck and see if they are the same tip to tip. Bearing wear, a bent deck or blade can make them cut at different heights in the center.
Sep 25, 2012 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
John deere riding mower will not go forwards or backwards and was just mowing yard with it. it will start it will cut grass but will not move now help
If it is the belt driven version you should have a deck belt and a drive belt. The drive belt is under the engine. If you have the hydraulic version check for a broken linkage at the pump.
Apr 22, 2012 | John Deere Garden
I have a John Deere L120 tractor with a hydrostatic transmission which after a half an hour of mowing struggles to go in reverse and seems to loose power when moving forward without stressing the motot. I...
Hi, your problem is caused by the transmission over heating. Remove the battery and battery carrier and clean all grass and debris from the hydro cooling fins and fan. Hope this is helpful, regards Phil.
Sep 08, 2011 | John Deere 22HP VTwin 48" Riding Mower
When mowing with my John Deere riding mower, it leaves a narrow strip of grass uncut in the center.
try sharpening the blades on the mower. dull blades can sometimes cause a strip of uncut grass
Aug 19, 2011 | John Deere 22HP VTwin 48" Riding Mower
The battery in my JD lawn tractor was dead; it started and mowed several times with a jump start but eventually only the tractor would run while the mower would not engage. With a new battery installed,...
I suspect that the alternator/generator has gone bad, preventing the battery from chargine, or generating enough voltage to keep the electric pto on your mower engaged.
I think that it is located on the engine beneath the flywheel.
I hope this helps you.
Aug 03, 2011 | John Deere Garden
I have a john deere gt242 mower, when i pull the pto knob to turn blades on they wont turn on. What could be the problem
Could be debris in or around the assembly,check under the fenders too.Check the tension on the belts.Good luck and happy mowing.
May 11, 2011 | John Deere Garden
Garden Logo
82 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
