Question about Whirlpool Microwave Ovens
Whirlpool microwave sqeals for 1 second everytime we us it. What would cause this?
My whirlpool microwave does not work and flashes a F1E4,MW POWER RELAY. I assume this is a fault, but don't know where relay is?
microwaves ovens are not consumer fixable. They are too dangerous and have special security screws to stop you getting inside them. There are capacitors in there that have HUGE volts enough to throw you across the room or burn a hole in your skin, and a part of the magnetron has beryllium which is toxic, breathed, or ingested. Thirty seconds of microwave energy at 1 metre will blind you.
Take it to a Whirlpool dealer.
Oct 16, 2016 | Whirlpool Microwave Ovens
High pitch noise
Sounds like a bad capacitor. Careful, they hold a big charge long after being turned off. They are usually not too expensive. Bad ones will bulge at the top or bottom, leak.
Nov 26, 2013 | Microwave Ovens
Microwave now takes ~2x longer to heat up and is steaming up inside
Place a 1/2 litre of water in a plastic microwaveable container. Record its temperature and place it in the microwave. Microwave on full power for 1 minute. Leave for 30 seconds and measure the temperature again.
If the temperature rise is at least 10 degrees Centigrade, the magnetron is fine.
Mar 02, 2011 | Whirlpool Microwave Ovens
Our Whirlpool over the range microwave makes a clicking sound for a few seconds then shuts the microwave off. The microwave is unusable. The sound seems to be coming from the control panel.
If the cooling fan is not working, that would explain the shutdown problem. The function of the fan is to cool the magnetron down when it is warming or cooking the food, if the fan fails to run, the thermal fuse will detect heat rise causing a shutdown with in 5 seconds or more, the clicking suggest fan issues. I would recommend a whirlpool technician to go through the system.
Jan 27, 2011 | Whirlpool MH7140XF Microwave Oven
When I type in the time to cook food, the microwave will run for about 2 seconds and then turn off and beeb 3 times. what causes that?
Boy, this sure sounds like a GE with a failing leaky magnetron, but that's not possible since you posted this under Whirlpool MH1160XS.
But it may still be a bad magnetron...
Aug 19, 2010 | Whirlpool MH1160XS Convection/Microwave...
Whirlpool mircowave will not heat
HI, the high voltage capacitor is unstable and, it has damaged the Magnetron. you will need to replace the Magnetron. it will run you about $191.30. this will restore the heating action in your microwave unit.
May 27, 2009 | Whirlpool MH6130XEB/Q Microwave Oven
Microwave hood # 721.80833500
One of 2 things are happening..One of the thermo protectors has a bad connection (Kenmore is good for these) or the Magnetron has a leak inside the control cavity causing a temporary short in the control.
Dec 30, 2008 | Kenmore 80809 Microwave Oven
Whirlpool Miccrowave (GH7145XFQ-1) went dead...
Does the display light up?
Are you sure it is getting power?
Check that and get back to us cause the next step is going inside
Jan 01, 2008 | Whirlpool GH7145XF Microwave Oven
Small fire n microwave
check mains supply at control circuit, and check all the high voltage circuit diode and condencers and magnetron.
Dec 20, 2007 | Whirlpool MH7140XF Microwave Oven
Microwave Ovens Logo
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
