My 55 inch Phillips TV keeps kicking off youtube
  • Televison & ... Master
  • 3,051 Answers
Hello Jamie Florence,
First best guess... Power Board:
While I dearly love to tell folks there are really only two (large)
circuit boards in most modern "FLAT PANELS"...
That is NOT actually the (whole) truth is there are several...
The least of which is your power CONTROL , which
includes your IR receiver (typically) together with
your SET resident controls... (On, Off, Volume, et al).
Just to assure yourself the "problem" is
INTERNAL you should tape off your IR receiver...
Your owners manual PROBABLY discusses moving your set out of DIRECT SUN... and taking precautions to afford reliable operation (could also be your REMOTE) ... Putting on the TAPE will prove it into the SET.
## Cautions:
Always check your OWN BOARD NUMBERS...!!!
Never force any connections...!!
Take lots of pictures ... put EVERYTHING EXACTLY BACK.
My first and ALWAYS recommendation... always protect delicate SEMI-CONDUCTORS by wearing anti-static wrist straps... A tiny static spark you might not feel is sufficient to RUIN the diodes in your cars ALTERNATOR (honest... for reals).
Second serious precaution... Use shopjimmy, amazon, eBay or worse... (at page bottom)
Never rely on anything but your OWN circuit board numbers.
Serious ELECTRONIC technicians always take STATIC PRECAUTIONS... and turn off the power (when-ever possible).
It is not improbable that another board is your issue...
but compared to a "QUALIFIED" (good) home repair technician...
It is a mistake you can afford about 5 more times...
and if you can go BACK to your ORIGINAL FAILURE condition... you are doing fine (excellent start)...
Most "home technicians" aren't even good.
As far as I'm concerned... these packs are too cheap to recommend live power tests (YOU can get seriously ZAPPED)...
If the SET does not immediately power up... I would suggest you assume 1 (one) of two (2) things...
1. Your "NEW" board is also bad (or you did not try to select "sources" when you installed it... (been there.. did that).
2. It was actually your MAIN-BOARD that needed to be replaced.
Buy one.... TRY IT.
Hey... if you like the set... so you end up with a couple of spare packs... properly handled & stored they will only appreciate in value).
Ill-advised activity... (voltage testing)...
It is SAID... WHAT does not kill you makes you stronger...
(I recommend WEAK: these packs are inexpensive
(Not worth ANY RISK)).
If you own a decent volt meter...
and you can look CLOSELY at the TEST POINTS... YOUR POWER BOARD voltages are printed on the circuit-board OUTPUTS:
Just keep in mind... you can get hurt... while causing more damage... with careless handling!!
Take photos... Work safely... Check your numbers and
ALWAYS wear ESD (static) wrist bands...
Hope this helps!!
TV Parts Universal TV Stands DLP Chips ShopJimmy
Carnac the Magnificent
Posted on May 04, 2017
Which version do I need to transmit from my pc to my tv via wifi?
you have to have either a SMART TV or a TV with USB PORTS. Basically if your TV is more than 2 years old it may not work.
I have a 55 inch LG and a 55 inch Phillips and they work great for getting on the internet and adding a external hard drive. Plus you might be able to use RUKU and other usb devices on the newer TV's
If you decide to get a SMART TV I would suggest a wireless usb keyboard with touchpad. Have fun.
Jan 17, 2016 | Google Chrome
I have a 52 or 55 inch phillips magnavox ptv 805 rear projection tv but the color isnt right on it everything else works fine i can see the picture fine but its just the color what can i do
Thats a common problem caused by the CRT coolant needing replacement. The Phillips CRT coolant kit is available from which contains the coolant and the CD with instructions.
Jun 30, 2011 | Televison & Video
I have a faded picture on my Magnovox 55 inch
You can get the service manual at
If the color are dim you most likely need the phillips coolant kit also available there which contains the CD with instructions.
Jan 01, 2010 | Televison & Video
My Mitsubishi tv power light keeps blinking
have a 55 inch Mitsubishi TV.. the green power light keeps blinking.. is there anything I can do myself?.. or I have to have someone to get it fix?
Nov 29, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Phillips 55 inch rear projection tv red convergence screwed up
Install the DPTV305_DPTV345 Chassis convergence repair kit. You can get the kit at the following link and it contains the parts plus instructions on CD.
Jul 25, 2009 | Philips 60PP9202 60" Rear Projection...
Have a 55 inch older tv color is starting to fade like a rainbow red and green can I get this fixed for a cheaper price of a new one
go toa tv repair shop and tell him to recharge the tube or tell him to change the   colour ic which will get better
May 19, 2009 | Philips TV Tuner Video Capture PCI Card -...
Screen missing
you will need the replacement screens. Phillips doesnt make them anylonger, they are exspensive. But you can get one by leaving a email at the following link with the model number of your set and what youre needing.
Jul 03, 2008 | Philips 55PP9401 55" Rear Projection...
55 inch phillps projection tv model #55p8341
you have to have your ant/cable connected to but tunners on the back you should see a ant1 and a ant2 then select pip from your remote
Jan 20, 2008 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
