I
Ibrahim Glavovic Posted on May 03, 2017
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I can't select PDF for Format on the scan setting screen when scanning off Canon printer? There is no pdf option at all. What causing problem and what procedure should I follow to fix it?
Printer: CANON PIXMA MG5760
Ross Stacey
Level 2:
Habit-Forming:
New Friend:
  • Expert 39 Answers
  • Posted on May 03, 2017
Ross Stacey
Expert
Level 2:
Habit-Forming:
New Friend:
Answers
39
Questions
0
Helped
20476
Points
101
I scan using M/S windows scan and fax app. I save the scan. Then I open the scan and print, selecting PDF printer on computer. From there I can open to read, send by email or print a hard copy from my printer.
3 Related Answers
Anonymous
  • 5 Answers
  • Posted on Jul 21, 2010
SOURCE: Setting PDF as default scan setting on Canon Imagerunner 3035
Additional Functions (hardware button on the panel)
Communication Settings
TX Settings
Scroll down to 2nd page
Edit Standard Send Settings
File Format: PDF
Scanning Mode: Black 300dpi
Anonymous
  • 32281 Answers
  • Posted on Aug 17, 2012
SOURCE: Canon irc2250i printer, how do I scan as PDF automaticaaly instead of TIF
Scan and create PDF document You need to install a PDF printer driver on your computer first. There are quite a few freeware PDF writer programs on the Internet you can download one such as CutePDF.
From your computer SCAN your document then click on File - Print and select the PDF writer as the printer device. Then name and save the PDF file. To download Cutepdf PDF printer driver (freeware) click on this link :- http://www.cutepdf.com/
Terry Corrow
johnny rebel
  • 10875 Answers
  • Posted on Jun 24, 2015
SOURCE: Canon 495 pixma scanner printer. When I go into devices/printers and select printer then under scan management section it will not let me select scan. It just does nothing now.
update the scanner drivers
How do I change the default file format from Jpeg to PDF on a xerox M24??
The following information provides an Overview of the Printer's available Scan Settings. 1. To enter the Scan mode, from the Printer's Main (Copy) Screen press the Menu button.
2. On the two-button selection screen, press the right-hand Scan/E-mail button. Note: If you press the lefthand "Copy" button by mistake you will be returned to the Main (Copy) Screen. You will then have to press the Menu button again to return to the two-button selection screen.
3. The Scan screen consists of three Tabs, with each Tab displaying a number of feature settings. From left to right, the three Tabs are labeled: Basic Scanning, Scan Options, and Image Quality/File Format.
4. When the Basic Scanning Tab is selected, three columns of settings are displayed. The first (left-hand) column of settings contains four "Output Color" selections, including: Auto, Full Color, Grayscale (256G), and Black. The second (center) column of settings displays four scan resolutions. The available selections include: 200 dpi, 300 dpi, 400 dpi, and 600 dpi. The third (right-hand) column of settings displays "2 Sided Original" selections including: 1 Sided, 2 Sided (H to H), 2 Sided (H to T), and More.... If you press More..., a screen displays with two setting selection buttons on the left, enabling you to select either 1 Sided or 2 Sided. If you choose 1 Sided, you can select an original orientation of Head to Top, or Head to Left. If you choose 2 Sided, two additional orientation buttons (Head to Head, and Head to Toe) become available for your selection. Note: To support "2 Sided" (Duplex) Scanning you will need to use the Printer's Duplex Automatic Document Feeder. When changing or viewing More... settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
5. After an Output Color is selected from the first column of the Basic Scanning Tab, and the Image Quality/File Format Tab is pressed, a screen is displayed allowing you to choose and configure the settings for Original Type (Text & Photo, Text, Photo), Image Compression (High, Normal, Low), Contrast, File Format, and Auto Exposure.
- Press the Original Type button to select the most effective scanning for your original image type. Options are Text & Photo, Text, and Photo. - Press the File Format button to select your scanned file format. Options are TIFF/JPEG, JPEG, DocuWorks, and PDF. - Press the Lighter/Darker/Contrast button to adjust scanned image density (lightness and darkness) and contrast. Use the supplied arrows to make the desired setting adjustments. - Press the Image Compression button to set the degree of data compression, used especially with JPEG scans. Options are High, Normal (default), and Low. - Press the Auto Exposure button to enable or disable this scanning feature with the ON or OFF buttons. When changing or viewing settings, press the Save button to save setting changes, or the Cancel button to exit the current screen without saving changes.
2helpful
2answers
I have an HP Officejet 6500. I want to scan a document to a PDF, then upload it to a website. How do I do it? I scanned the document, but now I can't find the PDF.
(1.) Start / All Programs / HP / HP Viewer / Scan Document (icon is in left margin)
(2.) A small screen appears entitled "Select Source", and provides the "HP Officejet 6200 Series TWAIN" option. Highlight this then click "select".
(3.) I accept the default provided on the next screen (i.e., radio buttons for "Document" & "Scan for editable text"; "Scan to:" (drop box) "HP Document Viewer; check "Show Preview" box; then click "Scan".
(4.) After a brief pause, my printer scans, then the HP Document Viewer screen on the PC provides a small image of the scanned document and allows me to click the "accept" icon.
(5.) After "accepting" the scan into the HP Document Viewer, it takes a minute for it to appear in the "viewer". Notice that the "View Thumbnails" tab is highlighted at the top of this screen. Click the check-box next to the scanned item then click the "View Page" tab just to the right of the "View Thumbnails" tab.
(6.) The new screen should show a larger version of your scanned document. Now notice the "Save As" icon in the upper left corner. Click that, then "yes" to warning default screen, then select a file name and location to save it into.
(7.) Before clicking save, click the drop box next to the "Save as type:" and select one of the pdf options. Mine offers: "PDF 1-bit", PDF 8-bit Grayscale", and "PDF 24-bit Color" options. Choose one of them then click "save".
(8.) You should then be able to find the scanned pdf file in the directory you selected to save it under.
Note that you may need all of the HP printer utilities and tool software installed for this to work. If you don't, you may need to uninstall/reinstall the printer software.
1helpful
2answers
Need to email documents in pdf format
Just scan or create the documents and save them as pdf files. Start your email & make them attachments.
7helpful
3answers
Scanning Multiple pages into one pdf
Scanning a multi-page document as a .pdf file reverts the settings for rotation, selected area, etc. to default for any pages after the first page. This applies to Mac OSX 10.3, 10.4, & 10.5. A simple, but tedious work-around is to scan each page as a separate file and easily recombine them using OSX Preview. Just open the first page, view the Sidebar, and drag-drop the additional page files into the sidebar. Save and it's all one multi-page .pdf.
2helpful
How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
32helpful
TX Settings
File Format: PDF
1helpful
Scan document to pdf format
you have to set up on the machine to scan to SMB. you then creat a folder in your c drive to recieve the scaned documents the folder needs to be a shared folder and you have the option to recieve it im PDF format.     let me know if that helps you out.
5helpful
2answers
Canon CanoScan LIDE 25
Use the PDF function of the CanoScan Toolbox. On the options screen for a pdf, click the drop down box next to “Save as Type:”. Select “PDF (Multiple Pages)”. This option causes CanoScan to stop after each page is scanned and ask if there is a next page or if you are finished.
4helpful
3answers
Cannot scan to pdf Deskjet F2100
You have to scan with Adobe Reader in order to scan and save a pdf
old marine
old marine
ZJ Limited
ZJ Limited
