Question about Troy-Bilt Garden
How do I replace a PTO cable for a 2009 Troy-bilt Bronco 42?
  • 41 Answers
SOURCE: TROY BILT TRIMMER MODEL TB70SS. HOW DO I REPLACE
Is the pull rope in the front or rear of engine.Thinking that the string is in the front,you must throttle housing and shaft from engine. remove starter housing. There sould be a screw holding the string and spring in place.
Posted on May 07, 2009
  • 22 Answers
SOURCE: Troy Bilt Tiller tines do not engage
You likely have a clutch problem, never saw one that a simple adjustment would fix. I'd take off the tiller (there are two bolts that hold the tiller portion to the transmission, and check to make sure the clutch is sliding in and out. My hunch is either the lever is loose on the shaft or the allen-head little bolt that they use to shift the clutch has come out. Be sure to grease the clutch while you're in there.
This should be covered in your owners manual. Shame on them if they didn't mention this.
Posted on Jun 14, 2009
  • 376 Answers
SOURCE: require an operator's manual for a bolen troy bilt ltx 14 hydro
Go to... http://www.buymtdonline.com/webapp/wcs/stores/servlet/FindingYourPart_10101_19502_-1 Scroll down to bottom left and click on Owner Manuals. You will have to have the model and serial numbers from under the seat of your mower.
Posted on Jun 19, 2009
  • 202 Answers
SOURCE: I have a Troy bilt 17hp 42 inch cut ride on lawn
yes they have a charging system, not like a car but a charging system one the less. as i said before either under or around the flywheel. some newer mowers also have an electronic regulator.
Posted on Jul 31, 2009
  • 297 Answers
SOURCE: Replacing Drive Cable on 05 Troy Bilt Self Propelled Lawn Mower
It is a pain in the ***!!! but not impossible to do it your self.
Posted on Aug 16, 2009
Troy Bilt 33" walk behind mower blades won't turn on.
Troy-Bilt Lawn Mower Blades Won't Engage - Model ...
www.repairclinic.com/...Mower/...-/Troy-Bilt-Lawn-mower-blades-won-t...
Most Frequent Causes for Lawn mower blades won't engage. See All Lawn Mower Parts for model 13AP60TP766. Cause 1 PTO Clutch. If the blades don't rotate the electric PTO clutch might not be engaging. ... Lawn mower wheels don't turn ...
Nov 08, 2015 | Troy Garden
Need a 42 inch Deck Manual PTO belt 742-0485 can't find one?
Didn't take long to find this belt. Check out this link:
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=pto+belt+742-0485
Apr 26, 2015 | Troy Bilt 175HP Manual 42" Riding Mower
Pto will not engage on my troy-bilt 42 inch cut
belt tensioner mechanism is not engageing properly.First check the engaugement cable for flaws or mounting problems. I suggest this first as these cables are under built and usually only 1/8" thick. this way the manufacture can ding you another 50 bucks ever time they fail.
Sep 02, 2014 | Garden
After running for a while my Troy Bilt RZT tractor Colt ZT42 PTO stops working
pto going out or stater going out run till it does then replace i the red neck saya it the pto replace if you cant live with it till burns out
Aug 31, 2014 | Troy Bilt 5.5hp Self Propelled Mower
Troy bilt
It thinks that the PTO is on. Do you have two different key positions? If so try both for a temp fix. If not it's probably a linkage or switch problem.
Aug 02, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Troy bilt troubleshooting
Check under your deck you could have something that is keeping your blades fro turning.
Aug 01, 2014 | Troy Bilt 175HP Manual 42" Riding Mower
Need a owners manual for troy bilt 17.5 hp 42 inch pony lawn tractor
HOW TO CHANGE A BELT ON
  • Troy-Bilt 17.5-HP Manual 42" Riding Mower
  • Nov 30, 2009 | Mtd Garden
    Had to change the small drive belt that drives the transmission on a Troy-Bilt 42'' 17.5 HP Pony mower. Now it only has one speed forward, slow!! Didn't touch anything-got the OEM belt replacement. Any...
    You need to adjust the gas pedal. Info should be in the owners manual. I have it in my Troy Bilt Bronco manual. It say to adjust it in my book after replacing the trans drive belt. Maybe that will help.
    Aug 17, 2009 | Garden
    Garden Logo
    Top Troy-Bilt Garden Experts
    Jay Finke
    Jay Finke
    Jim Parker
    Jim Parker
    Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
