Question about Kodak EASYSHARE Z1285 Digital Camera
My kodac Z1285 stopped working and the whole lens is out, after i clicked the power it started ok then i zoomed in, after the lens is completely out ''maximum zoom'' it stoped working and never come back on. the batteries is fully charged, although i tried another fully charged batteries i was thinking just to go to the screws and open it to see what is happened but i don't know, what shall i do?!
Don't open it!! That will void any warrenty the camera has! Have you tried cleaning it with Denatured Alcohol? You can puchase it at any store with a hardware dept. Just soak a q-tip in the alcohol and swab the camera down. It's safe to use on the screen and keys, and zoom buttons. I turn mine off and on several times to ensure that all the moving parts get cleaned. The alcohol evaperates almost instantly so theres no need to dry it off unless it's soaked. I clean mine outside on a picnic table b/c the alcohol has fumes and an odor that is a bit overwhelming. I hope this helps, if not call kodak, espically if it's still under warrenty. This denatured alcohol tip was given to me by a camera specialist.
Posted on Jul 28, 2009
I had the exact same problem with the same model camera, when you insert new batteries you have to set the date and time or your camera will malfunction and the only way to fix it is to have a manufacturer reset it; there is no way to reset the camera yourself
Posted on Sep 02, 2009
Fuji finepix s3100has no power even with new batteries
I have this problem also with Fuji Z90 model.
Problem is fixed and focus now working ok.
Camera is fall down and after when camera was started giving sound click click from focus big motor and error on screen Focus error
Focus ( lens ) was open ( small cover on top bellow sticker ) Small "snail" gear is taked out . Two sliding segment adjusted for focus ( upper full up and lower full down - beware about spring inside below this focus pins )and snail is inserted back. Camera started and focus start working. I need to make small adjustment . Reason when camera is started picture is not clear and before using camera i need to do full zoom in and back zoom out. After this picture is crystal clear and all working ok.
Dec 17, 2012 | Fuji FinePix S304 Digital Camera
Getting an zoom error on my fuji film finepix z90, what can i do?
Lens errors (zoom errors on Fuji's) are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to lens error problems can only be corrected by professional repair. But, here are some last resort troubleshooting steps that you can try that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try.
Jun 25, 2011 | Fuji FinePix S304 Digital Camera
The lens won't retract. the camera no longer functions
If dont mind i would suggest you to contact any expert or SERVICE CENTER because according to the problem you describe is technically difficult and due to jurk the gears of the zoom lens assembly may be broken misaligned, and there is a specific method to open the zoom lens assembly to change the gears, Or the if you want to repair it by yourself then you have to replace the complete lens block assembly, Therefore i would advise you to contact any expert for repair,
Jul 11, 2009 | Kodak EASYSHARE Z1285 Digital Camera
My Easy Share (Z730) is in the open position & will not close.
VERY COMMON WITH EASY SHARE. There are only a couple things you can really do. FIrst, try removing the memory card and try it. Than if that dosen't work. Try holding power button while gently wiggleing the zoom.
May 30, 2009 | Kodak EasyShare One Digital Camera
My FINEPIX s1000fd fujifilm camera displays zoom error! in red and won't take pictures please help. We put new batteries in and think I have all the settings right thanks ellen
Try these:
1) Make sure the lens cap is off. When the camera fires up, if it feels any resistance, it will stop zooming and tell you "zoom error"
2) Recharge or fit new batteries. Use 2700 power if you can get them.
3)Is there a bit of dirt between the zoom part and the camera body? I had this problem after my camera had been in my overcoat pocket. I cleared it out with a stiff artist's brush. Do NOT use WD 40 or similar, as I found to my cost on another camera. It eventually seeped through to the works and made all the pics cloudy!
4) Hold the camera body in one hand and gently wiggle the zoom part from side to side and up to down.You will hear a quiet click in the mechanism.
I have used my S1000fd lots now, and the initial "zoom error" problems have stopped.
It's a fine little camera, I especially like the 12x zoom and the live histogram. Mine has taught me lots about photography.
Dec 26, 2008 | Fuji FinePix S1000FD Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
V570 Dual Lens, will not switch to ordinary lens.
Hi, My V570 works fine on widescreen lens (the default on startup) but when I zoom up to switch to the other lens it goes to a dark blank screen and will take a similarly dark blank picture. I can hear the zoom activating as I click it so I think that is ok. I opened the camera
Jun 10, 2008 | Kodak EasyShare V570 Digital Camera
Camera really messed up!
Have you tried taking out the batteries and leaving it alone for a bit, then loading new batteries? I would try this first before anything. Good Luck.
Apr 09, 2008 | Casio Exilim EXZ75 Digital Camera
Kodak EASYSHARE Z1285 Digital Camera Logo
222 people viewed this question
Top Kodak Cameras Experts
Tony
Greg Cann
Greg Cann
Are you a Kodak Camera Expert? Answer questions, earn points and help others
