Question about Dimplex Heating & Cooling
Where to replace bulb for dimplex fireplace heater
5 Suggested Answers
  • 3239 Answers
SOURCE: remote control working with fireplace.
try www.dimplex.com go to customer sevices they should be able put you on to a local dealer in your area
hope this is of some help
Posted on Dec 13, 2008
reddyanantha
  • 205 Answers
SOURCE: The heater on my dimplex fire appears to be
dear sir/madam
have you checked for the power supply before changing the bulbs,if not please check it then you come back to us we will help you.
Posted on Aug 06, 2009
  • 4736 Answers
SOURCE: HOW TO REPLACE BULB ON
On the back of the stove, you will see a rectangular access panel near the bottom of the stove. If you remove that, you will have access to the bulbs. They are 60 watt, small base chandelier bulbs.
Hope this helps you change the bulbs.
Posted on Mar 28, 2011
  • 4736 Answers
SOURCE: How do you disassemble the
Good information. Thanks for sharing it.
Posted on Aug 23, 2011
Heater works but there are no longer any "flames."
The flames for most electric fireplaces are a reflection of light cast onto a rotating drum of reflective strands of tinsel. The lack of flames is likely due to a burnt out bulb. In most cases, you must remove the fireplace cover to get to the bulb.
Feb 07, 2013 | Dimplex DS5598 Mid-Size Heater
I have 2 Dimplex DS4411 fireplace heaters. One has the fire display, but does not heat. The other has heat, but no fire display. How do I fix it?
The fire display is a simple replacement of the light bulbs that produce the effect.
The heater issue could be a bad temp sensor, or a bad heater.
You can contact Dimplex support here:
Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Nov 28, 2012 | Dimplex DS4411 Electric Heater
What type of bulb is required for the mcn20 dimplex fire thank you
Steve, a 60 watt, small base, chandelier bulb is what is required. There are usually 3 to 4 of them in most electric fireplaces.
Hope this helped you. Please let me know. Thanks.
Jun 17, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
How to change bulbs on Dimplex HTN 20
If you have a compact fireplace in a cabinet mantle, you will need to remove the front Plexiglas and frame from the front of the firebox. Remove the logs, then the 1- piece ember bed (it just lifts out). This will give you access to the light bulbs.
If you what looks like an old wood stove, you access then from the rear of the unit. Remove the bottom access panel by unscrewing the 4 screws that hold it in place. You can then reach the light bulbs to change them.
In both cases, the replacement bulbs are small base chandelier bulbs.
Hope this helps to solve your problem.
Mar 11, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
Light bulb reflection on wall beside fireplace
yes also try using a frosted bulb or the new mini twist bulbs
Jan 13, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
BULBS
go to: www.dimplex.com
1. click cust suppt.
2. click tech suppt.documents
3. click parts & service
4. click stoves and choose your model
file will come up
Jan 04, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Remote control working with fireplace.
Dec 13, 2008 | Dimplex DS5603 Heater
Heating & Cooling Logo
29 people viewed this question
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
