Question about Sony Audio Players & Recorders
I NEED HINGE KITS FOR 2 SONY PS DJ9000 TURNTABLE LIDS
DJ TURNTABLES MUSIC
bhiga
  • 119 Answers
SOURCE: Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
Posted on Apr 05, 2008
  • 42 Answers
SOURCE: sony ps-lx2 turntable clicks when spinning
It seems something may have come loose over time or history, but you will have to delve inside to see what it is. It sounds as though the fault should be obvious.
If you do not want to do this, a repair shop should have no problem. I assume that the deck is working ok otherwise.
Posted on Jan 25, 2009
SOURCE: Sony PS-LX300USB Turntable, one channel not working
Have you tried swopping over the output leads from the turntable to the amp (normally one red and one white phono plug) so they are in each others socket? If you do this and you still get no sound from the right channel it is almost certain to be a faulty amp,or speaker.
If you swop and get no sound from the LEFT channel it is could be either a faulty lead or cartridge.
Posted on Apr 19, 2009
  • 691 Answers
SOURCE: one of my DJ turntables = only left side stereo sound
need to narrow it down, using 1 turn table ONLY with the mixer on channel 1 (the chanel that is working) to test reciever is working properly and sound working on both side of the speakers, this eliminate the first turn table. Next, disconnect the working turn table (1) and connect your second turn table to the same chanel and see if you getting the sound coming chanel 1 just as your first turn table did. If you getting sound coming out from turn table on ch1 than is not the turn table issue. It will be you mixer having problems. You cant solve the problems having everything connected. Testing one turn table at a time using working chanel on the mixer to see if both turn table working properly. If you use the same chanel testing both turn table and the second one does not work than it will be one of your turn table is faulty. Note: if you find and test both of your turn table is working properly than it will be your mixer. good luck and hope that help..
Posted on Aug 06, 2009
  • 3 Answers
SOURCE: I need to determine appropriate stylus replacement
any stylus should work i think radio shack sells them for pretty cheap and I know for sure that best buy sells them for cheap thats where I got mine. Best though from what I can remember is diamond tip but very coastly.
Posted on Sep 23, 2009
The hinge is broken on my Sony Turntable, and I have failed to fix it. Isther someoneto whom I could take it, or send it?
Contact Sony they will then send you a list or tell you who carries out repairs in your area.
Jun 21, 2014 | Sony Audio Players & Recorders
I have a Sony turntable system PS-636 which I bought as new in the UK many many years ago. It is not working and an engineer who looked it says the capstan motor (whatever that is) needs to be replaced and...
There's only one motor and that turns the turntable! If it has gone your in trouble. If the engineer can't get one it could be double trouble for you. I can only advise you to contact Sony and see if the motor is still available. If it is you can tell the engineer about it. If not I would sell it on E-Bay marked for parts only! Put any money you make towards a new turntable. There's lots of demand for parts such as the lids etc on E-Bay.
Oct 01, 2010 | Sony PS-LX350H Turntable
Sony Belt Drive Turntable Platen speed
Check for grease on the platter or anywhere in the mechanism. Sometimes somebody has messed around with the speed preset, there might be two. You could try adjusting them. Sometimes they are found on the underside of the turntable, covered up, or they will be on the PC board of the deck.
Jan 08, 2010 | Sony PS-LX250H Turntable
How to connect my turntables to my mpc 1000
If your turntables use ceramic cartridges, you'll need to use a passive interface box that converts the unbalanced ( RCA ) plugs from the turntable to balanced ( 1/4" T-R-S ) plugs to connect to your MPC1000's stereo line inputs. If your turntables have magnetic cartridges, you will need an active phone preamp, check the music retailers catalogs or on-line there are many makes and models.
If you want to mix the two turntables ( sequeing from one to the other and back continuously as in a DJ setup ), you'll need a small DJ mixer.
Hope this helps.
May 03, 2009 | Akai Mpc1000 Sampling Music Production...
Low volume on PS LX250h
This turntable has a built in pre-amp, under the platter is a on-off switch. Turn it to "on".
-Former PS-LX250H owner
Dec 12, 2008 | Sony PS-LX250H Turntable
Sl-1210mk5g's
It should be fairly obvious. The only thing I can think of it that the hinges are missing (these slot in to both the lids and the turntable and are easily lost if someone has been using them with the lids off).
If they are missing, it certainly would make it difficult to figure out!
Matt
Feb 29, 2008 | Technics SL-1210M5G Turntable
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
