Turn of cc
Cc wont turn off
Why wont my pocket bike start
chances are the carburetor is set too lean, turn the screw all the way in and then back it out 1 1/4 turns, then adjust in 1/4 turn increments to get it running at peak performance.
May 21, 2014 | Quad 47 cc / 49 cc Pocket Mini Bike...
Engine wont start on mini quadard 49cc model atv-2
A lot of guys are having trouble with that. If you have spark. disassemble the carb and clean it. then screw the set screw all the way in and back it out 1 1/4 turns. if you need more you do it in 1/4 turn increments.
Dec 24, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
Mini quadard 49cc model atv-2 pull start problem
a lot of guys are having issues with these machines. Most I believe are due to the carb settings. Turn the set screw all the way in and back it out 1 1/4 turns. Try that. if you need more you do it in 1/4 turn increments
Trying to start mini quadard 49 cc model atv-2
Try turning the carb set screw all the way in and back out 1 1/4 turns. If you need more... do it in 1/4 turn increments.
Atv wont start has fire gas in cylinder wasrunning fine quite on it own has only 1500kms on bike
you have a carb issue. turn the set screw all the way in and back it out 1 1/4 turns. this should work for you. if you need to adjust it... do it in 1/4 turn increments.
Dec 22, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
My bike wont start I replaced spark plug
most likely carb setting. Try turning the carb set screw all the way in and back out 1 1/4 of a turn. then adjust by 1/4 of a turn to fine tune it.
Aug 05, 2013 | Quad 47 cc / 49 cc Pocket Mini Bike...
50 cc automatic scooter wont start its electrical has power to light horn blinkers but turn key wont start
might pay to check the brushes inside the startermotor, and check connections to it.
Feb 21, 2013 | Motorcycles
My 49cc wont fire over
My 49cc 2 stroke pull start scooter wont turn over
Aug 19, 2012 | Quad 47 cc / 49 cc Pocket Mini Bike...
Lifan metro scooter wont turn off
have a look at the cdi plug ...one of the terminal in the plug cluster may have a broken wire or not making good connection with the cdi.
Jan 13, 2010 | Quad 47 cc / 49 cc Pocket Mini Bike...
Closed caption wont got off on sharp flat screen
If you didn't already check your TVs MENU for it's CC options and turn them off, Check there first possibly in the Audio Section. Second is check your Cable or DTV Box MENU to make sure that is turned off. With Cable you press the SETTINGS Button and on DTV you press MENU I believe.
Apr 28, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
