SONY PS DJ9000 LID HINGE KITS - Washing Machines
The hinge is broken on my Sony Turntable, and I have failed to fix it. Isther someoneto whom I could take it, or send it?
Contact Sony they will then send you a list or tell you who carries out repairs in your area.
Jun 21, 2014 | Sony Audio Players & Recorders
Scvs605a slow cooker hinged lid replacement
Great news !
Think I found a place for you in Canada that carries the hinged lid for your model
it's $15.99
http://www.crock-pot.ca/en_CA/parts/crock-pot-slow-cooker-hinge-lid/7921000031743.html
happy cooking
Dec 05, 2017 | Rival SCVS605A Slow Cooker
ASUS U46E broken hinge
Replacing a hinge, or both of them, isn't very tough. Check out this WEB site.
http://www.insidemylaptop.com/replace-br... Replacing Display hinges for your laptop maybe available from thia WEB site.
http://www.laptopparts101.com/display-screen-hinges/
Aug 27, 2012 | ASUS Computers & Internet
Kenmore Elite Oasis Washer Mod #110.27082601 Ser # CT1170582. I went to put the lid down and heard a "pop" type sound, and now the lid won't stay up. Everything else is working properly, and the...
Hello Chrissym1313,
Taken straight from the APPLIANCEPARTSPROS.COM
website... (Left & Right hinge Springs)
Hi--the lid on my Kenmore elite washer does not stay open on its own anymore--from what I have read-sounds like I need new hinge lid springs--can you tell me part #'s and how I would go about replacing those--thnx!!
Mike J for Model Number 110.28082700
Answer Hello Mike. You will need to order WP8580114 and WP8580115 for the unit.
Cross Reference Information
Part Number WP8580115 (AP6013571) replaces 8563961, 8580115, PS11746797, B008DK65SA, B002M647S6, B072YYQ2TQ.
Right hinge spring:
http://www.appliancepartspros.com/whirlpool-hinge-spring-rgt-wp8580115-ap6013571.html
Left hinge spring:
Whirlpool WP8580114 Hinge Left AppliancePartsPros com
Hope this helps
Carnac the Magnificent
Once you have your absolute part numbers... Then you can go SHOPPING... (Left: on eBay $25.50 plus tax & shipping)
New OEM Whirlpool Kenmore Washer Door Hinge 8580114 WP8580114 LH eBay
Right hinge
Amazon com Kenmore Elite W8580115 Washer Lid Hinge Home Improvement
RH hinge on PARTSELECT... ($39.20 plus tax & shipping)
Whirlpool WP8580115 Hinge PartSelect
Dec 18, 2017 | Washing Machines
We have a PS 2 slim silver console and the discs won't spin.
If its still under warranty then send it back to Sony to fix it. If not the problem probably is one of the tabs that trigger the switches might be broken off. the tabs are the plastic protrusions on the lid. if the switches are not hit the ps2 will think the lid is still open and will not spin the disc.
Apr 26, 2010 | Sony PlayStation 2 (PS2) Console
Sony VGN AR630
If the lid has a small slack and then is firmer again when the lid/screen is in another position, then the hinge mounting screws is most likely loose and the mounting screws needs to be tighten.
If the hinges are loose no matter what the position of the lid/screen is in then, they need to be replaced, there is no adjustment to tighten the hinges.
Jul 23, 2009 | Sony VAIO VGN-AR630E Notebook
Washer fills with water but wont drain
Check your lid switch. If your washer fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle or drain, the problem is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: Some washer models have the lid switch located near either the left or right hinge of the lid. This type of switch is activated by a rod on the hinge pin. If not functioning, it can often be adjusted by bending the hinge rod until it engages the switch.
If you have any questions, please let me know. I hope this helps you.
PS You do not have to drain the washer to complete this repair. Once the switch is replaced the washer will drain on its own. This may save you the need to bail water again.
Jul 19, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series
It sounds like you have a bad lid switch. If you open and close the lid, you should hear a distinctive "clicking" sound as the lid switch is activated when the lid closes. If you hear no sound, you need to check the following:
Some washers have the lid switch under the right-hand side of the wash tub opening and is activated through a small slot on the wash tub casing rim by a small plastic piece on the lid called a lid strike. If this is the type you have, make sure the lid strike is still intact or the switch will not activate. Check the two mounting screws next to the slot and make sure they are present and tight. These are the mounting screws that hold the lid switch in place. If they come loose it can prevent the switch from activating.
Newer models have the lid switch mounted under the washer casing in the left-hand rear adjacent to the left washer lid hinge. The switch is activated by a rod on the lid hinge. Sometimes a simple adjustment of this rod can correct contact problems.
No matter what configuration you have, if you make all these preliminary checks and the switch still does not work, replace it. The following link will give you step-by-step instructions on how to accomplish this:
If you require further assistance, please let me know. I hope this helps you.
PS If you provide me with your COMPLETE model number (located under the washer lid along the tub rim) I can also assist you with locating parts.
Jul 03, 2008 | Kenmore 24032\24036 Top Load Washer
Drum wont spin
The problem is your lid switch. This is a common problem that can be easily fixed. If you click on the following link, it gives you step-by-step instructions on how to replace a lid switch.
http://www.fixya.com/support/r385199-replacing_lid_switch_whirlpool_top
Typically, the lid switch becomes loose, or the contacts eventually fail from repeated use. If you open and shut the washer lid, you should be able to hear a "clicking" sound as the lid switch activates with the lid closing.
The switch is located on the the right-hand side of the lid on some models, and is activated by a plastic piece on the lid, called a "lid strike". Make sure the lid strike is still intact.
On other models the lid switch is located on the left-hand side under the washer casing near the left lid hinge. It is activated by a small rod that closes the lid switch contacts when the hinge pivots. Sometimes a simple adjustment of this rod will cure a lid switch problem.
If you post back with your model number, I can tell you which type of lid switch you have. Typically, they range in price form about $25 to $35. I hope this helps you.
PS Pine Sol would not cause this problem. I think this is just a coincidence.
Jun 30, 2008 | Washing Machines
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
